Running c# application creates screes screen issues
Hello. Running a c# application i made in monogame creates some visual errors. They go away once i close the application. how it looks
inxi output:
Kernel: 5.16.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3d7f37ea-6ec9-4e7c-abfb-36c47e2e627b rw rootflags=subvol=@
Type: Laptop System: Dell product: Latitude E7470 v: N/A
Mobo: Dell model: 0T6HHJ v: A00 serial: <superuser required>
UEFI-[Legacy]: Dell v: 1.31.3 date: 10/13/2021
ID-1: BAT0 charge: 48.0 Wh (100.0%) condition: 48.0/55.0 Wh (87.4%)
volts: 8.4 min: 7.6 model: SMP DELL MC34Y51 type: Li-poly serial: <filter>
status: Full
ID-2: hidpp_battery_0 charge: 71% condition: N/A volts: 3.9 min: N/A
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEA
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 799 high: 800 min/max: 400/3000 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 799 3: 800 4: 800
bogomips: 19999
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell Latitude E7470
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-2:3 chip-ID: 0bda:5686 class-ID: 0e02 serial: <filter>
Device-3: Microsoft Microsoft LifeCam Cinema type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-4.1:7 chip-ID: 045e:0812
class-ID: 0102
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157
size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
Monitor-2: HDMI1 res: 1920x1080 hz: 60 dpi: 92
size: 530x300mm (20.9x11.8") diag: 609mm (24")
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell Latitude E7470
Device-2: Logitech G935 Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:4 chip-ID: 046d:0a87
class-ID: 0102
Sound Server-1: ALSA v: k5.16.5-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-LM vendor: Dell Latitude E7470 driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-8:8 chip-ID: 8087:0a2b class-ID: e001
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 465.76 GiB used: 31.44 GiB (6.8%)
model: WDS500G2B0B-00YS70 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 31.44 GiB (6.8%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.3 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 73.0 C pch: 62.0 C mobo: N/A
Fan Speeds (RPM): cpu: 5386
Processes: 230 Uptime: 6m wakeups: 3 Memory: 15.3 GiB
used: 3.81 GiB (24.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1462 lib: 423 Shell: fish
Garuda (2.5.4-2):
System install date:     2022-01-30
Last full system update: 2022-02-05
If you include terminal outputs in your post please
use the proper output format in your post.
Using "~" 3 times above and "~" 3 times below the text block
will provide a readable, raw look.
after asking around online, this is the intended behavior, it is apparently turning off the compositor which makes the game run smoother
