Hi,
I recently installed garuda with gnome.I don't know why sometimes screen stars flickering.
Can someone please help me out. I m using Intel i5 4590 and Intel hd graphics
This description cannot help us understand when. Try to find out more specific circumstances.
Also post info and logs.
Reporting bugs | Garuda Linux wiki
Welcome to Garuda!
To be more specific, it happens mostly during heavy workloads. I've tried some solutions on the arch wiki but they didn't work.
sys specs are
OS: Garuda Linux x86_64
Kernel: 5.10.13-118-tkg-bmq
Packages: 1548 (pacman)
Shell: zsh
Resolution: 1920x1080
gnome-terminal-server
CPU: Intel i5-4590 (4) @ 3.7GHz
Memory: 2053MiB / 3847MiB (53%)
mhwd -l -d gives this
â•â”€sumeet@sumeet in ~ took 8m35s
╰λ mhwd -l -d
> PCI Device: /devices/pci0000:00/0000:00:1c.3/0000:02:00.0 (0200:10ec:8168)
Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
> AVAILABLE:
ATTACHED: PCI
VERSION: 2020.05.22
INFO: RealTek RTL-8168 Gigabit Ethernet driver
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0200
VENDORIDS: 1186 10ec
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:0412)
Display controller Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller
> INSTALLED:
ATTACHED: PCI
VERSION: 2020.12.03
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: video-vesa
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
> AVAILABLE:
ATTACHED: PCI
VERSION: 2020.12.03
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
ATTACHED: PCI
VERSION: 2020.07.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: video-modesetting video-linux
CLASSIDS: 0300
VENDORIDS: *
Warning: no configs for USB devices found!
What have you tried?
You haven’t posted logs.
cat $HOME/.local/share/xorg/Xorg.0.log
cat /var/log/Xorg.0.log
journalctl -b -p3
inxi -Fxxxaz
So, I tried a solution mentioned on the arch wikihttps://wiki.archlinux.org/index.php/intel_graphics
I’ve also posted this issue on Reddit at r/archlinux, those guys didn’t like that I’m using garuda. I’ve included a video file there https://www.reddit.com/r/archlinux/comments/le5zzq/screen_flickering_on_garuda_linux_gnome/?utm_source=share&utm_medium=web2x&context=3
I modified this file as said on the arch wiki to prevent tearing, that didn’t work.
/etc/X11/xorg.conf.d/20-intel.conf
Section “Device”
Identifier “Intel Graphics”
Driver “intel”
Option “TearFree” “true”
EndSection
so these are the logs you asked
>inxi -Fxxxaz
System: Kernel: 5.10.13-118-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=1f10e4cd-73cc-4004-a6db-99618fdc7de3 rw rootflags=subvol=@ quiet splash
rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1 Distro: Garuda Linux
Machine: Type: Desktop System: Dell product: OptiPlex 3020 v: 00 serial: <filter> Chassis: type: 15
Mobo: Dell model: 0WMJ54 v: A01 serial: <filter> UEFI: Dell v: A17 date: 02/04/2018
CPU: Info: Quad Core model: Intel Core i5-4590 bits: 64 type: MCP arch: Haswell family: 6 model-id: 3C (60)
stepping: 3 microcode: 28 L2 cache: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 26367
Speed: 3293 MHz min/max: 800/3700 MHz Core speeds (MHz): 1: 3293 2: 3243 3: 3293 4: 3293
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: Dell driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0412 class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver: loaded: intel display ID: :1
Monitor-1: VGA1 res: 1920x1080 hz: 60 dpi: 92 size: 531x297mm (20.9x11.7") diag: 608mm (24")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 20.3.4 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c class ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:8c20 class ID: 0403
Sound Server: ALSA v: k5.10.13-118-tkg-bmq
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169 v: kernel
port: e000 bus ID: 02:00.0 chip ID: 10ec:8168 class ID: 0200
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u bus ID: 3-9:5 chip ID: 148f:7601
class ID: 0000 serial: <filter>
IF: wlp0s20u9 state: up mac: <filter>
Drives: Local Storage: total: 961.52 GiB used: 57.15 GiB (5.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500312CS size: 465.76 GiB block size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: SC13
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500312CS size: 465.76 GiB block size:
physical: 512 B logical: 512 B speed: 1.5 Gb/s serial: <filter> rev: SC13
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SMI (STMicroelectronics) model: USB DISK size: 30 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 1100
Partition: ID-1: / raw size: 51.63 GiB size: 51.63 GiB (100.00%) used: 15.2 GiB (29.4%) fs: btrfs dev: /dev/sda6
maj-min: 8:6
ID-2: /boot/efi raw size: 600 MiB size: 598.8 MiB (99.80%) used: 8.5 MiB (1.4%) fs: vfat dev: /dev/sda1
maj-min: 8:1
ID-3: /home raw size: 118.81 GiB size: 116.44 GiB (98.01%) used: 41.95 GiB (36.0%) fs: ext4
dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw size: 51.63 GiB size: 51.63 GiB (100.00%) used: 15.2 GiB (29.4%) fs: btrfs
dev: /dev/sda6 maj-min: 8:6
ID-5: /var/tmp raw size: 51.63 GiB size: 51.63 GiB (100.00%) used: 15.2 GiB (29.4%) fs: btrfs
ID-1: swap-1 type: partition size: 20.57 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
maj-min: 8:2
ID-2: swap-2 type: zram size: 961.9 MiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 961.9 MiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 961.9 MiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 961.9 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C
Info: Processes: 249 Uptime: 10m wakeups: 0 Memory: 3.76 GiB used: 2.45 GiB (65.3%) Init: systemd v: 247
Compilers: gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1552 lib: 359 Shell: Bash v: 5.1.4
running in: gnome-terminal inxi: 3.3.00
>journalctl -b -p3
-- Journal begins at Fri 2021-02-05 21:08:10 IST, ends at Sun 2021-02-07 04:29:58 IST. --
Feb 07 04:22:31 sumeet systemd-udevd[296]: host6: /etc/udev/rules.d/50-sata.rules:3 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.0/host6/scsi_host/host6/link_power_management_policy}, ignoring: No such file or directory
Feb 07 04:22:36 sumeet systemd-tmpfiles[492]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
Feb 07 04:22:53 sumeet nmbd[876]: [2021/02/07 04:22:53.895007, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
Feb 07 04:22:53 sumeet nmbd[876]: daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
Feb 07 04:22:54 sumeet smbd[880]: [2021/02/07 04:22:54.546550, 0] ../../lib/util/become_daemon.c:135(daemon_ready)
Feb 07 04:22:54 sumeet smbd[880]: daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
Feb 07 04:22:59 sumeet pipewire[1010]: jack-device 0x560024af0238: can't open client: Connection refused
Feb 07 04:23:07 sumeet gdm-password][1945]: gkr-pam: unable to locate daemon control file
Feb 07 04:23:16 sumeet pipewire[3176]: jack-device 0x557858723958: can't open client: Connection refused
Feb 07 04:23:16 sumeet nmbd[876]: [2021/02/07 04:23:16.932647, 0] ../../source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
Feb 07 04:23:16 sumeet nmbd[876]: *****
Feb 07 04:23:16 sumeet nmbd[876]: Samba name server SUMEET is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.101
Feb 07 04:23:23 sumeet pipewire-media-session[3189]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut
Feb 07 04:23:23 sumeet pipewire-media-session[1031]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut
Feb 07 04:26:50 sumeet pipewire[3176]: alsa-pcm 0x5578586d7098: snd_pcm_status error: Broken pipe
Feb 07 04:27:00 sumeet pipewire[3176]: alsa-pcm 0x5578586d7098: snd_pcm_status error: Broken pipe
Sadly I can't post cat $HOME/.local/share/xorg/Xorg.0.log as your system doesn't allow new users to post more than 5 links and it reads x.org as a link which is more than 5 times in that log.
[ 79.535] (--) Log file renamed from "/home/garuda/.local/share/xorg/Xorg.pid-5950.log" to "/home/garuda/.local/share/xorg/Xorg.0.log"
[ 79.536] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 79.536]
linktoxorg X Server 1.20.10
X Protocol Version 11, Revision 0
[ 79.536] Build Operating System: Linux Arch Linux
[ 79.536] Current Operating System: Linux garuda-gnome 5.10.4-107-tkg-bmq #1 TKG SMP PREEMPT Fri, 01 Jan 2021 17:04:24 +0000 x86_64
[ 79.536] Kernel command line: intel_pstate=passive BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1 misobasedir=garuda misolabel=GARUDA_GNOME_SOARING_ quiet systemd.show_status=1 splash rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
[ 79.536] Build Date: 14 December 2020 12:10:29PM
[ 79.536]
[ 79.536] Current version of pixman: 0.40.0
[ 79.536] Before reporting problems, check http://wiki.linktoxorg
to make sure that you have the latest version.
[ 79.536] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 79.537] (==) Log file: "/home/garuda/.local/share/xorg/Xorg.0.log", Time: Fri Feb 5 23:52:15 2021
[ 79.539] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 79.539] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 79.552] (==) No Layout section. Using the first Screen section.
[ 79.552] (==) No screen section available. Using defaults.
[ 79.552] (**) |-->Screen "Default Screen Section" (0)
[ 79.552] (**) | |-->Monitor "<default monitor>"
[ 79.552] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 79.552] (==) Automatically adding devices
[ 79.552] (==) Automatically enabling devices
[ 79.552] (==) Automatically adding GPU devices
[ 79.552] (==) Automatically binding GPU devices
[ 79.552] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 79.555] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 79.555] Entry deleted from font path.
[ 79.555] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 79.555] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 79.555] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 79.555] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/OTF".
[ 79.555] (Run 'mkfontdir' on "/usr/share/fonts/OTF").
[ 79.556] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 79.556] Entry deleted from font path.
[ 79.556] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 79.556] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 79.556] (==) FontPath set to:
[ 79.556] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 79.556] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 79.556] (II) Module ABI versions:
[ 79.556] linktoxorg ANSI C Emulation: 0.4
[ 79.556] linktoxorg Video Driver: 24.1
[ 79.556] linktoxorg XInput driver : 24.1
[ 79.556] linktoxorg Server Extension : 10.0
[ 79.556] (++) using VT number 2
[ 79.557] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 79.558] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 79.558] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[ 79.560] (--) PCI:*(0@0:2:0) 8086:0412:1028:0612 rev 6, Mem @ 0xf7800000/4194304, 0xe0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 79.560] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 79.560] (II) LoadModule: "glx"
[ 79.561] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 79.577] (II) Module glx: vendor="linktoxorg Foundation"
[ 79.577] compiled for 1.20.10, module version = 1.0.0
[ 79.577] ABI class: linktoxorg Server Extension, version 10.0
[ 79.577] (==) Matched intel as autoconfigured driver 0
[ 79.577] (==) Matched modesetting as autoconfigured driver 1
[ 79.577] (==) Matched fbdev as autoconfigured driver 2
[ 79.577] (==) Matched vesa as autoconfigured driver 3
[ 79.577] (==) Assigned the driver to the xf86ConfigLayout
[ 79.577] (II) LoadModule: "intel"
[ 79.578] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 79.578] (II) Module intel: vendor="linktoxorg Foundation"
[ 79.578] compiled for 1.20.10, module version = 2.99.917
[ 79.578] Module class: linktoxorg Video Driver
[ 79.578] ABI class: linktoxorg Video Driver, version 24.1
[ 79.578] (II) LoadModule: "modesetting"
[ 79.578] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 79.598] (II) Module modesetting: vendor="linktoxorg Foundation"
[ 79.598] compiled for 1.20.10, module version = 1.20.10
[ 79.598] Module class: linktoxorg Video Driver
[ 79.598] ABI class: linktoxorg Video Driver, version 24.1
[ 79.598] (II) LoadModule: "fbdev"
[ 79.598] (WW) Warning, couldn't open module fbdev
[ 79.598] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 79.598] (II) LoadModule: "vesa"
[ 79.598] (WW) Warning, couldn't open module vesa
[ 79.598] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 79.598] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 79.598] (II) intel: Driver for Intel(R) HD Graphics
[ 79.598] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 79.598] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 79.598] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 79.598] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[ 79.598] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20200917
[ 79.598] (II) intel(0): SNA compiled from 2.99.917-914-ga511f22c
[ 79.599] (WW) Falling back to old probe method for modesetting
[ 79.599] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 79.599] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 4600
[ 79.599] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 4 threads
[ 79.599] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 79.599] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 79.599] (==) intel(0): RGB weight 888
[ 79.599] (==) intel(0): Default visual is TrueColor
[ 79.599] (II) intel(0): Output VGA1 has no monitor section
[ 79.599] (II) intel(0): Enabled output VGA1
[ 79.599] (II) intel(0): Output DP1 has no monitor section
[ 79.600] (II) intel(0): Enabled output DP1
[ 79.600] (II) intel(0): Output HDMI1 has no monitor section
[ 79.600] (II) intel(0): Enabled output HDMI1
[ 79.600] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[ 79.600] (II) intel(0): Output VIRTUAL1 has no monitor section
[ 79.600] (II) intel(0): Enabled output VIRTUAL1
[ 79.600] (--) intel(0): Output VGA1 using initial mode 1920x1080 on pipe 0
[ 79.600] (==) intel(0): TearFree disabled
[ 79.600] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[ 79.600] (==) intel(0): DPI set to (96, 96)
[ 79.600] (II) Loading sub module "dri3"
[ 79.600] (II) LoadModule: "dri3"
[ 79.600] (II) Module "dri3" already built-in
[ 79.600] (II) Loading sub module "dri2"
[ 79.600] (II) LoadModule: "dri2"
[ 79.600] (II) Module "dri2" already built-in
[ 79.600] (II) Loading sub module "present"
[ 79.600] (II) LoadModule: "present"
[ 79.600] (II) Module "present" already built-in
[ 79.600] (II) UnloadModule: "modesetting"
[ 79.600] (II) Unloading modesetting
[ 79.600] (II) intel(0): SNA initialized with Haswell (gen7.5, gt2) backend
[ 79.600] (==) intel(0): Backing store enabled
[ 79.600] (==) intel(0): Silken mouse disabled
[ 79.600] (II) intel(0): HW Cursor enabled
[ 79.600] (==) intel(0): DPMS enabled
[ 79.600] (==) intel(0): Display hotplug detection enabled
[ 79.600] (II) intel(0): [DRI2] Setup complete
[ 79.600] (II) intel(0): [DRI2] DRI driver: i965
[ 79.600] (II) intel(0): [DRI2] VDPAU driver: va_gl
[ 79.600] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[ 79.600] (II) intel(0): hardware support for Present enabled
[ 79.600] (II) Initializing extension Generic Event Extension
[ 79.600] (II) Initializing extension SHAPE
[ 79.600] (II) Initializing extension MIT-SHM
[ 79.600] (II) Initializing extension XInputExtension
[ 79.600] (II) Initializing extension XTEST
[ 79.600] (II) Initializing extension BIG-REQUESTS
[ 79.600] (II) Initializing extension SYNC
[ 79.600] (II) Initializing extension XKEYBOARD
[ 79.600] (II) Initializing extension XC-MISC
[ 79.600] (II) Initializing extension SECURITY
[ 79.600] (II) Initializing extension XFIXES
[ 79.600] (II) Initializing extension RENDER
[ 79.600] (II) Initializing extension RANDR
[ 79.601] (II) Initializing extension COMPOSITE
[ 79.601] (II) Initializing extension DAMAGE
[ 79.601] (II) Initializing extension MIT-SCREEN-SAVER
[ 79.601] (II) Initializing extension DOUBLE-BUFFER
[ 79.601] (II) Initializing extension RECORD
[ 79.601] (II) Initializing extension DPMS
[ 79.601] (II) Initializing extension Present
[ 79.601] (II) Initializing extension DRI3
[ 79.601] (II) Initializing extension X-Resource
[ 79.601] (II) Initializing extension XVideo
[ 79.601] (II) Initializing extension XVideo-MotionCompensation
[ 79.601] (II) Initializing extension GLX
[ 80.094] (II) AIGLX: Loaded and initialized i965
[ 80.094] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 80.094] (II) Initializing extension XFree86-VidModeExtension
[ 80.094] (II) Initializing extension XFree86-DGA
[ 80.094] (II) Initializing extension XFree86-DRI
[ 80.094] (II) Initializing extension DRI2
[ 80.100] (II) intel(0): switch to mode [email protected] on VGA1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 80.112] (II) intel(0): Setting screen physical size to 508 x 285
[ 80.174] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 80.174] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 80.174] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 80.174] (**) Power Button: Applying InputClass "system-keyboard"
[ 80.174] (II) LoadModule: "libinput"
[ 80.174] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 80.180] (II) Module libinput: vendor="linktoxorg Foundation"
[ 80.180] compiled for 1.20.8, module version = 0.30.0
[ 80.180] Module class: linktoxorg XInput Driver
[ 80.180] ABI class: linktoxorg XInput driver, version 24.1
[ 80.180] (II) Using input driver 'libinput' for 'Power Button'
[ 80.181] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 16 paused 0
[ 80.181] (**) Power Button: always reports core events
[ 80.181] (**) Option "Device" "/dev/input/event1"
[ 80.181] (**) Option "_source" "server/udev"
[ 80.187] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 80.188] (II) event1 - Power Button: device is a keyboard
[ 80.188] (II) event1 - Power Button: device removed
[ 80.188] (**) Option "config_info"
"udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 80.188] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 80.188] (**) Option "xkb_model" "pc105+inet"
[ 80.188] (**) Option "xkb_layout" "us"
[ 80.188] (WW) Option "xkb_variant" requires a string value
[ 80.188] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 80.205] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 80.205] (II) event1 - Power Button: device is a keyboard
[ 80.205] (II) config/udev: Adding input device Video Bus (/dev/input/event2)
[ 80.205] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 80.205] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 80.205] (**) Video Bus: Applying InputClass "system-keyboard"
[ 80.205] (II) Using input driver 'libinput' for 'Video Bus'
[ 80.206] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 19 paused 0
[ 80.206] (**) Video Bus: always reports core events
[ 80.206] (**) Option "Device" "/dev/input/event2"
[ 80.206] (**) Option "_source" "server/udev"
[ 80.207] (II) event2 - Video Bus: is tagged by udev as: Keyboard
[ 80.207] (II) event2 - Video Bus: device is a keyboard
[ 80.207] (II) event2 - Video Bus: device removed
[ 80.207] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input2/event2"
[ 80.207] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 80.207] (**) Option "xkb_model" "pc105+inet"
[ 80.207] (**) Option "xkb_layout" "us"
[ 80.207] (WW) Option "xkb_variant" requires a string value
[ 80.207] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 80.208] (II) event2 - Video Bus: is tagged by udev as: Keyboard
[ 80.208] (II) event2 - Video Bus: device is a keyboard
[ 80.208] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 80.208] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 80.208] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 80.208] (**) Power Button: Applying InputClass "system-keyboard"
[ 80.208] (II) Using input driver 'libinput' for 'Power Button'
[ 80.209] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 20 paused 0
[ 80.209] (**) Power Button: always reports core events
[ 80.209] (**) Option "Device" "/dev/input/event0"
[ 80.209] (**) Option "_source" "server/udev"
[ 80.209] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 80.209] (II) event0 - Power Button: device is a keyboard
[ 80.209] (II) event0 - Power Button: device removed
[ 80.209] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 80.209] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 80.209] (**) Option "xkb_model" "pc105+inet"
[ 80.209] (**) Option "xkb_layout" "us"
[ 80.209] (WW) Option "xkb_variant" requires a string value
[ 80.209] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 80.210] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 80.210] (II) event0 - Power Button: device is a keyboard
[ 80.211] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event12)
[ 80.211] (II) No input driver specified, ignoring this device.
[ 80.211] (II) This device may have been added with another device file.
[ 80.211] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event13)
[ 80.211] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event14)
[ 80.212] (II) config/udev: Adding input device SONiX USB DEVICE (/dev/input/event3)
[ 80.212] (**) SONiX USB DEVICE: Applying InputClass "evdev keyboard catchall"
[ 80.212] (**) SONiX USB DEVICE: Applying InputClass "libinput keyboard catchall"
[ 80.212] (**) SONiX USB DEVICE: Applying InputClass "system-keyboard"
[ 80.212] (II) Using input driver 'libinput' for 'SONiX USB DEVICE'
[ 80.212] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 21 paused 0
[ 80.212] (**) SONiX USB DEVICE: always reports core events
[ 80.212] (**) Option "Device" "/dev/input/event3"
[ 80.212] (**) Option "_source" "server/udev"
[ 80.214] (II) event3 - SONiX USB DEVICE: is tagged by udev as: Keyboard
[ 80.214] (II) event3 - SONiX USB DEVICE: device is a keyboard
[ 80.214] (II) event3 - SONiX USB DEVICE: device removed
[ 80.214] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.0/0003:0C45:6536.0001/input/input3/event3"
[ 80.214] (II) XINPUT: Adding extended input device "SONiX USB DEVICE" (type: KEYBOARD, id 9)
[ 80.214] (**) Option "xkb_model" "pc105+inet"
[ 80.214] (**) Option "xkb_layout" "us"
[ 80.214] (WW) Option "xkb_variant" requires a string value
[ 80.214] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 80.215] (II) event3 - SONiX USB DEVICE: is tagged by udev as: Keyboard
[ 80.215] (II) event3 - SONiX USB DEVICE: device is a keyboard
[ 80.216] (II) config/udev: Adding input device SONiX USB DEVICE Keyboard (/dev/input/event4)
[ 80.216] (**) SONiX USB DEVICE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 80.216] (**) SONiX USB DEVICE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 80.216] (**) SONiX USB DEVICE Keyboard: Applying InputClass "system-keyboard"
[ 80.216] (II) Using input driver 'libinput' for 'SONiX USB DEVICE Keyboard'
[ 80.216] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 22 paused 0
[ 80.216] (**) SONiX USB DEVICE Keyboard: always reports core events
[ 80.216] (**) Option "Device" "/dev/input/event4"
[ 80.216] (**) Option "_source" "server/udev"
[ 80.217] (II) event4 - SONiX USB DEVICE Keyboard: is tagged by udev as: Keyboard
[ 80.217] (II) event4 - SONiX USB DEVICE Keyboard: device is a keyboard
[ 80.217] (II) event4 - SONiX USB DEVICE Keyboard: device removed
[ 80.217] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.1/0003:0C45:6536.0002/input/input4/event4"
[ 80.217] (II) XINPUT: Adding extended input device "SONiX USB DEVICE Keyboard" (type: KEYBOARD, id 10)
[ 80.217] (**) Option "xkb_model" "pc105+inet"
[ 80.217] (**) Option "xkb_layout" "us"
[ 80.218] (WW) Option "xkb_variant" requires a string value
[ 80.218] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 80.219] (II) event4 - SONiX USB DEVICE Keyboard: is tagged by udev as: Keyboard
[ 80.219] (II) event4 - SONiX USB DEVICE Keyboard: device is a keyboard
[ 80.219] (II) config/udev: Adding input device SONiX USB DEVICE Wireless Radio Control (/dev/input/event5)
[ 80.219] (**) SONiX USB DEVICE Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
[ 80.219] (**) SONiX USB DEVICE Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[ 80.219] (**) SONiX USB DEVICE Wireless Radio Control: Applying InputClass "system-keyboard"
[ 80.219] (II) Using input driver 'libinput' for 'SONiX USB DEVICE Wireless Radio Control'
[ 80.220] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 23 paused 0
[ 80.220] (**) SONiX USB DEVICE Wireless Radio Control: always reports core events
[ 80.220] (**) Option "Device" "/dev/input/event5"
[ 80.220] (**) Option "_source" "server/udev"
[ 80.221] (II) event5 - SONiX USB DEVICE Wireless Radio Control: is tagged by udev as: Keyboard
[ 80.221] (II) event5 - SONiX USB DEVICE Wireless Radio Control: device is a keyboard
[ 80.221] (II) event5 - SONiX USB DEVICE Wireless Radio Control: device removed
[ 80.221] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.1/0003:0C45:6536.0002/input/input5/event5"
[ 80.221] (II) XINPUT: Adding extended input device "SONiX USB DEVICE Wireless Radio Control" (type: KEYBOARD, id 11)
[ 80.221] (**) Option "xkb_model" "pc105+inet"
[ 80.221] (**) Option "xkb_layout" "us"
[ 80.221] (WW) Option "xkb_variant" requires a string value
[ 80.221] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 80.222] (II) event5 - SONiX USB DEVICE Wireless Radio Control: is tagged by udev as: Keyboard
[ 80.222] (II) event5 - SONiX USB DEVICE Wireless Radio Control: device is a keyboard
[ 80.223] (II) config/udev: Adding input device SONiX USB DEVICE Consumer Control (/dev/input/event6)
[ 80.223] (**) SONiX USB DEVICE Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 80.223] (**) SONiX USB DEVICE Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 80.223] (**) SONiX USB DEVICE Consumer Control: Applying InputClass "system-keyboard"
[ 80.223] (II) Using input driver 'libinput' for 'SONiX USB DEVICE Consumer Control'
[ 80.223] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 24 paused 0
[ 80.223] (**) SONiX USB DEVICE Consumer Control: always reports core events
[ 80.223] (**) Option "Device" "/dev/input/event6"
[ 80.223] (**) Option "_source" "server/udev"
[ 80.225] (II) event6 - SONiX USB DEVICE Consumer Control: is tagged by udev as: Keyboard
[ 80.225] (II) event6 - SONiX USB DEVICE Consumer Control: device is a keyboard
[ 80.225] (II) event6 - SONiX USB DEVICE Consumer Control: device removed
[ 80.225] (II) libinput: SONiX USB DEVICE Consumer Control: needs a virtual subdevice
[ 80.225] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.1/0003:0C45:6536.0002/input/input6/event6"
[ 80.225] (II) XINPUT: Adding extended input device "SONiX USB DEVICE Consumer Control" (type: MOUSE, id 12)
[ 80.225] (**) Option "AccelerationScheme" "none"
[ 80.225] (**) SONiX USB DEVICE Consumer Control: (accel) selected scheme none/0
[ 80.225] (**) SONiX USB DEVICE Consumer Control: (accel) acceleration factor: 2.000
[ 80.225] (**) SONiX USB DEVICE Consumer Control: (accel) acceleration threshold: 4
[ 80.226] (II) event6 - SONiX USB DEVICE Consumer Control: is tagged by udev as: Keyboard
[ 80.226] (II) event6 - SONiX USB DEVICE Consumer Control: device is a keyboard
[ 80.226] (II) config/udev: Adding input device SONiX USB DEVICE (/dev/input/event7)
[ 80.226] (II) No input driver specified, ignoring this device.
[ 80.226] (II) This device may have been added with another device file.
[ 80.227] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/event8)
[ 80.227] (**) USB OPTICAL MOUSE : Applying InputClass "evdev pointer catchall"
[ 80.227] (**) USB OPTICAL MOUSE : Applying InputClass "libinput pointer catchall"
[ 80.227] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE '
[ 80.281] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 25 paused 0
[ 80.281] (**) USB OPTICAL MOUSE : always reports core events
[ 80.281] (**) Option "Device" "/dev/input/event8"
[ 80.281] (**) Option "_source" "server/udev"
[ 80.282] (II) event8 - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[ 80.282] (II) event8 - USB OPTICAL MOUSE : device is a pointer
[ 80.282] (II) event8 - USB OPTICAL MOUSE : device removed
[ 80.282] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-5/2-5:1.0/0003:18F8:0F97.0003/input/input8/event8"
[ 80.282] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE " (type: MOUSE, id 13)
[ 80.282] (**) Option "AccelerationScheme" "none"
[ 80.282] (**) USB OPTICAL MOUSE : (accel) selected scheme none/0
[ 80.282] (**) USB OPTICAL MOUSE : (accel) acceleration factor: 2.000
[ 80.282] (**) USB OPTICAL MOUSE : (accel) acceleration threshold: 4
[ 80.283] (II) event8 - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[ 80.283] (II) event8 - USB OPTICAL MOUSE : device is a pointer
[ 80.284] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/mouse0)
[ 80.284] (II) No input driver specified, ignoring this device.
[ 80.284] (II) This device may have been added with another device file.
[ 80.284] (II) config/udev: Adding input device USB OPTICAL MOUSE Consumer Control (/dev/input/event10)
[ 80.284] (**) USB OPTICAL MOUSE Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 80.285] (**) USB OPTICAL MOUSE Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 80.285] (**) USB OPTICAL MOUSE Consumer Control: Applying InputClass "system-keyboard"
[ 80.285] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Consumer Control'
[ 80.285] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 26 paused 0
[ 80.285] (**) USB OPTICAL MOUSE Consumer Control: always reports core events
[ 80.285] (**) Option "Device" "/dev/input/event10"
[ 80.285] (**) Option "_source" "server/udev"
[ 80.286] (II) event10 - USB OPTICAL MOUSE Consumer Control: is tagged by udev as: Keyboard
[ 80.286] (II) event10 - USB OPTICAL MOUSE Consumer Control: device is a keyboard
[ 80.286] (II) event10 - USB OPTICAL MOUSE Consumer Control: device removed
[ 80.286] (II) libinput: USB OPTICAL MOUSE Consumer Control: needs a virtual subdevice
[ 80.286] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-5/2-5:1.1/0003:18F8:0F97.0004/input/input10/event10"
[ 80.286] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE Consumer Control" (type: MOUSE, id 14)
[ 80.286] (**) Option "AccelerationScheme" "none"
[ 80.286] (**) USB OPTICAL MOUSE Consumer Control: (accel) selected scheme none/0
[ 80.286] (**) USB OPTICAL MOUSE Consumer Control: (accel) acceleration factor: 2.000
[ 80.286] (**) USB OPTICAL MOUSE Consumer Control: (accel) acceleration threshold: 4
[ 80.287] (II) event10 - USB OPTICAL MOUSE Consumer Control: is tagged by udev as: Keyboard
[ 80.288] (II) event10 - USB OPTICAL MOUSE Consumer Control: device is a keyboard
[ 80.288] (II) config/udev: Adding input device USB OPTICAL MOUSE Keyboard (/dev/input/event9)
[ 80.288] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 80.288] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 80.288] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "system-keyboard"
[ 80.288] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Keyboard'
[ 80.289] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 27 paused 0
[ 80.289] (**) USB OPTICAL MOUSE Keyboard: always reports core events
[ 80.289] (**) Option "Device" "/dev/input/event9"
[ 80.289] (**) Option "_source" "server/udev"
[ 80.290] (II) event9 - USB OPTICAL MOUSE Keyboard: is tagged by udev as: Keyboard
[ 80.290] (II) event9 - USB OPTICAL MOUSE Keyboard: device is a keyboard
[ 80.290] (II) event9 - USB OPTICAL MOUSE Keyboard: device removed
[ 80.290] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-5/2-5:1.1/0003:18F8:0F97.0004/input/input9/event9"
[ 80.290] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE Keyboard" (type: KEYBOARD, id 15)
[ 80.290] (**) Option "xkb_model" "pc105+inet"
[ 80.290] (**) Option "xkb_layout" "us"
[ 80.290] (WW) Option "xkb_variant" requires a string value
[ 80.290] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 80.291] (II) event9 - USB OPTICAL MOUSE Keyboard: is tagged by udev as: Keyboard
[ 80.291] (II) event9 - USB OPTICAL MOUSE Keyboard: device is a keyboard
[ 80.292] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event15)
[ 80.292] (II) No input driver specified, ignoring this device.
[ 80.292] (II) This device may have been added with another device file.
[ 80.292] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event16)
[ 80.292] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event17)
[ 80.292] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event18)
[ 80.293] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event11)
[ 80.293] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 80.293] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 80.293] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 80.293] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 80.293] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 28 paused 0
[ 80.293] (**) Dell WMI hotkeys: always reports core events
[ 80.293] (**) Option "Device" "/dev/input/event11"
[ 80.293] (**) Option "_source" "server/udev"
[ 80.294] (II) event11 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 80.294] (II) event11 - Dell WMI hotkeys: device is a keyboard
[ 80.294] (II) event11 - Dell WMI hotkeys: device removed
[ 80.294] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input12/event11"
[ 80.294] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 16)
[ 80.294] (**) Option "xkb_model" "pc105+inet"
[ 80.294] (**) Option "xkb_layout" "us"
[ 80.294] (WW) Option "xkb_variant" requires a string value
[ 80.294] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 80.295] (II) event11 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 80.296] (II) event11 - Dell WMI hotkeys: device is a keyboard
[ 80.312] (**) SONiX USB DEVICE Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 80.312] (**) SONiX USB DEVICE Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 80.312] (**) SONiX USB DEVICE Consumer Control: Applying InputClass "system-keyboard"
[ 80.312] (II) Using input driver 'libinput' for 'SONiX USB DEVICE Consumer Control'
[ 80.312] (II) systemd-logind: returning pre-existing fd for /dev/input/event6 13:70
[ 80.312] (**) SONiX USB DEVICE Consumer Control: always reports core events
[ 80.312] (**) Option "Device" "/dev/input/event6"
[ 80.312] (**) Option "_source" "_driver/libinput"
[ 80.312] (II) libinput: SONiX USB DEVICE Consumer Control: is a virtual subdevice
[ 80.312] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.1/0003:0C45:6536.0002/input/input6/event6"
[ 80.312] (II) XINPUT: Adding extended input device "SONiX USB DEVICE Consumer Control" (type: KEYBOARD, id 17)
[ 80.312] (**) Option "xkb_model" "pc105+inet"
[ 80.312] (**) Option "xkb_layout" "us"
[ 80.312] (WW) Option "xkb_variant" requires a string value
[ 80.312] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 80.313] (**) USB OPTICAL MOUSE Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 80.313] (**) USB OPTICAL MOUSE Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 80.313] (**) USB OPTICAL MOUSE Consumer Control: Applying InputClass "system-keyboard"
[ 80.313] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Consumer Control'
[ 80.313] (II) systemd-logind: returning pre-existing fd for /dev/input/event10 13:74
[ 80.313] (**) USB OPTICAL MOUSE Consumer Control: always reports core events
[ 80.313] (**) Option "Device" "/dev/input/event10"
[ 80.313] (**) Option "_source" "_driver/libinput"
[ 80.313] (II) libinput: USB OPTICAL MOUSE Consumer Control: is a virtual subdevice
[ 80.313] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-5
[ 80.313] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE Consumer Control" (type: KEYBOARD, id 18)
[ 80.313] (**) Option "xkb_model" "pc105+inet"
[ 80.313] (**) Option "xkb_layout" "us"
[ 80.313] (WW) Option "xkb_variant" requires a string value
[ 80.313] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
@Facon4
Read wiki "Reporting bugs" please, its a pain for cell and tablet user if you do not format the terminal output. Greetings SGS
That is only understandable that they would be upset with you. Why would you post on the Arch sub-reddit when using Garuda, There is a Garuda sub-reddit there if you want to post on Reddit. Please never post Garuda issues on other OS support sites. This will give Garuda a very poor reputation with other distro’s if our users are constantly doing this. Please stop this practice now, and whatever you do please never post a Garuda issue on the Arch Linux forum.
I understand. I'll keep that in mind. I thought that garuda is based on so someone might be able to help me out as it's based on the arch.
Are you getting tearing or flickering?
It's flickering.
This is not the correct log. User garuda?? Time of log??
Post the correct log at garuda private bin.
Which one, sorry but I use common home partition so that might have been the case. Which one is not the right one.
As posted
Check the contents to see the correct time.
There is not a sing xorg log in /var/log
ls /var/log/ -la
drwxr-xr-x 1 root root 396 Feb 8 03:00 .
drwxr-xr-x 1 root root 140 Feb 7 11:52 …
drwx------ 1 root root 0 Nov 11 12:25 audit
-rw-r–r-- 1 root root 2510252 Feb 6 01:48 auto-cpufreq.log
-rw------- 1 root root 1120 Feb 8 03:00 boot.log
-rw------- 1 root root 85807 Feb 8 03:00 boot.log.1
-rw------- 1 root root 216611 Feb 7 00:00 boot.log.2
-rw-rw---- 1 root utmp 384 Feb 6 23:58 btmp
-rw-r–r-- 1 root root 3455 Feb 5 20:58 Calamares.log
drwxr-xr-x 1 root root 20 Feb 6 01:50 cups
drwx–x–x 1 root gdm 0 Feb 5 21:08 gdm
-rw-r–r-- 1 root root 203 Feb 5 22:40 grub-fix-initrd-generation.log
drwxr-xr-x 1 root root 0 Apr 18 2020 gssproxy
drwxr-xr-x 1 root root 16 Feb 6 01:50 ipp-usb
drwxr-sr-x+ 1 root systemd-journal 76 Feb 5 21:08 journal
-rw-rw-r-- 1 root utmp 292876 Feb 8 03:09 lastlog
drwxr-xr-x 1 root root 0 Sep 3 04:00 old
-rw-r–r-- 1 root root 618179 Feb 7 08:26 pacman.log
-rw------- 1 root root 110 Feb 6 07:16 preload.log
drwx------ 1 root root 0 Jan 7 14:10 private
drwxr-xr-x 1 root root 176 Feb 7 00:00 samba
drwxr-xr-x 1 root root 0 Nov 28 04:10 speech-dispatcher
drwxr-xr-x 1 root root 6564 Feb 7 02:06 timeshift
-rw-rw-r-- 1 root utmp 123264 Feb 8 03:09 wtmp
.local/share/xorg/
-rw-r–r-- 1 facon4 facon4 32809 Feb 6 05:22 Xorg.0.log
-rw-r–r-- 1 facon4 facon4 47350 Feb 8 03:21 Xorg.1.log
-rw-r–r-- 1 facon4 facon4 42311 Feb 7 11:54 Xorg.1.log.old
I’ve sent you the first Xorg.0.log.
I've posted both the logs on telegram.
This looks like the correct log.
I cannot view the telegram logs.
Post in https://bin.garudalinux.org/
Sure, I've posted both.
https://bin.garudalinux.org/?7e8ef9db152c3867#9AQaNQLRCpj6t2kKYAdz4EyfrUrzRVJmY2nEQViCcPB7
Try setting some options for intel. Create a file:
with contents
Section "Device"
Identifier "Intel Graphics"
Driver "intel"
Option "TripleBuffer" "true"
Option "TearFree" "true"
EndSection
Reboot to check.
If there is no real improvement, change TearFree to false and recheck.
Possibly this happens because of not enough memory, in conjunction to other factors. But it's all try-and-fail effort.
You may read for Gnome and Intel for more ideas.
