Sbc-xq not working
Hi, i've been trying to enable sbc-xq without any luck, i have uncommented bluez5.enable-sbc-xq = truefrom usr/share/pipewire/media-session.d/bluez-monitor.conf and created a new conf in /etc/pipewire/media-session.d/ but there is no option for sbc-xq in audio settings or pavucontrol.
PC: Lenovo Y50-70(860m version)
Distro/version: Garuda Linux, newest
Kernel/version: zen1, 5.13.9
pipewire version:
Compiled with libpipewire 0.3.33
Linked with libpipewire 0.3.33
There are 13 desktop envirements, all new, but it changed often, so nobody know what you use until you post your inxi -Faz ike in the template explained.
Welcome
to the Garuda Linux forum :slight_smile:
thank you for answering and sorry for forgetting that, here:
System:    Kernel: 5.13.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=42a17a9c-9b32-4bef-81a1-abfcedc86728
rw [email protected] quiet
cryptdevice=UUID=6b73de83-eecc-4a3c-ab3a-39807a2cedf0:luks-6b73de83-eecc-4a3c-ab3a-39807a2cedf0
root=/dev/mapper/luks-6b73de83-eecc-4a3c-ab3a-39807a2cedf0 splash rd.udev.log_priority=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Laptop System: LENOVO product: 20378 v: Lenovo Y50-70 serial: <filter> Chassis: type: 10
Mobo: LENOVO model: Lenovo Y50-70 v: 31900058WIN serial: <filter> UEFI: LENOVO
v: 9ECN36WW(V2.00) date: 01/12/2015
Battery:   ID-1: BAT1 charge: 41.9 Wh (100.0%) condition: 41.9/54.8 Wh (76.5%) volts: 8.1 min: 7.4
model: LENOVO PABAS0241231 type: Li-ion serial: <filter> status: Full
CPU:       Info: Dual Core model: Intel Core i5-4210H bits: 64 type: MT MCP arch: Haswell family: 6
model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 23146
Speed: 2894 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 2894 2: 2908 3: 2894 4: 2894
Graphics:  Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 860M] vendor: Lenovo driver: nvidia v: 470.57.02
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1392 class-ID: 0302
Device-3: Acer Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 3-6:3 chip-ID: 5986:055e
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: NVIDIA GeForce GTX 860M/PCIe/SSE2 v: 4.6.0 NVIDIA 470.57.02
direct render: Yes
Audio:     Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.13.9-zen1-1-zen running: yes
Network:   Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel port: 4000 bus-ID: 08:00.0
chip-ID: 8086:08b4 class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: 3000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 3-7:4
chip-ID: 8087:07dc class-ID: e001
Drives:    Local Storage: total: 238.47 GiB used: 46.89 GiB (19.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: LITE-ON IT model: LCS-256M6S size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 201 scheme: GPT
Partition: ID-1: / raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 46.89 GiB (19.7%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-6b73de83-eecc-4a3c-ab3a-39807a2cedf0
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 706 KiB (0.3%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 46.89 GiB (19.7%) fs: btrfs
ID-4: /var/log raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 46.89 GiB (19.7%)
fs: btrfs dev: /dev/dm-0 maj-min: 254:0 mapped: luks-6b73de83-eecc-4a3c-ab3a-39807a2cedf0
ID-5: /var/tmp raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 46.89 GiB (19.7%)
ID-1: swap-1 type: zram size: 11.6 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 53.0 C mobo: N/A gpu: nvidia temp: 42 C
Info:      Processes: 230 Uptime: 2h 1m wakeups: 1 Memory: 11.6 GiB used: 2.98 GiB (25.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1357 lib: 418
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
nevermind, i had one lil typo ruining it, thank you for helping and good job on this distro, its amazing.
