Hello, I am very much enjoying the distro during the short time I have used it, but unfortunately I'm a noob and am trying to work a few things out that I have not found a solution for.
Under Settings > Power Management > Energy Saving
I have the "Screen energy saving" box checked, with a switch off time of 10 minutes. After this time the screen does turn off, for about 5 seconds, and then immediately turns back on.
System: Kernel: 5.15.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=78cb144b-5cd4-4e11-ba58-cad9614c53fa rw rootf[email protected] quiet splash
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: TUF GAMING B560M-PLUS WIFI v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 1017 date: 07/13/2021
CPU: Info: 8-Core model: 11th Gen Intel Core i7-11700K bits: 64 type: MT MCP
arch: Rocket Lake family: 6 model-id: A7 (167) stepping: 1 microcode: 40 cache:
L2: 16 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 115200
Speed: 4744 MHz min/max: 800/4900 MHz Core speeds (MHz): 1: 4744 2: 4721 3: 4882
4: 4814 5: 4964 6: 4735 7: 4873 8: 4900 9: 4894 10: 4873 11: 4989 12: 4933 13: 4886
14: 4909 15: 4900 16: 4886
Graphics: Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Sapphire Limited driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:731f
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL:
renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.42.0 5.15.2-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Audio: Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus-ID: 03:00.1
chip-ID: 1002:ab38 class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-zen1-1-zen running: yes
Network: Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:43f0 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel port: 4000
bus-ID: 06:00.0 chip-ID: 10ec:8125 class-ID: 0200
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:7
chip-ID: 8087:0026 class-ID: e001
Drives: Local Storage: total: 931.51 GiB used: 20.55 GiB (2.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 1B4QFXO7 temp: 35.9 C scheme: GPT
Partition: ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 20.55 GiB (2.2%)
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 20.55 GiB (2.2%)
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 20.55 GiB (2.2%)
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 20.55 GiB (2.2%)
ID-1: swap-1 type: zram size: 31.16 GiB used: 4.2 MiB (0.0%) priority: 100
Sensors: System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 52.0 C mem: 44.0 C
Info: Processes: 390 Uptime: 22m wakeups: 0 Memory: 31.16 GiB used: 3.94 GiB (12.6%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages:
pacman: 1850 lib: 548 Client: Unknown Client: garuda-assistant inxi: 3.3.08
