Request for garuda maintainers to provide a setup guide to switch to iwd network manager
  Kernel: 6.6.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
    available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
    root=UUID=b6b92ddd-1165-4684-927f-b9ae66d45eff rw rootflags=subvol=@ rd.udev.log_priority=3
    vt.global_cursor_default=0 loglevel=3 mitigations=off sysrq_always_enabled=1 ibt=off
  Desktop: GNOME v: 45.2 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 45.0.1
  Type: Laptop System: ASUSTeK product: X540LA v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X540LA v: 1.0 serial: <superuser required> UEFI: American Megatrends
    v: X540LA.303 date: 08/31/2018
  ID-1: BAT0 charge: 22.9 Wh (100.0%) condition: 22.9/33.2 Wh (69.1%) volts: 10.8 min: 10.8
    model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: not charging cycles: 721
  Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell gen: core 5 level: v3
    note: check built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61) stepping: 4
    microcode: 0x2F
  Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache: L1: 128 KiB
    desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1896 high: 1898 min/max: 500/1900 scaling: driver: intel_cpufreq
    governor: performance cores: 1: 1898 2: 1896 3: 1896 4: 1895 bogomips: 15962
  Device-1: Intel HD Graphics 5500 vendor: ASUSTeK driver: i915 v: kernel arch: Gen-8
    process: Intel 14nm built: 2014-15 ports: active: DP-1 off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:1616 class-ID: 0300
  Device-2: IMC Networks USB2.0 VGA UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 13d3:5a11 class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2 compositor: gnome-shell
    driver: X: loaded: intel unloaded: modesetting alternate: fbdev,vesa dri: i965 gpu: i915
    display-ID: 0
  Monitor-1: DP-1 model: Samsung SyncMaster serial: <filter> built: 2009 res: 1600x900 dpi: 92
    gamma: 1.2 size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9 modes: max: 1600x900
    min: 720x400
  Monitor-2: eDP-1 model: ChiMei InnoLux 0x15dc built: 2015 res: 1366x768 dpi: 101 gamma: 1.2
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast
    surfaceless: drv: iris wayland: drv: iris x11: drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2) device-ID: 8086:1616
    memory: 7.47 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel HD Graphics 5500
    (BDW GT2) driver: mesa intel v: 23.2.1-arch1.2 device-ID: 8086:1616 surfaces: xcb,xlib,wayland
    device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
    v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
  Device-1: Intel Broadwell-U Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
  API: ALSA v: k6.6.5-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.2 chip-ID: 10ec:8136
  IF: enp2s0f2 state: down mac: <fi
lter>
  Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On driver: rtl8723be
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b723
  IF: wlan0 state: up mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:b721 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0 lmp-v: 6 status:
    discoverable: no pairing: no class-ID: 7c010c
  Local Storage: total: 704.24 GiB used: 607.57 GiB (86.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253256GB size: 238.47 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 227N
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD5000LPCX-80VHAT1 size: 465.76 GiB
    fw-rev: 1A02 scheme: GPT
  ID-1: / raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 9.03 GiB (36.2%) fs: btrfs
    dev: /dev/sda1 maj-min: 8:1
  ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 576 KiB (0.1%) fs: vfat
    dev: /dev/sda4 maj-min: 8:4
  ID-3: /home raw-size: 9.8 GiB size: 9.8 GiB (100.00%) used: 2.3 GiB (23.4%) fs: btrfs
    dev: /dev/sda2 maj-min: 8:2
  ID-4: /var/log raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 9.03 GiB (36.2%) fs: btrfs
  ID-5: /var/tmp raw-size: 24.91 GiB size: 24.91 GiB (100.00%) used: 9.03 GiB (36.2%) fs: btrfs
  ID-1: swap-1 type: zram size: 7.65 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
  System Temperatures: cpu: 48.0 C pch: 43.5 C mobo: N/A
  Fan Speeds (rpm): cpu: 2000
  Processes: 274 Uptime: 1h 22m wakeups: 0 Memory: total: 8 GiB available: 7.65 GiB
  used: 3.59 GiB (46.9%) Init: systemd v: 255 default: graphical tool: systemctl Compilers:
  gcc: 13.2.1 Packages: 1210 pm: pacman pkgs: 1194 libs: 349 tools: pamac,paru pm: flatpak pkgs: 16
  Client: shell wrapper v: 5.2.21-release inxi: 3.3.31
Garuda (2.6.19-2):
  System install date:     2023-11-27
  Last full system update: 2023-12-11 ↻
This “request” seems like a backhanded way of saying “I can’t figure this out and I want someone to hold my hand.”
Besides, a rather robust and well-maintained setup guide already exists right here: iwd - ArchWiki
If you try following this guide and get stuck, instead of saying “I want someone else to spend their time writing a new guide”, instead say " I am trying to setup iwd using this ArchWiki article, and this part I don’t understand," or “I cannot get this to work; this is the expected result but this is what is happening.”
I did follow that guide but i couldn’t manage to get iwd to autoconnect to my saved network unless i disable then enable wifi from gnome settings.
Here is a helpful blog post which discusses how this kind of interaction with the forum is toxic to the community and must be avoided at all costs:
https://slash7.com/2006/12/22/vampires/
With that in mind, I will go ahead and close this topic.
If you need help with something, open a new topic and include specific information about how you have configured your setup, what is not working as expected, and what you have tried so far to fix it.
