System: Kernel: 5.15.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=aed8:: Installation fortsetzen? [J/n]
:: Pakete werden empfangen …
menumaker-0.99.14-1-any ee58-bd68-4d57-a44f-29b9e986f2d2
systemd.unified_cgroup_hierarchy=1 resume=UUID=9ee15ff6-2b88-4ffc-80d9-f7a84d466859 loglevel=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 5409 date: 01/07/2020
CPU: Info: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ family: 17 (23)
model-id: 8 stepping: 2 microcode: 800820D cache: L1: 768 KiB L2: 4 MiB L3: 16 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 118177
Speed: 2493 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz): 1: 2493 2: 1932
3: 1959 4: 1985 5: 2157 6: 2177 7: 1928 8: 1896 9: 1857 10: 1991 11: 2169 12: 2253 13: 2430
14: 1871 15: 3407 16: 2014
Graphics: Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] driver: amdgpu v: kernel
bus-ID: 07:00.0 chip-ID: 1002:699f class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 69 size: 708x398mm (27.9x15.7")
diag: 812mm (32")
OpenGL:
renderer: AMD Radeon RX 550 / 550 Series (POLARIS12 DRM 3.42.0 5.15.7-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Audio: Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X] driver: snd_hda_intel
v: kernel bus-ID: 07:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 09:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK PRIME B450M-A
driver: r8169 v: kernel port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS] type: USB driver: r8188eu bus-ID: 1-3:2
chip-ID: 2357:010c class-ID: 0000 serial: <filter>
IF: wlp1s0f0u3 state: up mac: <filter>
Drives: Local Storage: total: 2.04 TiB used: 7.53 GiB (0.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM005-2CW102 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5425
serial: <filter> rev: 0001 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: R013 scheme: GPT
Partition: ID-1: / raw-size: 219.12 GiB size: 219.12 GiB (100.00%) used: 7.53 GiB (3.4%) fs: btrfs
dev: /dev/sdb3 maj-min: 8:19
ID-2: /boot/efi raw-size: 2.24 GiB size: 2.23 GiB (99.80%) used: 576 KiB (0.0%) fs: vfat
dev: /dev/sdb2 maj-min: 8:18
ID-3: /home raw-size: 219.12 GiB size: 219.12 GiB (100.00%) used: 7.53 GiB (3.4%) fs: btrfs
ID-4: /var/log raw-size: 219.12 GiB size: 219.12 GiB (100.00%) used: 7.53 GiB (3.4%) fs: btrfs
ID-5: /var/tmp raw-size: 219.12 GiB size: 219.12 GiB (100.00%) used: 7.53 GiB (3.4%) fs: btrfs
ID-1: swap-1 type: partition size: 2.21 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb1
maj-min: 8:17
ID-2: swap-2 type: zram size: 15.61 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 48.1 C mobo: N/A gpu: amdgpu temp: 41.0 C
Info: Processes: 359 Uptime: 23m wakeups: 0 Memory: 15.61 GiB used: 2.99 GiB (19.1%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1138 lib: 290
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09
"My screen size is 21 inch but it is showing 22.9 inch and edges are cut off"
