Random freezes with pop ups of not possible to write on system
Hello everyone! Happy new year in advance! First thank you for your willingness here. I´m very happy with Garuda community, helping me on my ¨blocks¨ with this fantastic OS.
I´ve been suffering random freezes in these 2 years using Garuda. Before once a month, and now 2 times a week. I don´t know if this is sw or hw. I tried a lot of things and I guess hw, but I don´t now which one.
Last night I used ¨maldet¨ and after a few minutes appears this:
maldet(3739129): {scan} 21076/1315909 files scanned: 0 hits 0 cleanedfish: Job 1, ´sudo maldet -a´ terminated by signal SIGSEGV (Address boundary error)
And no usable system next. I had to poweroff from power button.
journalctl output:
journalctl --since=today
dic 31 03:39:54 pc-1 systemd-journald[175176]: Journal started
dic 31 03:39:54 pc-1 systemd-journald[175176]: System Journal (/var/log/journal/a1ff9f6148f14aa4b46578f3bdca3cb1) is 48.8M, max 50.0M, 1.1M free.
dic 31 03:39:54 pc-1 kernel: general protection fault, probably for non-canonical address 0x90ac1dbe841aba41: 0000 [#3533] PREEMPT SMP PTI
dic 31 03:39:54 pc-1 kernel: CPU: 6 PID: 162927 Comm: systemd-journal Tainted: P      D    OE      6.6.8-zen1-1-zen #1 2758545fbe9afaf5c07fa2ee57f0b681689ea159
dic 31 03:39:54 pc-1 kernel: Hardware name: HUANANZHI /X99-F8 GAMING, BIOS 5.11 10/29/2022
dic 31 03:39:54 pc-1 kernel: RIP: 0010:kmem_cache_alloc+0x118/0x320
dic 31 03:39:54 pc-1 kernel: Code: 08 0f 84 9b 01 00 00 4d 85 c9 0f 84 92 01 00 00 41 8b 44 24 28 4d 8b 14 24 4c 89 cf 49 89 d0 49 8b 9c 24 b8 00 00 00 4c 01 c8 <48> 33 18 48 89 c1 4>
dic 31 03:39:54 pc-1 kernel: RSP: 0018:ffffc90039b2fc40 EFLAGS: 00010286
dic 31 03:39:54 pc-1 kernel: RAX: 90ac1dbe841aba41 RBX: e03ab8e50f92462e RCX: ffff88903f580000
dic 31 03:39:54 pc-1 kernel: RDX: 0000000014358e06 RSI: 0000000000000040 RDI: 90ac1dbe841ab9d1
dic 31 03:39:54 pc-1 kernel: RBP: ffffc90039b2fc88 R08: 0000000014358e06 R09: 90ac1dbe841ab9d1
dic 31 03:39:54 pc-1 kernel: R10: 000000000003a8a0 R11: 0000000000000000 R12: ffff888100227b00
dic 31 03:39:54 pc-1 kernel: R13: 0000000000000000 R14: 0000000000000dc0 R15: ffff888b98d6f740
dic 31 03:39:54 pc-1 kernel: FS:  00007f106a223ec0(0000) GS:ffff88903f580000(0000) knlGS:0000000000000000
dic 31 03:39:54 pc-1 kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
dic 31 03:39:54 pc-1 kernel: CR2: 00007f1068c5e018 CR3: 0000000bcf514005 CR4: 00000000003706e0
dic 31 03:39:54 pc-1 kernel: DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
dic 31 03:39:54 pc-1 kernel: DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
dic 31 03:39:54 pc-1 kernel: Call Trace:
dic 31 03:39:54 pc-1 kernel:  <TASK>
dic 31 03:39:54 pc-1 kernel:  ? die_addr+0x128/0x130
dic 31 03:39:54 pc-1 kernel:  ? exc_general_protection+0x370/0x480
dic 31 03:39:54 pc-1 kernel:  ? asm_exc_general_protection+0x26/0x30
dic 31 03:39:54 pc-1 kernel:  ? kmem_cache_alloc+0x118/0x320
dic 31 03:39:54 pc-1 kernel:  ? alloc_empty_file+0x52/0x1a0
dic 31 03:39:54 pc-1 kernel:  alloc_empty_file+0x52/0x1a0
dic 31 03:39:54 pc-1 kernel:  path_openat+0x4b/0x14c0
dic 31 03:39:54 pc-1 kernel:  do_filp_open+0xb3/0x160
dic 31 03:39:54 pc-1 kernel:  __x64_sys_openat+0x1d5/0x240
dic 31 03:39:54 pc-1 kernel:  do_syscall_64+0x60/0x90
dic 31 03:39:54 pc-1 kernel:  ? syscall_exit_to_user_mode+0x2b/0x40
dic 31 03:39:54 pc-1 kernel:  ? do_syscall_64+0x6c/0x90
dic 31 03:39:54 pc-1 kernel:  entry_SYSCALL_64_after_hwframe+0x6e/0xd8
dic 31 03:39:54 pc-1 kernel: RIP: 0033:0x7f1069d20c70
dic 31 03:39:54 pc-1 kernel: Code: 48 89 44 24 20 75 94 44 89 54 24 0c e8 19 61 f8 ff 44 8b 54 24 0c 89 da 48 89 ee 41 89 c0 bf 9c ff ff ff b8 01 01 00 00 0f 05 <48> 3d 00 f0 ff ff 7>
dic 31 03:39:54 pc-1 kernel: RSP: 002b:00007ffc4e2f3e10 EFLAGS: 00000293 ORIG_RAX: 0000000000000101
dic 31 03:39:54 pc-1 kernel: RAX: ffffffffffffffda RBX: 0000000000080000 RCX: 00007f1069d20c70
dic 31 03:39:54 pc-1 kernel: RDX: 0000000000080000 RSI: 00007ffc4e2f4080 RDI: 00000000ffffff9c
dic 31 03:39:54 pc-1 kernel: RBP: 00007ffc4e2f4080 R08: 0000000000000000 R09: 0000000000000001
dic 31 03:39:54 pc-1 kernel: R10: 0000000000000000 R11: 0000000000000293 R12: 00007f106a13b774
dic 31 03:39:54 pc-1 kernel: R13: 00007f106a13b774 R14: 0000000000000001 R15: 00007ffc4e2f4050
dic 31 03:39:54 pc-1 kernel:  </TASK>
lines 1-44</kbd>
In the past always happen a lot of time this in a pop up with diferent paths, but always not writable appears:
Configuration file ¨/home/usuario/.config/kioslave5rc" not writable. Please contact your system administrator.
And no usable system.
This is my garuda-inxi output:
Kernel: 6.6.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4006ac11-19d2-4910-b26f-6b7635678308 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 loglevel=3 sysrq_always_enabled=1
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 info: latte-dock
wm: kwin_x11 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: HUANANZHI model: X99-F8 GAMING v: V5.0 serial: <filter>
UEFI: American Megatrends v: 5.11 date: 10/29/2022
Info: model: Intel Xeon E5-2697 v4 socket: LGA2011-3 bits: 64 type: MT MCP
arch: Broadwell level: v3 note: check built: 2015-18 process: Intel 14nm
family: 6 model-id: 0x4F (79) stepping: 1 microcode: 0xB000040
Topology: cpus: 1x cores: 18 tpc: 2 threads: 36 smt: enabled cache:
L1: 1.1 MiB desc: d-18x32 KiB; i-18x32 KiB L2: 4.5 MiB desc: 18x256 KiB
L3: 45 MiB desc: 1x45 MiB
Speed (MHz): avg: 3520 high: 3600 min/max: 1200/3600 base/boost: 2300/4000
scaling: driver: intel_cpufreq governor: performance volts: 0.2 V
ext-clock: 100 MHz cores: 1: 3600 2: 3600 3: 3600 4: 3600 5: 3600 6: 3600
7: 3600 8: 3600 9: 3600 10: 3600 11: 3600 12: 2759 13: 3600 14: 2730
15: 3600 16: 3600 17: 3600 18: 3600 19: 3600 20: 3600 21: 3600 22: 3600
23: 3600 24: 3600 25: 3600 26: 3600 27: 3600 28: 3600 29: 3600 30: 3600
31: 3600 32: 3600 33: 3600 34: 2450 35: 3600 36: 3600 bogomips: 165599
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] vendor: ZOTAC
status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
off: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 03:00.0 chip-ID: 10de:2489
Device-2: Realtek Full HD webcam driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0bda:5187
Device-3: Realtek Full HD webcam driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:4 chip-ID: 0bda:5187
Display: server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau,nvidia
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
s-diag: 1102mm (43.38")
Monitor-1: not-matched mapped: DP-5 pos: primary,left res: 1920x1080
hz: 60 dpi: 92 size: 531x299mm (20.91x11.77") diag: 609mm (23.99")
modes: N/A
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right
model: Acer KA241 serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 92
gamma: 1.2 size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9
Monitor-3: not-matched mapped: None-1-1 size-res: N/A modes: N/A
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.274 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 545.29.06 device-ID: 10de:2489
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.3.1-arch1.1 (LLVM 16.0.6)
Device-1: Intel C610/X99 series HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:8d20 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ZOTAC
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 10de:228b
Device-4: Razer USA Kraken Tournament Edition
lanes: 1 mode: 1.1 bus-ID: 3-13:5 chip-ID: 1532:0520 class-ID: 0300
Device-5: Realtek Full HD webcam driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.6.8-zen1-1-zen status: kernel-api with: osspd status: off
tools: N/A
Server-2: PipeWire v: 1.0.0 status: n/a (root, process) with:
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 476.94 GiB used: 213.66 GiB (44.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Hikvision
model: HS-SSD-C2000Pro 512G size: 476.94 GiB block-size: physical: 512 B
fw-rev: HBAF28FT temp: 24.9 C scheme: GPT
SMART: yes health: PASSED on: 256d 2h cycles: 2,324
read-units: 349,184,761 [178 TB] written-units: 69,727,826 [35.7 TB]
ID-1: / raw-size: 419.9 GiB size: 419.9 GiB (100.00%)
used: 213.63 GiB (50.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 29.8 MiB (10.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 419.9 GiB size: 419.9 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 419.9 GiB size: 419.9 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 419.9 GiB size: 419.9 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 62.69 GiB used: 15 MiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 36 dev: /dev/zram0
System Temperatures: cpu: 20.0 C mobo: N/A gpu: nvidia temp: 24 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 30%
Processes: 538 Uptime: 36m wakeups: 0 Memory: total: 64 GiB
available: 62.69 GiB used: 6.35 GiB (10.1%) Init: systemd v: 255
Packages: 2028 pm: pacman pkgs: 2021 libs: 523
tools: octopi,pamac,paru,pikaur,yay pm: flatpak pkgs: 7
Shell: garuda-inxi (sudo) default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2021-12-05
Last full system update: 2023-12-31
Is partially upgraded:   Yes
Relevant software:       snapper NetworkManager dracut(custom) mkinitcpio nvidia-dkms
Windows dual boot:       Yes
Failed units:            systemd-networkd-wait-online.service upgrade.service
Things tried:
-Memory: Lower memory frequency, disable ECC, change slots, change by anothers with lower frequency
-Changed cpu, psu, board,
I don´t remember if I changed disk and this happen also with my old Ubuntu. I think so, but I´ll try with another disk out of desperation right now, and I´ll update the thread with the result.
-Tried to disable snapshots if this was the cause
¿How can I detect the exact cause? Thanks.
It is not <kbd> use three ~ = ~~~, please, for terminal log output.
I edit your post.
I really loved it, but I’d start removing this.
We replaced it long ago with standard KDE panels which look pretty nice anyway.
https://wiki.garudalinux.org/en/dr460nized-migration
Possibly, also fix this
with a garuda-update.
Last but not least, many useful hints can be found here
Assuming it is not actually a problem with permissions on those files, is there anything in dmesg or journalctl about remounting filesystem read only?
Home is a subvolume or its own partition? Which filesystem (btrfs/ext4/…) if so?
This would make me suspect hardware plays a part.
In this thread [solved] kernel 5.15.2 - general protection fault / Kernel & Hardware / Arch Linux Forums a similar problem was caused by a faulty RAM module.
I’m not saying that’s necessarily the case, but it’s worth checking.
I see you replaced RAM already, but isn’t very clear.
Yes, it could be a problem of RAM speed / frequency.
Run memtest86+ from the GRUB menu.
And double check all connections, maybe something is not making good contact (RAM and disk especially).
What frequency and what RAM modules are installed?
I know next to nothing, but someone may understand something from that.
I considered a compatibility problem, but I couldn’t find anything.
All reports about the motherboard on linux-hardware are good.
Only found reports about sleep not working.
maldet crash may or may not be related with the other issues.
I advise to choose one and stick with it.
My recommendation is octopi and paru or pikaur for the command line.
Again, only one is necessary.
But all of this comes later and is unrelated to the problem.
Thanks to all. It seems hw related, I opened this thread for see if anyone has the same problem and how he resolved it. I go to do a fresh install on another disk and get all your advices.
By now I think the best is to buy a new pc. I´m very tired with this problem 2 years now. Have a nice day!!
Edit: I installed Garuda Dragonized in another disk, all from zero.
Now all works ok, 0 freezes, but the fire test will be in 3 months. I still suspect about the hw. Thanks to all.
Changed the disk, installed system from zero with the latest version downloaded from internet, and yesterday another freeze playing a video on firefox and passing maldet again. 1 week. hw problem again, so no garuda related.
Kernel: 6.6.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=17d372d1-0965-42d5-9e2a-a250e0102569 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Desktop System: HUANANZHI product: N/A v: N/A
Mobo: HUANANZHI model: X99-F8 GAMING v: V5.0 serial: <superuser required>
Info: model: Intel Xeon E5-2697 v4 bits: 64 type: MT MCP arch: Broadwell
level: v3 note: check built: 2015-18 process: Intel 14nm family: 6
Speed (MHz): avg: 3348 high: 3600 min/max: 1200/3600 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3600 2: 3600 3: 3600
4: 2379 5: 3600 6: 3600 7: 3600 8: 3600 9: 1252 10: 3600 11: 1619 12: 3600
13: 3600 14: 3600 15: 3600 16: 1201 17: 3600 18: 3600 19: 3600 20: 3600
21: 3600 22: 3600 23: 3600 24: 3600 25: 3600 26: 3600 27: 3600 28: 2479
29: 3600 30: 3600 31: 3600 32: 3600 33: 3600 34: 3600 35: 3600 36: 3600
bogomips: 165603
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
Monitor-1: DP-3 mapped: DP-5 note: disabled pos: primary,left
memory: 7.81 GiB
API: Vulkan v: 1.3.274 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
surfaces: xcb,xlib
lanes: 1 mode: 1.1 bus-ID: 3-14:6 chip-ID: 1532:0520 class-ID: 0300
API: ALSA v: k6.6.9-zen1-1-zen status: kernel-api with: aoss
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
Local Storage: total: 447.13 GiB used: 15.57 GiB (3.5%)
ID-1: /dev/sda maj-min: 8:0 model: SATA3 480GB SSD size: 447.13 GiB
serial: <filter> fw-rev: 7B0 scheme: GPT
used: 15.57 GiB (3.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 62.69 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 21.0 C mobo: N/A gpu: nvidia temp: 27 C
Processes: 530 Uptime: 59m wakeups: 0 Memory: total: 64 GiB
available: 62.69 GiB used: 7.6 GiB (12.1%) Init: systemd v: 255
pm: pacman pkgs: 1913 libs: 560 tools: octopi,paru,pikaur Shell: fish
v: 3.7.0 running-in: konsole inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2023-12-31
Last full system update: 2024-01-07
If your power supply in your home fluctuates or you suffer from frequent outages buying a new computer may not be your best investment. If you are suffering from frequent hardware failures, unstable power can often be the cause, (especially for hard drives). You may want to consider buying a UPS/backup power source to help keep your power from fluctuating.
The solution for me was to change the RAM. I had Kllisre and changed for Team Group and all changed to good site.
On Windows blue screens happened diary and sometimes more times on the same day. On Garuda once a month and finally once a week.
These problems happened always so I can say is due to incompatibility with mainboard-cpu.
Thanks to all for the support!
