λ inxi -Faz
System: Kernel: 5.15.6-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=295e7c6a-b69e-4d42-89a4-06a9e8fe2314
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: H110M-C/BR v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 0304 date: 01/12/2016
CPU: Info: Dual Core model: Intel Core i3-6100 bits: 64 type: MT MCP arch: Skylake-S family: 6
model-id: 5E (94) stepping: 3 microcode: EA cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 29598
Speed: 3700 MHz min/max: 800/3700 MHz Core speeds (MHz): 1: 3700 2: 3700 3: 3700 4: 3700
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: ZOTAC driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c02 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7") s-diag: 554mm (21.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 75 dpi: 102 size: 480x270mm (18.9x10.6")
diag: 551mm (21.7")
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44
direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: ZOTAC driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Sound Server-1: ALSA v: k5.15.6-zen2-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK PRIME B450M-A
driver: r8169 v: kernel port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8
bus-ID: 1-1:2 chip-ID: 0a12:0001 class-ID: e001
Drives: Local Storage: total: 1.35 TiB used: 134.65 GiB (9.8%)
ID-1: /dev/sda maj-min: 8:0 model: N/A size: 447.13 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 8A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB
serial: <filter> rev: CC49 scheme: GPT
Partition: ID-1: / raw-size: 756.25 GiB size: 756.25 GiB (100.00%) used: 134.65 GiB (17.8%) fs: btrfs
dev: /dev/sdb3 maj-min: 8:19
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 580 KiB (0.1%) fs: vfat
dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 756.25 GiB size: 756.25 GiB (100.00%) used: 134.65 GiB (17.8%) fs: btrfs
ID-4: /var/log raw-size: 756.25 GiB size: 756.25 GiB (100.00%) used: 134.65 GiB (17.8%)
fs: btrfs dev: /dev/sdb3 maj-min: 8:19
ID-5: /var/tmp raw-size: 756.25 GiB size: 756.25 GiB (100.00%) used: 134.65 GiB (17.8%)
ID-1: swap-1 type: partition size: 9.77 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb2
maj-min: 8:18
ID-2: swap-2 type: zram size: 7.67 GiB used: 2.06 GiB (26.9%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 55.0 C mobo: 27.8 C gpu: nvidia temp: 46 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 59%
Info: Processes: 262 Uptime: 6h 28m wakeups: 0 Memory: 7.67 GiB used: 5.4 GiB (70.4%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1923 lib: 510 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.09
I recently had to restore my desktop layout to the KDE defaults. I have not found any way to change the lockscreen (not SDDM) back to the Dr460nized one.
