Hello, I am new here, and first, thanks to this beautiful distro and great work here.
I did remove an old Endeavour partition, and of course, messed my boot menu.
I have been able to manually launch my Garuda from grub rescue, however, I have not been able to reinitiate completely my boot, given than the next reboot did bring me again on the grub rescue.
Thanks for your help and have a nice day!
inxi -Faz
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=14c396d6-5048-45b2-903b-042f341ab1a3 rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: U36JC v: 1.0
Mobo: ASUSTeK model: U36JC v: 1.0 serial: <superuser required>
BIOS: American Megatrends v: U36JC.205 date: 01/26/2011
ID-1: BAT0 charge: 65.0 Wh (99.1%) condition: 65.6/81.2 Wh (80.8%)
volts: 16.5 min: 14.4 model: ASUSTek U36-58 type: Li-ion serial: N/A
status: N/A
Info: model: Intel Core i5 M 480 bits: 64 type: MT MCP arch: Westmere
family: 6 model-id: 0x25 (37) stepping: 5 microcode: 0x7
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2009 high: 2446 min/max: 1199/2667 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1263 2: 2110
3: 2218 4: 2446 bogomips: 21279
Type: l1tf
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Device-1: Intel Core Processor Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
Device-2: NVIDIA GT218M [GeForce 310M] vendor: ASUSTeK driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:0a70 class-ID: 0300
Device-3: Chicony Asus Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.2:4 chip-ID: 04f2:b1b9 class-ID: 0e02
loaded: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 120
size: 290x160mm (11.4x6.3") diag: 331mm (13")
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
Device-2: NVIDIA High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:0be3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: AzureWave AW-NB037H 802.11bgn driver: ath9k v: kernel
bus-ID: 03:00.0 chip-ID: 168c:002b class-ID: 0280
IF: wls1 state: up mac: <filter>
vendor: ASUSTeK U6V/U31J laptop driver: r8169 v: kernel port: 8000
bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: ens5 state: down mac: <filter>
Device-1: Qualcomm Atheros AR3011 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-1.1:3 chip-ID: 0cf3:3005 class-ID: e001
Local Storage: total: 232.89 GiB used: 9.92 GiB (4.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 Series
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 9B0Q scheme: MBR
ID-1: / raw-size: 73.47 GiB size: 73.47 GiB (100.00%)
used: 9.92 GiB (13.5%) fs: btrfs dev: /dev/sda9 maj-min: 8:9
ID-2: /home raw-size: 73.47 GiB size: 73.47 GiB (100.00%)
ID-3: /var/log raw-size: 73.47 GiB size: 73.47 GiB (100.00%)
ID-4: /var/tmp raw-size: 73.47 GiB size: 73.47 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.55 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nouveau temp: 41.0 C
Processes: 201 Uptime: 2h 17m wakeups: 1 Memory: 7.55 GiB
used: 1.36 GiB (18.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1315 lib: 313 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
