Basicly what the title says. Any ideas?
Kernel: 5.15.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=77d7c93f-9703-4f0a-9d5f-39d198e6728b rw rootflags=subvol=@
Desktop: GNOME 41.2 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
Type: Convertible System: HP product: HP ProBook x360 435 G7 v: N/A
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: HP model: 8735 v: KBC Version 09.24.00 serial: <superuser required>
UEFI: HP v: S80 Ver. 01.04.02 date: 01/18/2021
ID-1: BAT0 charge: 33.8 Wh (96.3%) condition: 35.1/45.0 Wh (78.0%)
volts: 12.6 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: N/A cycles: 57
Device-1: hid-0018:04F3:2AD3.0001-battery model: ELAN2513:00 04F3:2AD3
serial: N/A charge: N/A status: N/A
Info: model: AMD Ryzen 3 4300U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1413 high: 1474 min/max: 1400/2700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1396 2: 1397
3: 1388 4: 1474 bogomips: 21560
IBRS_FW, STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: Quanta HP HD Camera type: USB driver: uvcvideo bus-ID: 3-3:2
chip-ID: 0408:5375 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: gnome-shell driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :1 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 166 size: 294x165mm (11.6x6.5")
diag: 337mm (13.3")
Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.15.10-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:2723 class-ID: 0280
bus-ID: 1-3:2 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 238.47 GiB used: 11.96 GiB (5.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNV256G KIOXIA size: 238.47 GiB block-size: physical: 512 B
rev: HP00AE00 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 30 GiB size: 30 GiB (100.00%) used: 11.74 GiB (39.1%)
used: 76.1 MiB (14.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 191.98 GiB size: 191.98 GiB (100.00%)
used: 147 MiB (0.1%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 30 GiB size: 30 GiB (100.00%)
used: 11.74 GiB (39.1%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 30 GiB size: 30 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.23 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C mobo: 0.0 C gpu: amdgpu temp: 43.0 C
Processes: 269 Uptime: 5m wakeups: 3 Memory: 7.23 GiB
used: 2.24 GiB (31.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1064 lib: 297 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: gnome-terminal inxi: 3.3.11
