RTL8822BE - Slow wifi
Hi,
On Garuda KDE I have slower WIFI and signal is weaker than on other distro *Manjaro.
For example, I can see that data traffic is 0 for few sec and after that traffic is back
I am 2 m from router.
 Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
  vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
  port: f000 bus ID: 02:00.0 chip ID: 10ec:b822
inxi -Fxxxza
  Kernel: 5.9.13-98-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: intel_pstate=passive
  BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-bmq
  root=UUID=11de5c08-b64e-4502-97f8-a61295848e7e rw [email protected]
  resume=UUID=3b4f21d2-8f3a-4387-b37c-0102e3a4df99 loglevel=3
  Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
  dm: SDDM Distro: Garuda Linux
  Type: Convertible System: HP product: HP ENVY x360 Convertible 13-ar0xxx
  v: N/A serial: <filter> Chassis: type: 31 serial: <filter>
  Mobo: HP model: 85DE v: 41.36 serial: <filter> UEFI: AMI v: F.19
  date: 12/26/2019
  ID-1: BAT0 charge: 50.8 Wh condition: 50.8/50.8 Wh (100%)
  volts: 17.5/15.4 model: 333-2B-49-A KC04053XL type: Li-ion
  serial: <filter> status: Full
  Device-1: hid-0018:04F3:23B9.0004-battery model: ELAN2514:00 04F3:23B9
  serial: N/A charge: N/A status: N/A
  Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
  bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 18 (24)
  stepping: 1 microcode: 8108102 L2 cache: 2048 KiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 33568
  Speed: 2502 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
  1: 2502 2: 2056 3: 2868 4: 2730 5: 2600 6: 2449 7: 2890 8: 2602
  STIBP: disabled, RSB filling
  Device-1: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel
  bus ID: 04:00.0 chip ID: 1002:15d8
  Device-2: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
  bus ID: 3-1:2 chip ID: 04ca:709d
  Display: x11 server: X.org 1.20.10 compositor: kwin_x11
  driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
  resolution: <missing: xdpyinfo>
  OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.39.0
  5.9.13-98-tkg-bmq LLVM 11.0.0)
  v: 4.6 Mesa 20.3.0 direct render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 04:00.1
  chip ID: 1002:15de
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  vendor: Hewlett-Packard driver: N/A
  alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 04:00.5
  chip ID: 1022:15e2
  Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
  Sound Server: ALSA v: k5.9.13-98-tkg-bmq
  Local Storage: total: 476.94 GiB used: 16.43 GiB (3.4%)
  ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8H size: 476.94 GiB
  block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
  serial: <filter> rev: HPS0 scheme: GPT
  ID-1: / raw size: 467.84 GiB size: 467.84 GiB (100.00%)
  used: 16.43 GiB (3.5%) fs: btrfs dev: /dev/nvme0n1p2
  ID-2: /home raw size: 467.84 GiB size: 467.84 GiB (100.00%)
  ID-3: /var/log raw size: 467.84 GiB size: 467.84 GiB (100.00%)
  ID-4: /var/tmp raw size: 467.84 GiB size: 467.84 GiB (100.00%)
  ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%)
  priority: -2 dev: /dev/nvme0n1p3
  ID-2: swap-2 type: zram size: 734.5 MiB used: 5.0 MiB (0.7%)
  priority: 32767 dev: /dev/zram0
  ID-3: swap-3 type: zram size: 734.5 MiB used: 5.0 MiB (0.7%)
  priority: 32767 dev: /dev/zram1
  ID-4: swap-4 type: zram size: 734.5 MiB used: 5.0 MiB (0.7%)
  priority: 32767 dev: /dev/zram2
  ID-5: swap-5 type: zram size: 734.5 MiB used: 5.0 MiB (0.7%)
  priority: 32767 dev: /dev/zram3
  ID-6: swap-6 type: zram size: 734.5 MiB used: 5.0 MiB (0.7%)
  priority: 32767 dev: /dev/zram4
  ID-7: swap-7 type: zram size: 734.5 MiB used: 4.8 MiB (0.6%)
  priority: 32767 dev: /dev/zram5
  ID-8: swap-8 type: zram size: 734.5 MiB used: 4.8 MiB (0.6%)
  priority: 32767 dev: /dev/zram6
  ID-9: swap-9 type: zram size: 734.5 MiB used: 4.8 MiB (0.6%)
  priority: 32767 dev: /dev/zram7
  System Temperatures: cpu: 50.9 C mobo: 47.0 C gpu: amdgpu temp: 50.0 C
  Processes: 302 Uptime: 22m wakeups: 794 Memory: 5.74 GiB
  used: 5.31 GiB (92.6%) Init: systemd v: 247 Compilers: gcc: 10.2.0
  clang: 11.0.0 Packages: pacman: 1282 lib: 429 Shell: fish v: 3.1.2
  running in: konsole inxi: 3.1.09
nmcli device wifi list
IN-USE  BSSID              SSID            MODE   CHAN  RATE        SIGNAL  B>
*       90:EF:68:D8:D1:C9  Ludilo          Infra  5     130 Mbit/s  64      ▂>
        30:B5:C2:98:44:F4  TP-LINK_9844F4  Infra  1     270 Mbit/s  34      ▂>
        B0:C2:87:EA:F4:9E  B.net_95404     Infra  1     130 Mbit/s  32      ▂>
        9C:30:5B:64:82:5D  648257          Infra  11    130 Mbit/s  32      ▂>
        3C:84:6A:A3:7E:37  --              Infra  6     130 Mbit/s  22      ▂>
disable wifi powersave
and mac address randomization
Yes,I already tried that. That was my first step, as I saw similar post on forum
Please list all steps you've taken so far. Not listing what you've already tested simply wastes everyone's time repeating the same things over again.
Reset your router to the factory default. Then reboot computer and router.
List all prior troubleshooting efforts.
I did this :
disabled wifi powersave
Reset router to the factory
Compared speed and traffic activity on my laptop and phone.
On the phone I have constant traffic and better speed
If you haven't tested this driver:
rtw88-dkms-git
Then install the rtw88-dkms-git driver from the chaotic AUR repository.
Reboot after installation. Hopefully your speeds increase.
If the driver does not make any difference then I would try disabling IPv6 either through Network Manager or through your router.
Have you used this computer on another network?
Does the same thing happen on other networks?
Have you tested other routers with your home network?
Have you changed your dns provider? If so which servers are you using?
Is your bios up to date?
Is your routers firmware up to date?
Please attempt to answer all questions.
Thanks,
First, I am not sure if driver is loaded correctly or do I need disable older one etc.
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822BE 802.11a/b/g/n/ac WiFi adapter
        DeviceName: Realtek RTL8822BE 802.11 ac 2x2 WiFi + BT 4.2 Combo Adapter (MU-MIMO supported)
        Subsystem: Hewlett-Packard Company Realtek RTL8822BE 802.11ac 2 × 2 Wi-Fi + Bluetooth 4.2 Combo Adapter (MU-MIMO supported)
        Kernel driver in use: rtw_8822be
        Kernel modules: rtw88_8822be, rtw_8822be
IPv6 = I set for method / ignored in Network manager
Yes, mobile network, while I was trying to download Garuda iso. It fails 3 times on wifi due to network, so I tried from phone network, same issues.
No, I only have this one
Have you changed your dns provider? No
I am not sure
Is your bios up to date? yes
Is your routers firmware up to date? I am not sure also, I searched that, but didnt found any info
