Same problem i am getting right now
If you have installed some other sound server first uninstall it and then:
reinstall pipwire using these steps:
- Remove all the configuration files in
/etc/pipewire
sudo mv /etc/pipewire /tmp
- Reinstall pipewire with:
sudo pacman -S pipewire-support
- enable its services
systemctl --user enable --now pipewire.socket pipewire-pulse.socket wireplumber.service
- reboot
if it doesn't help or you are stuck open a new forum thread and provide your inxi
Since I moved your post, you miss the template they get on a new thread, here it is.
Hello Garuda users.
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
Hi, I changed the name of the topic to be more descriptive of what it's about - this was done based on the topic this was split from (Unable to play video on any browser), as well as your previous audio issues thread.
All the best with getting this problem sorted ^^ the more information you provide, the quicker this can get resolved.
Kernel: 6.3.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=231adbe5-cbff-46a0-a133-7b383848afc1 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A17 FA706ICB_FA706ICB
Mobo: ASUSTeK model: FA706ICB v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FA706ICB.307 date: 12/28/2022
ID-1: BAT1 charge: 46.8 Wh (53.0%) condition: 88.3/90.2 Wh (97.9%)
volts: 15.2 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600106
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2806 high: 2900 min/max: 1400/4299 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2900 2: 2900
3: 2900 4: 2900 5: 2900 6: 2900 7: 2900 8: 2900 9: 2900 10: 2900 11: 1397
12: 2900 13: 2900 14: 2900 15: 2900 16: 2900 bogomips: 92628
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 530.xx+ status: current (as of 2023-05)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:25a2
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
temp: 43.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 322e:202c
class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: amdgpu,modesetting,nouveau
alternate: fbdev,nv,vesa dri: radeonsi,nouveau gpu: amdgpu display-ID: :0
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0a11 built: 2021
res: 1920x1080 hz: 144 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.3.1-zen2-1-zen) direct-render: Yes
bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.3.1-zen2-1-zen status: kernel-api with: aoss
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 13d3:3563
Local Storage: total: 476.94 GiB used: 11.92 GiB (2.5%)
fw-rev: FXM7201Q temp: 43.9 C scheme: GPT
ID-1: / raw-size: 94 GiB size: 94 GiB (100.00%) used: 11.89 GiB (12.6%)
used: 30 MiB (11.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 94 GiB size: 94 GiB (100.00%)
used: 11.89 GiB (12.6%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 94 GiB size: 94 GiB (100.00%)
ID-5: /var/tmp raw-size: 94 GiB size: 94 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.18 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 6 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 51.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (RPM): cpu: 3100
Processes: 333 Uptime: 6m wakeups: 164 Memory: available: 7.18 GiB
used: 2.2 GiB (30.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: 3448 pm: pacman pkgs: 1724
libs: 519 tools: octopi,paru pm: rpm pkgs: N/A note: see --rpm tools: dnf
inxi: 3.3.27
System install date: 2023-05-04
Last full system update: 2023-05-13
Perhaps ‘rm’ was what was meant?
Where is rm?
Instead of the 'mv' command. 'rm' will remove that tmp directory. 'mv' means to move, and he's missing a needed operand (a destination), that's why I guessing 'rm'
Ok let me try
Please, no pictures from terminal.
I edit your garuda-inxi text, please use three ~ in first and last line, like
Terminal text
then others can easily expand or copy the text.
Ok, sorry for that , am new here
Then is that command needed at all? I'm busy, so I'm sorry but I have to go for now.
I don't know may be there are more ways to fix this....i need some one u instruct me.
And now my audio is gone again...
I don't want to change to switch to another linux ..plz help me fix this...am loving garuda ..its ui is just outstanding and this makes me stuck with it.
Thats not the standard install.
Follow exactly the steps Video playback problem in youtube and everywhere - #2 by NaN
Check your file system, if pipewire exist in /etc/pipewire/
ls -la /etc/pipewire/
"/etc/pipewire/": No such file or directory (os error 2)
Fine, the files are in /tmp I guess. Now
BTW, where come “oss-emulator” from?
- I installed the pipewire
3.After third command
Faild to enable unit : unit file pipewire-plus.socket does not exists.
