Randomly freezes and does an audio loop
I am having this issue where my system randomly freezes unabling me to perform any actions. Happens usually when shutting down or trying to restart. 4/5 of restart attemps result in freezing and about 1/8 of shutdowns. I also experienced it while im playing games a couple times.
Kernel: 6.9.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=34678ffc-e641-4807-ad60-ffe0d8651433 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Laptop System: MONSTER product: ABRA A5 V20.4 v: Standard
Mobo: MONSTER model: ABRA A5 V20.4 v: Standard
serial: <superuser required> part-nu: A5V204GM5AR5E
uuid: <superuser required> UEFI: American Megatrends LLC. v: N.1.13MON07
date: 01/11/2024
ID-1: BAT0 charge: 62.3 Wh (100.0%) condition: 62.3/62.3 Wh (100.0%)
volts: 17.0 min: 15.2 model: standard type: Li-ion serial: <filter>
status: full
Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP
microcode: 0x433
Topology: cpus: 1x cores: 8 mt: 4 tpc: 2 st: 4 threads: 12 smt: enabled
cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32 KiB, 4x64 KiB
L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3957 high: 4400 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: performance cores: 1: 4400 2: 4400 3: 4400
4: 4400 5: 4400 6: 4400 7: 4400 8: 4400 9: 3300 10: 2387 11: 3300 12: 3300
bogomips: 59904
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Tongfang Hongkong
driver: i915 v: kernel alternate: xe arch: Gen-12.2 process: Intel 10nm
built: 2021-22+ ports: active: eDP-2 empty: none bus-ID: 00:02.0
chip-ID: 8086:46a3 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile]
vendor: Tongfang Hongkong driver: nvidia v: 555.58.02
alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: none empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 01:00.0
chip-ID: 10de:28a1 class-ID: 0300
Device-3: Kingcome HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 2b7e:b680
Monitor-1: eDP-2 res: 1536x864 size: N/A modes: N/A
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a3 memory: 15.18 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: integrated-gpu
name: Intel Graphics (ADL GT2) driver: mesa intel v: 24.1.4-arch1.2
device-ID: 8086:46a3 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 4050 Laptop GPU driver: nvidia
v: 555.58.02 device-ID: 10de:28a1 surfaces: xcb,xlib,wayland device: 2
v: 24.1.4-arch1.2 (LLVM 18.1.8) device-ID: 10005:0000
vendor: Tongfang Hongkong driver: snd_hda_intel v: kernel
alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA vendor: Tongfang Hongkong driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be
API: ALSA v: k6.9.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
vendor: Tongfang Hongkong driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 8087:0026
Local Storage: total: 931.51 GiB used: 354.71 GiB (38.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR413 temp: 40.9 C
used: 354.71 GiB (38.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.08 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.0 C mobo: N/A
Memory: total: 32 GiB note: est. available: 31.08 GiB used: 5.45 GiB (17.5%)
Processes: 328 Power: uptime: 7m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 12.39 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2097 libs: 595 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-07-04
Last full system update: 2024-07-30
Failed units:```
We[come to the Garuda forum @hby .
You should probably test alternate kernels and try switching to the noveau non-proprietary graphics driver.
https://bbs.archlinux.org/viewtopic.php?id=293400&p=4
Try using X11 instead of Wayland. I’m on a modern AMD system which is supposed to be ideal for Wayland but it freezes constantly if I use it.
To switch back to X11 select it from the drop-down box on the login screen.
