Return key registering as KP_Enter
Hi Hoping someone can point me in the right direction here. I've got a laptop with Manjaro i3 and Garuda Qtile (on separate SSDs) and I've found that on Garuda xev shows my Return key as KP_Enter but on Manjaro (also Endeavour) xev correctly shows my Return key as Return. Now, I know I can reassign the key as need but I'm just wondering if there's a simple setting somewhere that I'm missing to have it correctly report Return instead of KP_Enter (my laptop doesn't have a keypad so this is the standard Return key).
Things I've tried:
  • Installed Garuda i3: same problem Return key shows as KP_Enter
  • Checked that Manjaro i3, Endeavour i3, Garuda i3, and Garuda Qtile all had the same keyboard settings ( model=generic pc105, layout=ie_English UTF-8 etc).
  • Read the Arch Wiki for pages for Linux Console/Keyboard Configuration and Xorg/Keyboard Configuration
  • Compared the output of localectl status on each OS
  • Compared the contents of /etc/vconsole.conf and /etc/X11/xorg.conf.d/00-keyboard.conf on each OS
  • Compared xev output on each OS, I found that on Garuda if I hold Fn and hit my return key it shows as Return.
inxi -Faz output:
  Kernel: 5.13.10-zen1-1-zen x86_64 bits: 64 compiler: gcc
  v: 11.1.0
  root=UUID=285c75c8-2fba-4287-af8d-32529bceaceb rw
  [email protected] quiet splash rd.udev.log_priority=3
  vt.global_cursor_default=0
  resume=UUID=06e589a2-b813-4d13-b74b-984f1ac2e521 loglevel=3
  Desktop: Qtile 0.18.1.dev0+g8e7ecc0a.d20210719 wm: LG3D
  Type: Laptop System: TUXEDO product: InfinityBook_S_14_v5
  v: N/A serial: <filter> Chassis: Notebook type: 10
  Mobo: TUXEDO model: L140CU serial: <filter> UEFI: INSYDE
  v: 1.07.07RTR3 date: 02/17/2020
  ID-1: BAT0 charge: 65.1 Wh (95.0%)
  condition: 68.5/73.9 Wh (92.6%) volts: 8.2 min: 7.7
  model: Notebook BAT type: Li-ion serial: <filter>
  status: Discharging
  Info: Quad Core model: Intel Core i7-10510U bits: 64
  type: MT MCP arch: Kaby Lake note: check family: 6
  model-id: 8E (142) stepping: C (12) microcode: EA cache:
  L2: 8 MiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  vmx
  bogomips: 36799
  Speed: 3329 MHz min/max: 400/4900 MHz Core speeds (MHz):
  1: 3329 2: 3727 3: 4040 4: 3602 5: 3865 6: 3343 7: 3799
  8: 4097
  Vulnerabilities: Type: itlb_multihit
  status: KVM: VMX disabled
  Type: spec_store_bypass mitigation: Speculative Store Bypass
  disabled via prctl and seccomp
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and
  __user pointer sanitization
  Device-1: Intel CometLake-U GT2 [UHD Graphics]
  vendor: CLEVO/KAPOK driver: i915 v: kernel bus-ID: 00:02.0
  Device-2: Chicony Chicony USB2.0 Camera type: USB
  driver: uvcvideo bus-ID: 1-7:3 chip-ID: 04f2:b684
  Display: x11 server: X.Org 1.20.13 compositor: picom
  v: git-60eb0 driver: loaded: intel unloaded: modesetting
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96
  s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
  Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157
  size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2)
  v: 4.6 Mesa 21.2.1 direct render: Yes
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: CLEVO/KAPOK
  chip-ID: 8086:02c8 class-ID: 0403
  Sound Server-1: ALSA v: k5.13.10-zen1-1-zen running: yes
  Sound Server-4: PipeWire v: 0.3.34 running: yes
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel
  port: 5040 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp6s0 state: up mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb
  v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0029 class-ID: e001
  bt-service: enabled,running rfk-block: hardware: no
  software: yes address: <filter>
  Local Storage: total: 698.65 GiB used: 9.99 GiB (1.4%)
  SMART Message: Required tool smartctl not installed. Check
  --recommends
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung
  model: SSD 860 EVO M.2 250GB size: 232.89 GiB block-size:
  physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
  serial: <filter> rev: 4B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung
  model: SSD 860 EVO M.2 500GB size: 465.76 GiB block-size:
  ID-1: / raw-size: 207.09 GiB size: 207.09 GiB (100.00%)
  used: 9.99 GiB (4.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  used: 562 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 207.09 GiB size: 207.09 GiB (100.00%)
  ID-4: /var/log raw-size: 207.09 GiB
  size: 207.09 GiB (100.00%) used: 9.99 GiB (4.8%) fs: btrfs
  ID-5: /var/tmp raw-size: 207.09 GiB
  Kernel: swappiness: 133 (default 60)
  cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 25.54 GiB
  used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 maj-min: 8:3
  ID-2: swap-2 type: zram size: 23.21 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 47.0 C mobo: N/A
  Processes: 280 Uptime: 6h 5m wakeups: 4089 Memory: 23.22 GiB
  used: 2.8 GiB (12.1%) Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1172
  lib: 297 Shell: fish v: 3.3.1 running-in: alacritty
  inxi: 3.3.06
Many thanks for any advice.
sudo showkey -a
^M 	 13 0015 0x0d <-- KP_Enter
^M 	 13 0015 0x0d <-- Enter
on my pc105 Keyboard (I have no laptop with i3wm)
It's not nice that it is, but is there a problem because of that?
It is not standard practice after installing a new operating system to check what the return values of the Return / Enter key are. :wink:
I personally can't help you there, but
:slight_smile:
BTW, why you use "old" kernel?
Hey and thanks for the reply/welcome.
Nah, not really, was just wondering if there was something obvious I'd overlooked.
Lol no indeed, I wouldn't normally do so. I just noticed that after installing i3 and LeftWM Super+Return/Super+Shift+Return wasn't giving me a terminal the way it normally would (Qtile works fine though). I checked xev out of curiosity and noticed it was KP_Enter where usually I see Return.
Fresh re-install that I haven't updated yet. :blush:
Thanks again!
~/.config/i3/config
# start a terminal #alacritty xfce4-terminal
bindsym $super+Return exec xfce4-terminal
bindsym $super+t exec xfce4-terminal
bindsym $super+Shift+Return exec alacritty
Try Super + t :slight_smile:
