Dear All,
Installed garuda few months ago, all was working well. However, since few weeks, the system has been freezing on idle requiring hard-reboot by pressing reset button. No response on keyboard or trying to get to any tty.
Some of the problems I recently had was with a PSU, that is sorted. For some reason SDDM stopped working for me, and I had to change my DM to Slim. Apart from that, haven't tinkered around much with the system.
Any thoughts?
Host: pc Kernel: 5.14.8-zen1-1-zen x86_64 bits: 64 Desktop: Unity
Distro: Garuda Linux
Type: Desktop System: ASUS product: All Series v: N/A
Mobo: ASUSTeK model: Z97-A v: Rev 1.xx serial: <superuser required>
BIOS: American Megatrends v: 1304 date: 07/11/2014
Info: Quad Core model: Intel Core i7-4790 bits: 64 type: MT MCP cache:
L2: 8 MiB
Speed: 3600 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 3600 2: 3600
3: 3600 4: 3601 5: 3601 6: 3601 7: 3601 8: 3601
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
driver: i915 v: kernel
Device-2: NVIDIA GP104 [GeForce GTX 1080] driver: nvidia v: 470.62.02
Display: x11 server: X.Org 1.20.13 driver: loaded: nvidia resolution:
1: 1920x1080~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2
v: 4.6.0 NVIDIA 470.62.02
driver: snd_hda_intel
Device-2: Intel 9 Series Family HD Audio driver: snd_hda_intel
Device-3: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.14.8-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Device-1: Intel Ethernet I218-V driver: e1000e
IF: eno1 state: up speed: 100 Mbps duplex: full mac: 78:24:af:8a:97:d5
IF-ID-1: anbox0 state: down mac: 66:fc:ed:41:c2:bc
IF-ID-2: docker0 state: down mac: 02:42:8c:af:31:90
IF-ID-3: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 16.03 TiB used: 9.15 TiB (57.1%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT1000P1SSD8 size: 931.51 GiB
ID-2: /dev/sda vendor: Toshiba model: HDWD120 size: 1.82 TiB
ID-3: /dev/sdb vendor: Seagate model: ST2000DM006-2DM164 size: 1.82 TiB
ID-4: /dev/sdc vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
ID-5: /dev/sdd vendor: Seagate model: ST2000DL003-9VT166 size: 1.82 TiB
ID-6: /dev/sde vendor: SanDisk model: SDSSDA120G size: 111.79 GiB
ID-7: /dev/sdf vendor: Western Digital model: WD102KRYZ-01A5AB0
ID-1: / size: 96.16 GiB used: 28.4 GiB (29.5%) fs: btrfs dev: /dev/sde2
ID-2: /home size: 465.76 GiB used: 107.61 GiB (23.1%) fs: btrfs
dev: /dev/sdc1
ID-3: /var/log size: 96.16 GiB used: 28.4 GiB (29.5%) fs: btrfs
dev: /dev/sde2
ID-4: /var/tmp size: 96.16 GiB used: 28.4 GiB (29.5%) fs: btrfs
dev: /dev/sde2
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
dev: /dev/sde1
ID-2: swap-2 type: zram size: 15.5 GiB used: 768 KiB (0.0%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 53 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 51%
Processes: 384 Uptime: 58m Memory: 15.5 GiB used: 5.02 GiB (32.4%)
Shell: Zsh inxi: 3.3.06
