╭─jan@master in ~
╰─λ garuda-inxi
Kernel: 5.19.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=f3a4dd0e-3ba0-4998-a2ee-71dee30c18e4 rw rootflags=subvol=@
Type: Laptop System: Hewlett-Packard product: HP EliteBook 8470p
v: A1029C1103 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 179B v: KBC Version 42.38
serial: <superuser required> BIOS: Hewlett-Packard v: 68ICF Ver. F.73
date: 08/07/2018
ID-1: BAT0 charge: 40.0 Wh (96.9%) condition: 41.3/41.3 Wh (100.0%)
volts: 12.3 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
Info: model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v3 built: 2012-15 process: Intel 22nm family: 6
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1787 high: 3300 min/max: 1200/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1454 2: 1200 3: 3300
4: 1197 bogomips: 20751
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13
ports: active: VGA-1 off: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1,
HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Chicony Integrated HP HD Webcam type: USB driver: uvcvideo
bus-ID: 1-1.3:4 chip-ID: 04f2:b230 class-ID: 0e02 serial: <filter>
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: LVDS-1 note: disabled model: Samsung 0x4642 built: 2012
res: N/A dpi: 112 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: 1366x768
Monitor-2: VGA-1 pos: primary model: BenQ GL2450 serial: <filter>
built: 2014 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x298mm (20.91x11.73") diag: 609mm (24") ratio: 16:9 modes:
OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa
22.1.7 direct render: Yes
Sound Server-1: ALSA v: k5.19.13-zen1-1-zen running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: 4060 bus-ID: 00:19.0 chip-ID: 8086:1502
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 24:00.0
chip-ID: 8086:0082 class-ID: 0280
Local Storage: total: 238.47 GiB used: 9.5 GiB (4.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 256GB
type: SSD serial: <filter> rev: 4B6Q scheme: MBR
ID-1: / raw-size: 238.47 GiB size: 238.47 GiB (100.00%) used: 9.5 GiB
(4.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 238.47 GiB size: 238.47 GiB (100.00%) used: 9.5 GiB
ID-3: /var/log raw-size: 238.47 GiB size: 238.47 GiB (100.00%) used: 9.5
GiB (4.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/tmp raw-size: 238.47 GiB size: 238.47 GiB (100.00%) used: 9.5
ID-1: swap-1 type: zram size: 7.63 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 213 Uptime: 28m wakeups: 1 Memory: 7.63 GiB used: 3.27 GiB
(42.8%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1217 libs: 340
tools: octopi,pamac,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-10-04
Last full system update: 2022-10-04
Meine Erwartungen an Garuda waren eigentlich nach diversen Videos sehr hoch, die Installation lief super und nach den ersten BOOT sah auch alles gut aus.
Leider musste ich dann Feststellen das nach einem erneuten REBOOT nur noch ein schwarzer Hintergrund da war. OK , Hintergrund auf Bild eingestellt und kann damit auch leben, aber so ganz richtig ist das nicht. Der Geblurte Hintergrund bei offenen Fenstern hatte schon was
