Hello, I'm encountering a problem with my Razer Blade.
Aux audio output is mono and can play only some frequencies, and audio aux input is not working.
Kernel: 5.17.3-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod-edge
root=UUID=a7e2f5c7-fe48-4582-8a96-652a235481a9 rw [email protected]
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
mitigations=off amd_iommu=on iommu=pt
Type: Laptop System: Razer product: Blade 14 - RZ09-0370 v: 1.04
serial: <filter> Chassis: type: 10 serial: N/A
Mobo: Razer model: PI411 v: 4 serial: N/A UEFI: Razer v: 1.06
date: 06/07/2021
ID-1: BAT0 charge: 12.9 Wh (20.7%) condition: 62.2/61.6 Wh (101.0%)
volts: 15.9 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: charging
Info: model: AMD Ryzen 9 5900HX with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3242 high: 3244 min/max: 400/3301 boost: disabled
base/boost: 3300/4650 scaling: driver: amd-pstate governor: performance
volts: 1.2 V ext-clock: 100 MHz cores: 1: 3243 2: 3242 3: 3242 4: 3244
5: 3243 6: 3243 7: 3243 8: 3243 9: 3242 10: 3242 11: 3243 12: 3242
13: 3244 14: 3241 15: 3243 16: 3243 bogomips: 105402
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Razer USA
driver: nvidia v: 510.60.02 alternate: nvidiafb,nouveau,nvidia_drm pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Cezanne vendor: Razer USA driver: amdgpu v: kernel pcie:
active: eDP-1 empty: none bus-ID: 04:00.0 chip-ID: 1002:1638
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-4:2 chip-ID: 13d3:56d5 class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: modesetting gpu: amdgpu
Monitor-1: eDP-1 model: Sharp LQ140M1JW49 built: 2020 res: 1920x1080
hz: 144 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.17.3-xanmod1-1)
v: 4.6 Mesa 22.0.1 direct render: Yes
Device-1: NVIDIA vendor: Razer USA driver: snd_hda_intel v: kernel pcie:
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Razer USA
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_sof_amd_renoir
Device-3: AMD Family 17h/19h HD Audio vendor: Razer USA
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.17.3-xanmod1-1 running: yes
Sound Server-4: PipeWire v: 0.3.50 running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2725
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-3:2 chip-ID: 8087:0032 class-ID: e001
address: <filter>
Local Storage: total: 953.87 GiB used: 450.1 GiB (47.2%)
model: MZVLB1T0HBLR-00000 size: 953.87 GiB block-size: physical: 512 B
rev: EXF7201Q temp: 34.9 C scheme: GPT
SMART: yes health: PASSED on: 6d 22h cycles: 1,027
read-units: 11,888,659 [6.08 TB] written-units: 10,174,088 [5.20 TB]
ID-1: / raw-size: 936.96 GiB size: 936.96 GiB (100.00%)
used: 450.1 GiB (48.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 936.96 GiB size: 936.96 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 936.96 GiB size: 936.96 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 936.96 GiB size: 936.96 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.04 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.61 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 45.0 C
Processes: 434 Uptime: 10m wakeups: 1 Memory: 15.05 GiB
used: 5.31 GiB (35.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1899 pacman: 1892 lib: 504 flatpak: 7
inxi: 3.3.15
Garuda (2.6.1-3):
System install date: 2022-02-11
Last full system update: 2022-04-21
Relevant software: tlp NetworkManager
Failed units: systemd-oomd.socket
