Hello everyone. I just made a fresh install on a new SSD and after getting it all set up I screwed up when closing a terminal with htop running....It gave me the "running process" warning and asked if I really wanted to close it with a process running. I checked the box that said something like, "Do not show this message again," then I clicked the wrong one and told it not to kill the terminal. Now I can't close a terminal with a running process. My konsole is now stuck running a process I can't kill with Ctrl + C and I can't even close the terminal to stop it. I'm hoping someone might be able to tell me how I can reset that warning so I can try again. Thanks in advance for any help with this as I'm apparently searching with the wrong key words in DDG.
╭─user@transruda in ~
╰─λ garuda-inxi
Kernel: 5.17.5-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=06624f42-8c02-4c83-a1d0-1cf8a1e4482e rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
Type: Laptop System: Acer product: Aspire 7750G v: V1.21
serial: <superuser required> Chassis: type: 10 v: 1.21
Mobo: Acer model: JE70_HR serial: <superuser required> BIOS: Acer v: 1.21
date: 08/09/2012
ID-1: BAT0 charge: 12.7 Wh (100.0%) condition: 12.7/47.5 Wh (26.7%)
volts: 12.4 min: 10.8 model: SANYO Li_Ion_4000mA type: Li-ion
serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master
Info: model: Intel Core i7-2630QM bits: 64 type: MT MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 850 high: 1221 min/max: 800/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1221 2: 798 3: 798
4: 798 5: 798 6: 798 7: 798 8: 798 bogomips: 31930
Type: l1tf
Device-1: AMD Whistler [Radeon HD 6630M/6650M/6750M/7670M/7690M]
vendor: Acer Incorporated ALI driver: radeon v: kernel alternate: amdgpu
pcie: gen: 2 speed: 5 GT/s lanes: 16 ports: active: LVDS-1
empty: HDMI-A-1,VGA-1 bus-ID: 01:00.0 chip-ID: 1002:6741 class-ID: 0300
Device-2: Alcor Micro Acer Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.3:3 chip-ID: 058f:b002 class-ID: 0e02
alternate: fbdev,vesa gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: LVDS-1 mapped: LVDS model: AU Optronics 0x139e built: 2009
res: 1600x900 hz: 60 dpi: 106 gamma: 1.2 size: 382x214mm (15.04x8.43")
diag: 438mm (17.2") ratio: 16:9 modes: max: 1600x900 min: 640x480
OpenGL: renderer: AMD TURKS (DRM 2.50.0 / 5.17.5-zen1-2-zen LLVM 13.0.1)
v: 3.3 Mesa 22.0.3 compat-v: 3.1 direct render: Yes
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Device-2: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series]
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aa90 class-ID: 0403
Sound Server-1: ALSA v: k5.17.5-zen1-2-zen running: yes
Device-1: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet
vendor: Acer Incorporated ALI driver: atl1c v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 1969:1083
Device-2: Qualcomm Atheros AR9287 Wireless Network Adapter
vendor: Foxconn T77H167.00 driver: ath9k v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:002e
Local Storage: total: 347.51 GiB used: 99.45 GiB (28.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A120G
type: SSD serial: <filter> rev: BBF0 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Dogfish Technology model: SSD 128GB
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 4A0 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Generic model: Multi-Card
size: 116.48 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: GPT
ID-1: / raw-size: 30.52 GiB size: 30.52 GiB (100.00%)
used: 13.47 GiB (44.1%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 88.72 GiB size: 88.72 GiB (100.00%)
used: 55.94 GiB (63.0%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-3: /var/log raw-size: 30.52 GiB size: 30.52 GiB (100.00%)
ID-4: /var/tmp raw-size: 30.52 GiB size: 30.52 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.61 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 66.0 C mobo: N/A gpu: radeon temp: 62.0 C
Processes: 306 Uptime: 1h 26m wakeups: 13 Memory: 15.61 GiB
used: 2.83 GiB (18.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1497 lib: 344 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-05-11
Last full system update: 2022-05-11 ↻
Failed units: bluetooth-autoconnect.service systemd-networkd-wait-online.service
