Recovery after bios reset
╰─λ sudo garuda-inxi
[sudo] password for vorsv:
Kernel: 6.4.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=eb3e5cab-408f-41aa-86b9-6b5e3c79bbde rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Type: Laptop System: HP product: HP EliteBook 830 G5 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 83B3 v: KBC Version 04.6E.00 serial: <filter> UEFI: HP
v: Q78 Ver. 01.25.00 date: 06/16/2023
ID-1: BAT0 charge: 24.2 Wh (75.9%) condition: 31.9/50.2 Wh (63.4%)
volts: 11.1 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: discharging cycles: 560
Info: model: Intel Core i5-8350U socket: BGA1356 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 8 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xA (10)
microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1483 high: 1900 min/max: 400/3600 base/boost: 1600/3600
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 1900 2: 1900 3: 1900 4: 800 5: 1900 6: 800
7: 1900 8: 766 bogomips: 30399
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-9:4 chip-ID: 05c8:0808 class-ID: 0e02 serial: <filter>
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
Monitor-1: eDP-1 model: InfoVision Optronics/Kunshan 0x0536 built: 2019
res: 1920x1080 hz: 60 dpi: 166 gamma: 1.2 size: 294x165mm (11.57x6.5")
diag: 337mm (13.3") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) direct-render: Yes
API: ALSA v: k6.4.7-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.76 status: n/a (root, process) with:
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
Local Storage: total: 946.16 GiB used: 85.62 GiB (9.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: SN560E
lanes: 4 tech: SSD serial: <filter> fw-rev: AO009E4O temp: 39.9 C
SMART: yes health: PASSED on: 65d 21h cycles: 1,187
read-units: 1,118,917,478 [572 TB] written-units: 112,335,529 [57.5 TB]
ID-2: /dev/sda maj-min: 8:0 model: N/A size: 14.65 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: <filter> fw-rev: 2.00 scheme: MBR
ID-1: / raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
used: 85.58 GiB (17.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 39.7 MiB (8.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p6
maj-min: 259:6
ID-3: /home raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
maj-min: 259:5
ID-4: /var/log raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 488.28 GiB size: 488.28 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 31.21 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C pch: 44.5 C mobo: N/A
Processes: 280 Uptime: 3m wakeups: 1 Memory: total: 32 GiB
available: 31.21 GiB used: 3.3 GiB (10.6%) igpu: 32 MiB Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: 2105 pm: dpkg pkgs: 2 pm: pacman pkgs: 2103 libs: 571
tools: gnome-software,octopi,paru Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date:     2023-08-01
Last full system update: 2023-08-26
Windows dual boot:       Yes
I have been using Garuda linux in this machine because of some chip lvl damage issue i gave to service center they replaced the chip and gave it it is not booting now
So I tried it with a usb stick
And selected “detect EFI bootloader” option
That got me into the os
So i tried os-prober and update grub
But it still doesn’t shows up while booting
Check path to /boot/efi/
lsblk -f
You must chroot and
sudo install-grub <path/to/boot/efi>
before sudo update-grub
No sudo needed for garuda-inxi.
It did work sir thank you
And one doubt how you replying to certain clipping
And garuda-inxi said to detect dual boot status try sudo
Just select the text , to which you wanna reply and click on “quote”
Yes sudo is required for that purpose
