inxi:
Kernel: 5.18.0-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=21c7fde8-1bef-4f82-abc8-364dad2d6848 rw [email protected]
resume=UUID=59131e58-a432-49f0-bae1-aebf3325230e loglevel=3
Desktop: Tabby info: latte-dock wm: kwin_x11 dm: SDDM
Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A
Mobo: HP model: 8574 v: 21.17 serial: <filter> UEFI: AMI v: F.22
date: 05/03/2021
ID-1: BAT0 charge: 53.2 Wh (100.0%) condition: 53.2/53.2 Wh (100.0%)
volts: 17.3 min: 15.4 model: HP Primary type: Li-ion serial: N/A
status: full
Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check
bits: 64 type: MT MCP arch: Coffee Lake family: 6 model-id: 0x9E (158)
stepping: 0xD (13) microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1168 high: 1201 min/max: 800/4500 base/boost: 3960/8300
scaling: driver: intel_pstate governor: powersave volts: 1.1 V
ext-clock: 100 MHz cores: 1: 1100 2: 1100 3: 1161 4: 1183 5: 1144 6: 1200
7: 1200 8: 1201 9: 1200 10: 1186 11: 1145 12: 1200 bogomips: 62399
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 515.43.04 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Turing pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-2: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 04ca:707f class-ID: 0e02 serial: <filter>
compositors: 1: kwin_x11 2: Tabby driver: X: loaded: nvidia gpu: nvidia
Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.43x7.52")
s-diag: 391mm (15.39")
Monitor-1: DP-2 res: 1920x1080 hz: 60 dpi: 142
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
v: 4.6.0 NVIDIA 515.43.04 direct render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: Hewlett-Packard
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Sound Server-1: ALSA v: k5.18.0-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 3d:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-2: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
bus-ID: 1-7:4 chip-ID: 8087:0029 class-ID: e001
v: 3.0 port: 5020 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 1.84 TiB used: 59.52 GiB (3.2%)
model: MZVLB1T0HBLR-000H1 size: 953.87 GiB block-size: physical: 512 B
rev: HPS0NEXF temp: 43.9 C scheme: GPT
SMART: yes health: PASSED on: 249d 0h cycles: 829
read-units: 50,721,188 [25.9 TB] written-units: 53,054,602 [27.1 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 1B6Q temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 238d 1h cycles: 496
written: 2.2 TiB Pre-Fail: reallocated sector: 99 threshold: 10
ID-1: / raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
used: 59.52 GiB (6.6%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 563 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-4: /var/log raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-5: /var/tmp raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-1: swap-1 type: zram size: 31.23 GiB used: 512 KiB (0.0%)
ID-2: swap-2 type: partition size: 34.36 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 58.0 C pch: 52.0 C mobo: N/A gpu: nvidia
temp: 53 C
Processes: 327 Uptime: 8m wakeups: 1 Memory: 31.23 GiB
used: 4.51 GiB (14.4%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 Packages: pacman: 1478 lib: 369 Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: tabby inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2021-07-24
Last full system update: 2022-05-31
Relevant software: tlp NetworkManager
Windows dual boot: Yes
Snapshots: Timeshift (maybe)
Hi community,
I have this slight problem with Garuda KDE Dragonized - every time I hibernate my laptop (I almost never turn it off, only restart it after updates), some time after restoring from hibernation the screen starts glitching, sometimes on it's own, sometimes when invoking e.g. alt+tab. I can't really describe it, it's just white screen with shades of gray, however I am still able to control the system, so when I can hit the logout button I am able to log in again and the glitch is gone.
The problem is, it doesn't work all the time as I am not always able to hit the logout button
I then get an error saying that the screen effects were restarted due to graphics glitch. I also get sometimes error on screen that the hardware was changed (it was not) during the hibernation, results doubtful.
It's not really that big a problem, but I am developing on my laptop and when this occurs, lines of code not saved or already commited to git could be lost, so any help with this issue would be greatly appreciated.
