DESKTOP
Kernel: 5.18.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=256c59f5-44bf-4897-ae8c-6a4455a54263 rw [email protected]
loglevel=3 ibt=off
Mobo: ASUSTeK model: ROG CROSSHAIR VII HERO v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4603
date: 09/13/2021
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ gen: 2
built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8 stepping: 2
microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3137 high: 4247 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2773 2: 2410
3: 2408 4: 4133 5: 2494 6: 4201 7: 2811 8: 2545 9: 2767 10: 4157 11: 2709
12: 4247 bogomips: 86403
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Gigabyte driver: nvidia
v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Maxwell process: TSMC 28nm
built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 0a:00.0 chip-ID: 10de:13c2 class-ID: 0300
Screen-1: 0 s-res: 6880x1440 s-dpi: 109 s-size: 1603x342mm (63.11x13.46")
s-diag: 1639mm (64.53")
Monitor-1: DP-0 pos: primary,left res: 3440x1440 hz: 60 dpi: 109
size: 800x335mm (31.5x13.19") diag: 867mm (34.15") modes: N/A
Monitor-2: DP-4 pos: right res: 3440x1440 hz: 60 dpi: 109
OpenGL: renderer: NVIDIA GeForce GTX 970/PCIe/SSE2
v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
Device-1: NVIDIA GM204 High Definition Audio vendor: Gigabyte
link-max: lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:0fbb class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0c:00.3
Sound Server-1: ALSA v: k5.18.3-zen1-1-zen running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:095a class-ID: 0280
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
bus-ID: 1-11:3 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 5.92 TiB used: 2.56 TiB (43.2%)
rev: 2B2QEXM7 temp: 32.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: E1.3
model: WD15EADS-00P8B0 size: 1.36 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 0A01
scheme: MBR
model: WD40EZRZ-75GXCB0 size: 3.64 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 19.09 GiB (31.8%)
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 50.9 MiB (10.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 328.24 GiB size: 328.24 GiB (100.00%)
used: 96.46 GiB (29.4%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 60 GiB size: 60 GiB (100.00%)
used: 19.09 GiB (31.8%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 60 GiB size: 60 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.52 GiB used: 1.8 MiB (0.0%)
ID-2: swap-2 type: partition size: 7.03 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 42.0 C mobo: 25.0 C gpu: nvidia temp: 35 C
Fan Speeds (RPM): cpu: 604 case-1: 0 case-2: 0 case-3: 0 gpu: nvidia
fan: 51%
Power: 12v: 11.94 5v: N/A 3.3v: N/A vbat: 3.14
Processes: 425 Uptime: 3h 53m wakeups: 1 Memory: 15.52 GiB
used: 5.98 GiB (38.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1443 lib: 345
Shell: Zsh v: 5.9 running-in: tilix inxi: 3.3.17
Garuda (2.6.3-2):
System install date: 2022-05-26
Last full system update: 2022-06-13 ↻
╭─rusty ~
╰─» sudo garuda-inxi
[sudo] password for rusty:
loglevel=3 ibt=off
Mobo: ASUSTeK model: ROG CROSSHAIR VII HERO v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 4603 date: 09/13/2021
Info: model: AMD Ryzen 5 2600X socket: AM4 bits: 64 type: MT MCP arch: Zen+
gen: 2 built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8
stepping: 2 microcode: 0x800820D
Speed (MHz): avg: 3600 min/max: 2200/3600 boost: enabled
base/boost: 3600/4250 scaling: driver: acpi-cpufreq governor: performance
volts: 1.2 V ext-clock: 100 MHz cores: 1: 3600 2: 3600 3: 3600 4: 3600
5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600 12: 3600
bogomips: 86403
SMART: yes health: PASSED on: 11d 10h cycles: 98
read-units: 1,002,088 [513 GB] written-units: 1,598,520 [818 GB]
logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: E1.3 temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 70d 23h cycles: 539
written: 1.6 MiB
model: WD15EADS-00P8B0 family: Caviar Green size: 1.36 TiB block-size:
physical: 512 B logical: 512 B sata: 2.6 speed: 3.0 Gb/s type: N/A
serial: <filter> rev: 0A01 temp: 26 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 3y 9d 12h cycles: 7385
model: WD40EZRZ-75GXCB0 family: Blue size: 3.64 TiB block-size:
physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD
rpm: 5400 serial: <filter> rev: 0A80 temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 224d 5h cycles: 1797
read: 1.3 TiB written: 2.57 TiB
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:3
used: 50.9 MiB (10.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
used: 96.46 GiB (29.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6
used: 19.09 GiB (31.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3
maj-min: 259:3
maj-min: 259:3
System Temperatures: cpu: 35.0 C mobo: 25.0 C gpu: nvidia temp: 35 C
Fan Speeds (RPM): cpu: 552 case-1: 0 case-2: 0 case-3: 0 gpu: nvidia
fan: 51%
Power: 12v: 11.99 5v: N/A 3.3v: N/A vbat: 3.14
Processes: 426 Uptime: 3h 53m wakeups: 1 Memory: 15.52 GiB
used: 5.98 GiB (38.6%) Init: systemd v: 251 default: graphical
Shell: garuda-inxi (sudo) default: Zsh v: 5.9 running-in: tilix
inxi: 3.3.17
Garuda (2.6.3-2):
Windows dual boot: Yes
