Every time i try and update with Rani i get a download speed around 3-400 kilobytes a second instead of a top of 43 MB/s. Making updating Garuda take hours instead of minutes updating. Yet when i update through terminal no trouble downloading full speed.
Is there anything that can be done about this?
Thanks
Kernel: 6.15.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=fa32ef0e-5eeb-4831-b916-361f6644d308 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.4.3 tk: Qt v: N/A info: frameworks v: 6.16.0
wm: kwin_wayland tools: avail: budgie-screensaver, swayidle, xscreensaver
vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop System: NZXT product: N7 Z790 v: N/A
serial:
Mobo: NZXT model: N7 Z790 serial:
uuid: UEFI: American Megatrends LLC. v: 10.07
date: 04/25/2024
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M275/M280
serial: charge: 55% (should be ignored) rechargeable: yes
Info: model: Intel Core i9-14900KF bits: 64 type: MST AMCP arch: Raptor Lake
gen: core 14 level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xB7 (183) stepping: 1 microcode: 0x12F
Topology: cpus: 1x dies: 1 clusters: 12 cores: 24 threads: 32 mt: 8 tpc: 2
st: 16 smt: enabled cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32
KiB, 16x64 KiB L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 800 min/max: 800/5700:6000:4400 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800
23: 800 24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800
32: 800 bogomips: 203980
Device-1: NVIDIA AD103 \[GeForce RTX 4080\] vendor: Gigabyte driver: nvidia
v: 575.64.05 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
chip-ID: 10de:2704 class-ID: 0300
Monitor-1: HDMI-A-1 model: MSI G321CU built: 2022 res: mode: 3840x2160
hz: 120 scale: 100% (1) dpi: 140 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: max: 3840x2160 min: 640x480
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4080/PCIe/SSE2
memory: 15.62 GiB display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 16 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4080 driver: nvidia v: 575.64.05
device-ID: 10de:2704 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.6-arch1.1 (LLVM
Device-1: Intel Raptor Lake High Definition Audio vendor: ASRock
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bb
API: ALSA v: k6.15.8-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 \[Typhoon Peak\] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 07:00.0
IF: wlp7s0 state: down mac:
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:11 chip-ID: 8087:0032
Local Storage: total: 17.4 TiB used: 12.03 TiB (69.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Fanxiang model: S880 2TB
lanes: 4 tech: SSD serial: fw-rev: SN17171 temp: 46.9 C
ID-2: /dev/nvme1n1 maj-min: 259:9 vendor: Crucial model: CT500P3PSSD8
lanes: 4 tech: SSD serial: fw-rev: P9CR40D temp: 39.9 C
ID-3: /dev/nvme2n1 maj-min: 259:5 vendor: TeamGroup
model: T-FORCE TM8FPZ004T size: 3.64 TiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial:
fw-rev: EIFM51.3 temp: 38.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Seagate model: ST12000NM0127
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: fw-rev: G006 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500418AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: fw-rev: CC38 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SanDisk 3.2 Gen1
size: 116.57 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial:
fw-rev: DL17 scheme: GPT
ID-1: / raw-size: 159.18 GiB size: 159.18 GiB (100.00%)
used: 97.09 GiB (61.0%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
used: 2.2 MiB (0.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 159.18 GiB size: 159.18 GiB (100.00%)
ID-4: /var/log raw-size: 159.18 GiB size: 159.18 GiB (100.00%)
ID-5: /var/tmp raw-size: 159.18 GiB size: 159.18 GiB (100.00%)
ID-1: swap-1 type: zram size: 46.87 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.5 C mobo: N/A
Memory: total: 48 GiB available: 46.87 GiB used: 6.62 GiB (14.1%)
Processes: 578 Power: uptime: 1h 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 18.66 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2156 libs: 584 tools: gnome-software, octopi,
pacseek, paru, trizen Compilers: clang: 20.1.8 gcc: 15.1.1
Shell: garuda-inxi default: Bash v: 5.3.3 running-in: lxterminal
inxi: 3.3.38
Garuda (2.7.3-2):
System install date: 2025-07-26
Last full system update: 2025-08-08
