Rendering issue for some programs
I have observed this behavior with yuzu(shown) discord and transmission so far. the details in app are blurry (so rendering at the wrong resolution or dpi?) and it extends beyond the screen (regardless of what monitor I put it on)
as you can see it extends past in all directions. closing and reopening immediately doesn't solve i just wait awhile and when i reopen it will render properly. I have tried switching between Wayland and x11 sessions to no avail. Any suggestions and insight would be greatly appreciated.
  Kernel: 6.4.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=0e559dbe-1901-4722-bd05-54f3a73edf9f rw rootflags=subvol=@
  Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Desktop System: Gigabyte product: B650 AORUS ELITE AX v: N/A
  Mobo: Gigabyte model: B650 AORUS ELITE AX v: x.x
    serial: <superuser required> UEFI: American Megatrends LLC. v: F5
    date: 05/17/2023
  ID-1: hidpp_battery_0 charge: 45% condition: N/A volts: 3.8 min: N/A
  Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 5
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2997 high: 3000 min/max: 3000/5453 boost: enabled
    scaling: driver: acpi-cpufreq governor: powersave cores: 1: 2992 2: 3000
    3: 3000 4: 2988 5: 3000 6: 3000 7: 3000 8: 2993 9: 3000 10: 3000 11: 3000
    12: 3000 bogomips: 112580
    vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    lanes: 16 ports: active: DP-1, DP-2, HDMI-A-1, HDMI-A-2 empty: none
    bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0300
  Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-3, DP-4,
    DP-5, HDMI-A-3 bus-ID: 13:00.0 chip-ID: 1002:164e class-ID: 0300
    temp: 40.0 C
    compositor: gnome-shell driver: X: loaded: amdgpu
  Screen-1: 0 s-res: 7450x1680 s-dpi: 96 s-size: 1971x445mm (77.60x17.52")
    s-diag: 2021mm (79.55")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,1-3 model: 43548
    built: 2021 res: 2560x1440 dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43")
    diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
  Monitor-2: DP-2 mapped: DisplayPort-1 pos: 1-4 model: Acer V203W
    serial: <filter> built: 2008 res: 1050x1680 hz: 60 dpi: 90 gamma: 1.2
    size: 296x474mm (11.65x18.66") diag: 508mm (20") ratio: 16:10, 15:9 modes:
    max: 1680x1050 min: 720x400
  Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: 2-2 model: Asus VS248
    serial: <filter> built: 2012 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
  Monitor-4: HDMI-A-2 mapped: HDMI-A-1 pos: 2-1 model: LG (GoldStar) TV
    serial: <filter> built: 2017 res: 1920x1080 hz: 120 dpi: 30 gamma: 1.2
    size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9 modes:
    max: 3840x2160 min: 720x400
  API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon RX 6750 XT (navi22
    LLVM 15.0.7 DRM 3.52 6.4.2-zen1-1-zen) direct-render: Yes
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 13:00.1
  Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
    bus-ID: 13:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Sony DualShock 4 [CUH-ZCT2x] driver: snd-usb-audio,usbfs
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.3:3
    chip-ID: 054c:09cc class-ID: 0300
  Device-5: Kingston HyperX 7.1 Audio
    lanes: 1 mode: 1.1 bus-ID: 7-1.2:3 chip-ID: 0951:16a4 class-ID: 0300
  API: ALSA v: k6.4.2-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
  IF: enp14s0 state: down mac: <filter>
    bus-ID: 0f:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp15s0 state: up mac: <filter>
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:4 chip-ID: 0e8d:0616
  Local Storage: total: 2.74 TiB used: 194.94 GiB (6.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital
    model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 731100WD temp: 34.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
    lanes: 4 tech: SSD serial: <filter> fw-rev: 004C temp: 30.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
  ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 194.94 GiB (10.5%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
    used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
    used: 194.94 GiB (10.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
  ID-1: swap-1 type: zram size: 30.5 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 38.0 C mobo: 32.0 C
  GPU: device: amdgpu temp: 40.0 C device: amdgpu temp: 52.0 C mem: 54.0 C
    fan: 781 watts: 33.00
  Processes: 383 Uptime: 12m wakeups: 5 Memory: available: 30.5 GiB
  used: 3.46 GiB (11.3%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1528
  libs: 521 tools: pamac,paru Shell: fish v: 3.6.1 running-in: alacritty
  inxi: 3.3.27
  System install date:     2023-03-17
  Last full system update: 2023-07-10
