Hello Garuda users.
Kernel: 5.18.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=c8f869ce-554b-4598-b90a-a257e270b783 rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.25.4 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Laptop System: HP product: HP Pavilion 15 Notebook PC v: N/A
Mobo: HP model: 22A9 v: 72.48 serial: <superuser required>
UEFI: American Megatrends v: F.46 date: 04/18/2018
ID-1: BAT0 charge: 20.4 Wh (100.0%) condition: 20.4/20.4 Wh (100.0%)
volts: 16.8 min: 14.8 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: charging cycles: 183
Info: model: AMD A10-7300 Radeon R6 10 Compute Cores 4C+6G bits: 64
type: MT MCP arch: Steamroller built: 2014 process: GF 28nm
family: 0x15 (21) model-id: 0x30 (48) stepping: 1 microcode: 0x6003109
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 256 KiB desc: d-4x16
KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 1896 min/max: 1100/1900 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1896 2: 1896 3: 1896
4: 1896 bogomips: 15171
disabled, RSB filling
Device-1: AMD Kaveri [Radeon R6 Graphics] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu arch: GCN-2 code: Sea Islands
process: GF/TSMC 16-28nm built: 2013-17 ports: active: HDMI-A-1,eDP-1
empty: none bus-ID: 00:01.0 chip-ID: 1002:130a class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) Webcam type: USB
driver: uvcvideo bus-ID: 2-4:2 chip-ID: 05c8:036e class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: radeon
unloaded: fbdev,modesetting,vesa gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 3286x1080 s-dpi: 96 s-size: 869x285mm (34.21x11.22")
s-diag: 915mm (36.01")
Monitor-1: HDMI-A-1 mapped: HDMI-0 pos: primary,top-right
model: Kingston 40TV serial: <filter> built: 2019 res: 1920x1080 hz: 60
dpi: 69 gamma: 1.2 size: 708x398mm (27.87x15.67") diag: 1015mm (40")
Monitor-2: eDP-1 mapped: eDP pos: bottom-l model: AU Optronics 0x43ec
built: 2013 res: 1366x768 hz: 60 dpi: 101 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes:
max: 1366x768 min: 640x480
OpenGL: renderer: AMD KAVERI (LLVM 14.0.6 DRM 2.50 5.18.16-zen1-1-zen)
v: 4.5 Mesa 22.1.6 direct render: Yes
Device-1: AMD Kaveri HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:1308
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.18.16-zen1-1-zen running: yes
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: N/A modules: rtl8723be pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 10ec:b723
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8136
IF-ID-1: br-c5322a07816b state: down mac: <filter>
bus-ID: 3-3:2 chip-ID: 0bda:b001 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 465.76 GiB used: 232.15 GiB (49.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 72.53 GiB size: 72.53 GiB (100.00%) used: 53.19 GiB
(73.3%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.42%) used: 27.5 MiB
(27.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 72.53 GiB size: 72.53 GiB (100.00%) used: 53.19 GiB
ID-4: /var/log raw-size: 72.53 GiB size: 72.53 GiB (100.00%) used: 53.19
GiB (73.3%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-5: /var/tmp raw-size: 72.53 GiB size: 72.53 GiB (100.00%) used: 53.19
ID-1: swap-1 type: zram size: 14.59 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 68.9 C mobo: N/A gpu: radeon temp: 69.0 C
Processes: 237 Uptime: 56m wakeups: 2 Memory: 14.59 GiB used: 2.96 GiB
(20.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 2304 lib: 509
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
Garuda (2.6.5-1):
System install date: 2021-12-24
Last full system update: 2022-08-29 ↻
Failed units: fancontrol.service samba.service
as you can see in network section
diver: N/A
and the wifi connection doesnt work!
the sudo modprobe rtl8723be
response is:
modprobe: ERROR: Error running install command '/bin/false' for module rtlwifi: retcode 1
modprobe: ERROR: could not insert 'rtl8723be': Invalid argument
how can i make the wifi connection work?
and i have to mention i installed the OS on another pc and now using the hard disk in a new laptop
