Kernel: 6.18.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=1ee69ab7-4876-489c-b980-f9550ad4fc59 rw rootflags=subvol=@
quiet loglevel=3 sysrq_always_enabled=1 vt.global_cursor_default=0
btusb.enable_autosuspend=0 btusb.force_scofix=1
FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
Type: Desktop Mobo: Gigabyte model: B650I AX v: x.x
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends LLC. v: F31c date: 07/23/2024
Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 4
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120A
desc: 6x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 5240 min/max: 427/5457 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 5240 2: 5240 3: 5240
4: 5240 5: 5240 6: 5240 7: 5240 8: 5240 9: 5240 10: 5240 11: 5240 12: 5240
bogomips: 112588
ssse3 svm
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti] vendor: Gigabyte driver: nvidia
v: 590.48.01 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: DP-1, DP-2, HDMI-A-1, HDMI-A-2 empty: none
bus-ID: 01:00.0 chip-ID: 10de:2486 class-ID: 0300
gpu: nv_platform,nvidia,nvidia-nvswitch d-rect: 9286x3648 display-ID: 0
Monitor-1: DP-1 pos: primary,1-1 model: Acer XV272U serial: <filter>
built: 2020 res: mode: 2560x1440 hz: 144 scale: 178% (1.78) to: 1440x2560
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
Monitor-2: DP-2 pos: 2-2 model: Acer ED343CUR V3 serial: <filter>
built: 2024 res: mode: 3440x1440 hz: 180 scale: 100% (1) dpi: 111 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 862mm (33.9") modes: max: 3440x1440
min: 640x480
Monitor-3: HDMI-A-1 pos: 3-3 model: Samsung S19F350 serial: <filter>
built: 2016 res: mode: 1366x768 hz: 60 scale: 77% (0.77) to: 1763x991
dpi: 85 gamma: 1.2 size: 410x230mm (16.14x9.06") diag: 470mm (18.5")
ratio: 16:9 modes: max: 1366x768 min: 640x480
Monitor-4: HDMI-A-2 pos: 2-4 model: Samsung S24R35x serial: <filter>
built: 2020 res: mode: 1920x1080 hz: 72 scale: 83% (0.83) to: 2304x1296
dpi: 92 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 604mm (23.8")
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 25.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
memory: 7.81 GiB display-ID: :0.0
API: Vulkan v: 1.4.335 layers: 12 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 590.48.01 device-ID: 10de:2486
surfaces: N/A device: 1 type: cpu name: llvmpipe (LLVM 21.1.6 256 bits)
driver: mesa llvmpipe v: 25.3.3-arch1.1 (LLVM 21.1.6)
Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Gigabyte
bus-ID: 13:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Walmart AB13X Headset Adapter
lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 001f:0b21 class-ID: 0300
Device-4: GYROCOM C&C Fiio E10 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-1.4:9
chip-ID: 1852:7022 class-ID: 0102
API: ALSA v: k6.18.3-zen1-1-zen status: kernel-api tools: N/A
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
Device-2: Realtek RTL8852CE PCIe 802.11ax Wireless Network
port: d000 bus-ID: 07:00.0 chip-ID: 10ec:c852 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:3 chip-ID: 0bda:0852
lmp-v: 12 status: discoverable: no pairing: yes class-ID: 6c0104
Local Storage: total: 2.52 TiB used: 325.96 GiB (12.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KingPrice model: KPART512GBC2DVT
lanes: 4 tech: SSD serial: <filter> fw-rev: FW000003 temp: 62.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD PM830 2.5 7mm 256GB
tech: SSD serial: <filter> fw-rev: 3D1Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT2000MX500SSD1
tech: SSD serial: <filter> fw-rev: 045 scheme: GPT
ID-1: / raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
used: 95.7 GiB (40.1%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 31.7 MiB (33.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-4: /var/log raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-5: /var/tmp raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.4 GiB used: 11.9 MiB (0.0%) priority: 100
System Temperatures: cpu: 64.2 C mobo: 53.5 C
Memory: total: 64 GiB note: est. available: 62.41 GiB used: 7.85 GiB (12.6%)
Processes: 431 Power: uptime: 1h 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.92 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1862 libs: 453
tools: gnome-software,octopi,paru,yay pm: appimage pkgs: 0 Compilers:
clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9 default: fish v: 4.3.3
running-in: konsole inxi: 3.3.40
Garuda (2.11.1-1):
System install date: 2024-07-27
Garuda release: 240428
Last full system update: 2026-01-24
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
25/26 checks run in 0.60 seconds ⌛
Powered by garuda-health 🦅
When I try to update with Garuda-Update I get the following error and it doesn’t start.
:: Replace vi with extra/ex-vi-compat? [Y/n] y
resolving dependencies...
warning: removing 'lib32-nvidia-utils-590.48.01-1' from target list because it conflicts with 'lib32-nvidia-580xx-utils-580.126.09-1'
warning: removing 'lib32-opencl-nvidia-590.48.01-1' from target list because it conflicts with 'lib32-opencl-nvidia-580xx-580.126.09-1'
warning: removing 'opencl-nvidia-590.48.01-2' from target list because it conflicts with 'opencl-nvidia-580xx-580.126.09-1'
:: garuda-mokka-1.2.8-6 and kwin-effects-forceblur-1.5.0-1.9 are in conflict. Remove kwin-effects-forceblur? [y/N] y
:: unable to satisfy dependency 'opencl-nvidia>=590' required by garuda-hardware-profile-nvidia
:: unable to satisfy dependency 'lib32-nvidia-utils>=590' required by garuda-hardware-profile-nvidia
:: unable to satisfy dependency 'lib32-opencl-nvidia>=590' required by garuda-hardware-profile-nvidia
Can anyone tell me what’s the fault. About a month back I guess, I used the garuda-fix to move to the new nVidia drivers. I don’t really understand what’s going on, my guess is the old drivers are still there. Please advice on what should be done to remove the conflicts.
Thanks in advance
