hello I'll give some background as to how i made it happen. everything was working just fine I was playing steam trying to figure out how to fix stutter issues got tired and put it in sleep mode. woke up it was working fine but steam wouldn't load into the online version so i rebooted my computer now im stuck at the boot screen. i have 3 option
1: garuda (normal way to boot)
2: advanced boot options
3: snapshots
I tried all 3 and none work they all do the same it will say
loading kernel linux-zen
loading initial ramdisk
any help? ik how to get into the Konsole through here and logged in it states
alefetch: could not open /sys/class/drm to determine resolution in tty mode
is there anything i can prompt it to make it boot or is a bigger problem? I also use Dragonized if that helps
It happened again but reloaded a older snapshot but the konsole when tried the most recent one said my password was incorrect even though i have it wrote down so don't forget any ideas why?
nothing just installed steam and stuff back I have an idea that it might be the proprietary divers i download on both times i loaded in? maybe each working one Is running on open drivers?
