i can't take a screenshot
On your printer?
A little more information would be helpful to be able to help you.
Ein paar Informationen mehr wären hilfreich um dir helfen zu können.
inxi -Fxxxza
i can't take a screenshot, on garuda screen capture don't work. not with flameshot and spactacle, screenshot is not working.
KDE? Or one of the many other DEs that Garuda offers?
Do you use lite or ultimate or Barebones version?
You see, "it do not work", is not enough for asking for help.
BTW, it work on i3wm and KDE on my PC.
⣿⣿⠏⣠⣾⣦⡐⢌⢿⣷⣦⣅⡑⠕⠡⠐⢿⠿⣛⠟⠛⠛⠛⠛⠡⢷⡈⢂⢕⢂ OS: Garuda Linux x86_64
⠟⣡⣾⣿⣿⣿⣿⣦⣑⠝⢿⣿⣿⣿⣿⣿⡵⢁⣤⣶⣶⣿⢿⢿⢿⡟⢻⣤⢑⢂ Kernel: 5.9.1-zen2-1-zen
⣾⣿⣿⡿⢟⣛⣻⣿⣿⣿⣦⣬⣙⣻⣿⣿⣷⣿⣿⢟⢝⢕⢕⢕⢕⢽⣿⣿⣷⣔ Uptime: 6 hours, 29 mins
⣿⣿⠵⠚⠉⢀⣀⣀⣈⣿⣿⣿⣿⣿⣿⣿⣿⣿⣗⢕⢕⢕⢕⢕⢕⣽⣿⣿⣿⣿ Packages: 1962 (pacman)
⢷⣂⣠⣴⣾⡿⡿⡻⡻⣿⣿⣴⣿⣿⣿⣿⣿⣿⣷⣵⣵⣵⣷⣿⣿⣿⣿⣿⣿⡿ Shell: zsh 5.8
⢌⠻⣿⡿⡫⡪⡪⡪⡪⣺⣿⣿⣿⣿⣿⠿⠿⢿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⣿⠃ DE: Plasma 5.20.1
⠣⡁⠹⡪⡪⡪⡪⣪⣾⣿⣿⣿⣿⠋⠐⢉⢍⢄⢌⠻⣿⣿⣿⣿⣿⣿⣿⣿⠏⠈ WM: KWin
⡣⡘⢄⠙⣾⣾⣾⣿⣿⣿⣿⣿⣿⡀⢐⢕⢕⢕⢕⢕⡘⣿⣿⣿⣿⣿⣿⠏⠠⠈ WM Theme: WhiteSur-dark
⠌⢊⢂⢣⠹⣿⣿⣿⣿⣿⣿⣿⣿⣧⢐⢕⢕⢕⢕⢕⢅⣿⣿⣿⣿⡿⢋⢜⠠⠈ CPU: AMD FX-8150 (8) @ 3.800GHz
⠄⠁⠕⢝⡢⠈⠻⣿⣿⣿⣿⣿⣿⣿⣷⣕⣑⣑⣑⣵⣿⣿⣿⡿⢋⢔⢕⣿⠠⠈ GPU: AMD ATI Radeon RX 470/480/570/570X/580/580X/590
⠨⡂⡀⢑⢕⡅⠂⠄⠉⠛⠻⠿⢿⣿⣿⣿⣿⣿⣿⣿⣿⡿⢋⢔⢕⢕⣿⣿⠠⠈ Memory: 6466MiB / 11959MiB
⠄⠪⣂⠁⢕⠆⠄⠂⠄⠁⡀⠂⡀⠄⢈⠉⢍⢛⢛⢛⢋⢔⢕⢕⢕⣽⣿⣿⠠⠈ Song: Shayne Hartford - Unknown Album - Genshin Impact on LINUX!
inxi -Fxxxza is not working
What is the output in terminal/konsole from
inxi -Fxxxza
Did you reboot in KDE after updates?
If nothing help restore last working snapshot.
ultimate
System: Kernel: 5.9.1-zen2-1-zen x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/vmlinuz-linux-zen root=UUID=62e1017a-d087-4b4a-a211-bd48c1081f1d rw
[email protected] quiet splash loglevel=3
Desktop: KDE Plasma 5.20.1 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: Gigabyte model: GA-78LMT-USB3 6.0 serial: <filter> BIOS: Award v: F2
date: 11/25/2014
CPU: Info: 8-Core model: AMD FX-8150 bits: 64 type: MCP arch: Bulldozer family: 15 (21) model-id: 1
stepping: 2 microcode: 600063E L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 61072
Speed: 1416 MHz min/max: 1400/3800 MHz boost: disabled Core speeds (MHz): 1: 1412 2: 1417 3: 1419
4: 1425 5: 1419 6: 1432 7: 1424 8: 1472
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: PC Partner Limited driver: amdgpu v: kernel bus ID: 01:00.0 chip ID: 1002:67df
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: amdgpu FAILED: ati
unloaded: modesetting,radeon alternate: fbdev,vesa display ID: :0 screens: 1
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: AMD Radeon RX 480 Graphics (POLARIS10 DRM 3.39.0 5.9.1-zen2-1-zen LLVM 10.0.1)
v: 4.6 Mesa 20.2.1 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 00:14.2 chip ID: 1002:4383
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: PC Partner Limited
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 1002:aaf0
Sound Server: ALSA v: k5.9.1-zen2-1-zen
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
v: kernel port: ce00 bus ID: 03:00.0 chip ID: 10ec:8168
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Microsoft Xbox 360 Wireless Adapter type: USB driver: usbfs bus ID: 5-1:2
chip ID: 045e:0719 serial: <filter>
Drives: Local Storage: total: 763.85 GiB used: 580.75 GiB (76.0%)
ID-1: /dev/sda vendor: Samsung model: ST500LM012 HN-M500MBB size: 465.76 GiB block size:
physical: 4096 B logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0001
scheme: MBR
ID-2: /dev/sdb vendor: Samsung model: HD322HJ size: 298.09 GiB block size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 1118 scheme: MBR
Partition: ID-1: / raw size: 44.74 GiB size: 44.74 GiB (100.00%) used: 41.94 GiB (93.7%) fs: btrfs
dev: /dev/sdb2
ID-2: /boot raw size: 500.0 MiB size: 476.2 MiB (95.24%) used: 315.7 MiB (66.3%) fs: ext4
dev: /dev/sda1
ID-3: /home raw size: 465.27 GiB size: 456.97 GiB (98.22%) used: 374.23 GiB (81.9%) fs: ext4
dev: /dev/sda2
ID-1: swap-1 type: zram size: 373.7 MiB used: 332.1 MiB (88.9%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 373.7 MiB used: 326.8 MiB (87.4%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 373.7 MiB used: 328.7 MiB (88.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 373.7 MiB used: 313.9 MiB (84.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 373.7 MiB used: 331.6 MiB (88.7%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 373.7 MiB used: 329.1 MiB (88.1%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 373.7 MiB used: 332.0 MiB (88.8%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 373.7 MiB used: 317.3 MiB (84.9%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: partition size: 2.00 GiB used: 0 KiB (0.0%) priority: 1024 dev: /dev/sdb4
Sensors: System Temperatures: cpu: 33.0 C mobo: N/A gpu: amdgpu temp: 47.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 703
Info: Processes: 354 Uptime: 6h 28m Memory: 11.68 GiB used: 6.28 GiB (53.8%) Init: systemd v: 246
Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: pacman: 1962 lib: 565 flatpak: 0 Shell: Zsh v: 5.8
running in: konsole inxi: 3.1.06
Try reboot first and then
flameshot gui -d 5000
i did not it but this problem is occurring since I reinstalled garuda
"flameshot gui -d 5000" is working
Ok, I boot in KDE, there the "Print" Button on keyboard doesn't work.
I always use the icon in taskbar for screenshot in KDE, in i3wm the button work.
So it is maybe a KDE bug if it works before.
On my kde lite install printscreen using windows key /prtscr works
