Running a game
Hello again :sweat_smile:, i was trying to run gta san but it isnot launching. I had tried to fix it by using winetricks d3dx9 vcrun2010 but still it isnt launching.. i also updated wine. here is my Garuda-inxi : garuda-inxi
Kernel: 6.4.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=841fed05-c7a1-4710-85fc-de712c660e4a rw rootflags=subvol=@
resume=UUID=100ebd16-08c1-416a-835e-5f1db5650c37 loglevel=3 ibt=off
Type: Desktop Mobo: INTEL model: H61 serial: <superuser required>
UEFI: American Megatrends v: 4.6.5 date: 05/29/2019
Info: model: Intel Core i3-3220 bits: 64 type: MT MCP arch: Ivy Bridge
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3292 high: 3293 min/max: 1600/3300 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3291 2: 3292 3: 3292
4: 3293 bogomips: 26339
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics driver: i915
active: VGA-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:0152 class-ID: 0300
s-diag: 414mm (16.31")
Monitor-1: VGA-1 model: EW32S3PW serial: <filter> built: 2012
res: 1366x768 hz: 60 dpi: 30 gamma: 1.2 size: 1150x650mm (45.28x25.59")
diag: 1321mm (52") ratio: 16:9 modes: max: 1366x768 min: 720x400
API: OpenGL v: 4.2 Mesa 23.1.5 renderer: Mesa Intel HD Graphics 2500 (IVB
GT1) direct-render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
API: ALSA v: k6.4.10-zen2-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
Device-2: Ralink MT7601U Wireless Adapter driver: mt7601u type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.6:6
chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlp0s29u1u6 state: up mac: <filter>
Local Storage: total: 628.27 GiB used: 68.03 GiB (10.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1BD142
tech: HDD rpm: 7200 serial: <filter> fw-rev: KC48 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 model: SATA SSD 128GB size: 119.24 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: SSD
serial: <filter> fw-rev: 537 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Cruzer Blade
size: 14.59 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: SanDisk model: USB 3.2Gen1
size: 28.67 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: GPT
ID-1: / raw-size: 112.74 GiB size: 112.74 GiB (100.00%) used: 15 GiB (13.3%)
fs: btrfs dev: /dev/sdb3 maj-min: 8:19
used: 576 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 435.76 GiB size: 435.76 GiB (100.00%)
used: 53.03 GiB (12.2%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/log raw-size: 112.74 GiB size: 112.74 GiB (100.00%)
used: 15 GiB (13.3%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
ID-5: /var/tmp raw-size: 112.74 GiB size: 112.74 GiB (100.00%)
ID-1: swap-1 type: zram size: 6.72 GiB used: 1.33 GiB (19.7%)
ID-2: swap-2 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 47.0 C mobo: N/A
Processes: 277 Uptime: 1h 0m wakeups: 0 Memory: total: 8 GiB note: est.
available: 6.72 GiB used: 2.5 GiB (37.2%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 2147 libs: 567 tools: octopi,pamac,paru
inxi: 3.3.28
System install date:     2023-08-12
Last full system update: 2023-08-13
  1. How did you install the game? Which store?
  2. Run it from the terminal and share the log.
For reference, here's compatibility report of GTA San
https://www.protondb.com/app/12120
i am using wine bcz proton give me this error : Protontricks was closed due to the following error:
No Proton enabled Steam apps were found. Have you launched one of the apps at least once?
Please include this entire error message when making a bug report.
Log messages:
Found Steam directory at /home/p******/.local/share/Steam
Found 1 Steam library folders
Currently logged-in Steam user: p****
Couldn't find custom shortcuts. Maybe none have been created yet?
