Hi when I Try so record my screen in OBS there is major screen tearing I am using an intel GPU and KDE Dragonized Thanks in advance
Read
please
It also affects manjaro and arch.
Ah, then it is simple and we do not need more details.
And you don't need to read the wiki.
How do i fix this?
Ask OBS first, then arch, then manjaro
Not to be rude, but If you are having all the same problems on these other OS's it should be fairly apparent that this is not a Garuda specific issue.
