Hello !
I have installed Garuda with the beautiful Dr460nized theme and I have a theming issue with one of my applications I use for development purpose : Bonita Studio.
The issue is that the dark theme doesn't properly apply as the application doesn't have a dark theme pre built so it's kind of unusable :
Is there a way to improve this render or disable the auto theming for this application ?
I found a post about Libreoffice for the same issue but the answer was just to use the LibreOffice dark theme.
Thank you in advance !
inxi -Fza
System: Kernel: 5.13.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=f6f170c6-d407-4bd2-b554-b3853d3d11ab rw
[email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: Micro-Star model: B350M BAZOOKA (MS-7A38) v: 1.0 serial: <filter> UEFI: American Megatrends
v: 1.F0 date: 07/07/2018
CPU: Info: Quad Core model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64 type: MCP arch: Zen family: 17 (23)
model-id: 11 (17) stepping: 0 microcode: 810100B cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 28001
Speed: 1426 MHz min/max: 1600/3500 MHz boost: enabled Core speeds (MHz): 1: 1426 2: 2543 3: 1935 4: 1806
Graphics: Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Micro-Star MSI driver: amdgpu
v: kernel bus-ID: 38:00.0 chip-ID: 1002:15dd class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
Screen-1: 0 s-res: 5760x1454 s-dpi: 96 s-size: 1521x384mm (59.9x15.1") s-diag: 1569mm (61.8")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 96 size: 509x286mm (20.0x11.3") diag: 584mm (23")
Monitor-2: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
Monitor-3: HDMI-A-1 res: 1920x1200 hz: 60 dpi: 94 size: 518x324mm (20.4x12.8") diag: 611mm (24.1")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.41.0 5.13.9-zen1-1-zen LLVM 12.0.1) v: 4.6 Mesa 21.1.6
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 38:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 38:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.13.9-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: f000 bus-ID: 1b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp27s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 2.05 TiB used: 536.99 GiB (25.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: OneTouch SSD size: 931.51 GiB block-size:
physical: 512 B logical: 512 B type: SSD serial: <filter> rev: 0001 scheme: MBR
Partition: ID-1: / raw-size: 465.85 GiB size: 465.85 GiB (100.00%) used: 35.86 GiB (7.7%) fs: btrfs dev: /dev/sdb2
maj-min: 8:18
ID-2: /boot/efi raw-size: 954 MiB size: 952.1 MiB (99.80%) used: 5.9 MiB (0.6%) fs: vfat dev: /dev/sda4
maj-min: 8:4
ID-3: /home raw-size: 465.85 GiB size: 465.85 GiB (100.00%) used: 35.86 GiB (7.7%) fs: btrfs dev: /dev/sdb2
maj-min: 8:18
ID-4: /var/log raw-size: 465.85 GiB size: 465.85 GiB (100.00%) used: 35.86 GiB (7.7%) fs: btrfs dev: /dev/sdb2
maj-min: 8:18
ID-5: /var/tmp raw-size: 465.85 GiB size: 465.85 GiB (100.00%) used: 35.86 GiB (7.7%) fs: btrfs dev: /dev/sdb2
maj-min: 8:18
ID-1: swap-1 type: zram size: 14.59 GiB used: 63.5 MiB (0.4%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 44.8 C mobo: N/A gpu: amdgpu temp: 44.0 C
Info: Processes: 284 Uptime: 3h 20m wakeups: 0 Memory: 14.59 GiB used: 10.12 GiB (69.4%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1339 lib: 339 Shell: fish v: 3.3.1
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
