RTL8192EU - USB Wifi not connecting
Whenever I connect my usb adapter it shows all the available wifi networks but it doesn't connect to wifi it says configuring interface for some time while trying to connect and then after some time a notification pops up:
"Wireless interface (wlp0s29u1u4)
The wifi network could not be found"
I saw few forums related to similar topic but nothing worked.
here is my lsusb output:
Bus 002 Device 006: ID 0bda:818b Realtek Semiconductor Corp. RTL8192EU 802.11b/g/n WLAN Adapter
Bus 002 Device 008: ID 04e8:6863 Samsung Electronics Co., Ltd Galaxy series, misc. (tethering mode)
Bus 002 Device 004: ID 046d:c31d Logitech, Inc. Media Keyboard K200
Bus 002 Device 003: ID 046d:c077 Logitech, Inc. M105 Optical Mouse
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
and here's my inxi -Fxxxza output:
  Kernel: 5.10.14-119-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.1
  parameters: intel_pstate=passive BOOT_IMAGE=/boot/vmlinuz-linux-tkg-bmq
  root=UUID=a254025d-a93e-47e8-bfda-11a403627b03 rw quiet splash
  resume=UUID=86acf350-4e94-4b33-9705-eee729af8923 loglevel=3
  Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
  dm: SDDM Distro: Garuda Linux
  Type: Desktop Mobo: ASUSTeK model: P8H61-M LX3 R2.0 v: Rev X.0x
  serial: <filter> BIOS: American Megatrends v: 0406 date: 06/29/2012
  Info: Dual Core model: Intel Core i3-2100 bits: 64 type: MT MCP
  arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
  L2 cache: 3 MiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 24827
  Speed: 2296 MHz min/max: 1600/3100 MHz Core speeds (MHz): 1: 2296 2: 2124
  3: 3102 4: 2269
  Type: l1tf
  vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0102
  class ID: 0300
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0
  s-diag: 414mm (16.3")
  Monitor-1: VGA1 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1")
  diag: 470mm (18.5")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 2000 (SNB GT1)
  v: 3.3 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
  vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:1c20 class ID: 0403
  Sound Server: ALSA v: k5.10.14-119-tkg-bmq
  vendor: ASUSTeK P8 series driver: r8169 v: kernel port: e000 bus ID: 03:00.0
  chip ID: 10ec:8168 class ID: 0200
  Device-2: Realtek RTL8192EU 802.11b/g/n WLAN Adapter type: USB
  driver: rtl8xxxu bus ID: 2-1.4:6 chip ID: 0bda:818b class ID: 0000
  IF: wlp0s29u1u4 state: down mac: <filter>
  IF-ID-1: enp0s29u1u3 state: unknown speed: N/A duplex: N/A mac: <filter>
  Local Storage: total: 465.76 GiB used: 243.53 GiB (52.3%)
  model: WD5000AAKX-00ERMA0 size: 465.76 GiB block size: physical: 512 B
  logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 1H15 scheme: MBR
  ID-1: / raw size: 90.82 GiB size: 88.89 GiB (97.88%) used: 50.34 GiB (56.6%)
  fs: ext4 dev: /dev/sda6 maj-min: 8:6
  ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda5 maj-min: 8:5
  ID-2: swap-2 type: zram size: 905.8 MiB used: 13.5 MiB (1.5%)
  priority: 32767 dev: /dev/zram0
  ID-3: swap-3 type: zram size: 905.8 MiB used: 13.1 MiB (1.4%)
  priority: 32767 dev: /dev/zram1
  ID-4: swap-4 type: zram size: 905.8 MiB used: 13.5 MiB (1.5%)
  priority: 32767 dev: /dev/zram2
  ID-5: swap-5 type: zram size: 905.8 MiB used: 12.9 MiB (1.4%)
  priority: 32767 dev: /dev/zram3
  System Temperatures: cpu: 72.0 C mobo: 27.8 C
  Processes: 207 Uptime: 50m wakeups: 0 Memory: 3.54 GiB
  used: 2.83 GiB (80.1%) Init: systemd v: 247 Compilers: gcc: 10.2.0
  clang: 11.0.1 Packages: pacman: 1697 lib: 535 Shell: fish v: 3.1.2
  running in: konsole inxi: 3.3.01
Hoping to get reply soon
Thank you :slight_smile:
You have done a pretty good job at detailing your problem, except for my quote. You really need to be more specific about what you've tested.
Have you disibled MAC Address randomization (if not search for how to do that). I would also disable IPv6.
I don't happen to be at home to refer to my network notes. However, if I recall correctly this is one of Realtek's old dogs from their lineup. I don't have anything against Realtek, but like most manufacturers they have good adapters and bad. This is rather one of their poorest wifi adapters. Personaly I'd think about a replacent because even if you get it working, it's performance is generally very poor.
Replacing an internal wifi adapter in a desktop is rather easy, so that would be a fairly cheap and easy fix IMO. You could use an internal add in card or a USB dongle. You will get far better performance from a relatively inexpensive replacement than you'll ever see out of your current model.
I usually don't give this advice very often, but in your adapter's case it's often just not worth the effort to try and get it working (especially on a desktop computer).
As this is a desktop is Ethernet an option. If running cables is a no go then I might mention that a powerline networking setup would be a vast improvement over wifi. The nice thing about using a powerline setup is that they do not require special drivers. So you are pretty much guaranteed compatability with Linux.
A powerline network setup is definitely more expensive than buying a cheap wifi replacement, however your speed and reliabilty will be far superior to Wifi. Just something to think about if you don't want driver issues on Linux. You can search online for details about powerline networking if you are unfamiliar with it. Only pay attention to new reports on powerline networking as the old technology when it first came out was not very good. Recent powerline systems are excellent IMO.
Welcome to Garuda BTW.
