Reset my icon setting after restart in Hyprland
I have an annoying problem, i changed the icon pack to papyrus dark grey with gtk settings (nwg-look). The icons are fine until i restart the system, i try looking conf or settings files but i cant find where should i change for permanently.
i alredy changed in:
/home/[user]/.config/gtk-3.0/settings.ini
and
/home/[user]/.config/gtk-4.0/settings.ini
but still reset after restart.
Any suggestion?
inxi:
  Kernel: 6.7.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=095c9f1d-4e23-42b2-aa42-36402880711e rw rootflags=subvol=@
    quiet resume=UUID=4b8a0d61-7df0-445b-9329-0c5cf2f2c346 loglevel=3
  Type: Laptop System: Dell product: Vostro 3580 v: N/A
  Mobo: Dell model: 0PMTCG v: A00 serial: <superuser required> UEFI: Dell
    v: 1.27.0 date: 11/16/2023
  ID-1: BAT0 charge: 29.3 Wh (100.0%) condition: 29.3/42.0 Wh (69.8%)
    volts: 12.6 min: 11.4 model: BYD DELL 1VX1H97 type: Li-ion serial: <filter>
    status: full
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
  Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
    stepping: 0xC (12) microcode: 0xF8
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 3261 high: 3812 min/max: 400/3900 scaling:
    driver: intel_pstate governor: performance cores: 1: 3698 2: 3812 3: 3503
    4: 3777 5: 3796 6: 400 7: 3776 8: 3326 bogomips: 28800
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Dell
    ports: active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 0000:00:02.0
    chip-ID: 8086:3ea0 class-ID: 0300
  Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
    chip-ID: 1bcf:2b98 class-ID: 0e02
    compositor: Hyprland driver: X: loaded: modesetting
    alternate: fbdev,intel,vesa dri: iris gpu: i915 d-rect: 4480x1080
    display-ID: 1
  Monitor-1: HDMI-A-1 pos: right model: LG (GoldStar) ULTRAWIDE
    serial: <filter> built: 2014 res: 2560x1080 hz: 60 dpi: 112 gamma: 1.2
    scale: 1 size: 677x290mm (26.65x11.42") diag: 628mm (24.7") modes:
    max: 2560x1080 min: 720x400
  Monitor-2: eDP-1 pos: primary,left model: AU Optronics 0x38ed built: 2015
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 scale: 1
    modes: 1920x1080
  API: Vulkan v: 1.3.276 layers: 3 device: 0 type: integrated-gpu
    name: Intel UHD Graphics 620 (WHL GT2) driver: mesa intel v: 23.3.4-arch1.2
    device-ID: 8086:3ea0 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 23.3.4-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
    alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 0000:00:1f.3
    chip-ID: 8086:9dc8 class-ID: 0403
  API: ALSA v: k6.7.2-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
    vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 0000:01:00.0
    vendor: Dell driver: ath10k_pci v: kernel bus-ID: 0000:02:00.0
    chip-ID: 168c:0042 class-ID: 0280
  IF-ID-1: wguk133t state: unknown speed: N/A duplex: N/A mac: N/A
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 0cf3:e009
    driver: intel_nvme_remap v: N/A port: 4060 bus-ID: 0000:00:17.0
    chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 1.36 TiB used: 18.08 GiB (1.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
    model: KBG40ZNS256G NVMe 256GB size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B tech: SSD serial: <filter> fw-rev: 10410106 temp: 22.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SU630 size: 223.57 GiB
    serial: <filter> fw-rev: 3R17 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST1000LM 024 HN-M101M
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A
    serial: <filter> fw-rev: 2AR2 scheme: MBR
  ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 8.3 GiB (13.8%)
    used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 162.16 GiB size: 162.16 GiB (100.00%)
    used: 9.77 GiB (6.0%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-4: /var/log raw-size: 60 GiB size: 60 GiB (100.00%)
    used: 8.3 GiB (13.8%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-5: /var/tmp raw-size: 60 GiB size: 60 GiB (100.00%)
    zswap: no
  ID-1: swap-1 type: partition size: 16.01 GiB used: 0 KiB (0.0%)
  ID-2: swap-2 type: zram size: 7.63 GiB used: 1.89 GiB (24.7%)
  System Temperatures: cpu: 68.0 C pch: 61.0 C mobo: 43.0 C
  Fan Speeds (rpm): cpu: 2665
  Processes: 303 Uptime: 1d 20h 43m wakeups: 4 Memory: total: 8 GiB
  available: 7.63 GiB used: 4.29 GiB (56.2%) Init: systemd v: 255
  pm: pacman pkgs: 1440 libs: 417 tools: paru Shell: fish v: 3.7.0
  running-in: foot inxi: 3.3.31
Garuda (2.6.22-1):
  System install date:     2024-01-21
  Last full system update: 2024-01-29
  Failed units:            [email protected]
I found it.
I need change it in the “/usr/local/bin/apply-gsettings”
Can i delete this settings from the hyprland.conf or this file set up other settings is well? Because this file reset all the icon, theme, font and cursor settings every restart. So doesnt make sense change anything in the gtk settings.
# Use gtk-settings
exec-once = apply-gsettings
thanks.
