Hello, I'm new to Linux as a primary driver OS, and occasionally the system will start to logout. This is cancelable and looking around on the arch forums, can't seem to find an analogous situation (much of what I can find is immediate logouts, freezes or crashes, which my machine isn't doing). The advice there had me sticking my nose into some logs but I can't understand much of what's there, so I figure I'll ask here.
╰─λ garuda-inxi
Kernel: 6.0.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=8a427227-28ba-444a-8f0a-217559488779 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.0 tk: Qt v: 5.15.6 info: latte-dock
Type: Desktop System: ASUS product: All Series v: N/A
Mobo: ASUSTeK model: H87M-E v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 0401 date: 04/10/2013
Device-1: hidpp_battery_0 model: Logitech Marathon Mouse/Performance Plus
M705 serial: <filter> charge: 10% (should be ignored) rechargeable: yes
Info: model: Intel Core i5-4570 bits: 64 type: MCP arch: Haswell
desc: 1x6 MiB
Speed (MHz): avg: 3498 high: 3600 min/max: 800/3600 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3600 2: 3193 3: 3600
4: 3600 bogomips: 25542
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Tul /
PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0
chip-ID: 1002:73ff class-ID: 0300
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.00x9.37")
s-diag: 449mm (17.69")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Dell E1911 serial: <filter>
built: 2012 res: 1440x900 hz: 60 dpi: 90 gamma: 1.2
size: 408x255mm (16.06x10.04") diag: 481mm (18.9") ratio: 16:10 modes:
max: 1440x900 min: 720x400
OpenGL: renderer: AMD Radeon RX 6600 (navi23 LLVM 14.0.6 DRM 3.48
6.0.1-zen2-1-zen) v: 4.6 Mesa 22.2.1 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 3-10:6 chip-ID: 1130:1620
bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0300 class-ID: 0403
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: Tenx USB AUDIO type: USB
Device-4: Samson GoMic compact condenser microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-9:4 chip-ID: 17a0:0302
Sound API: ALSA v: k6.0.1-zen2-1-zen running: yes
vendor: ASUSTeK H81M-C driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 06:00.0
chip-ID: 168c:0030 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-4.4.3:9 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 6.37 TiB used: 61.5 GiB (0.9%)
model: WD60EZAZ-00SF3B0 size: 5.46 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 61.5 GiB
(6.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
(0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 61.5
GiB (6.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 61.5
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 61.5
ID-1: swap-1 type: zram size: 7.7 GiB used: 1.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 35.0 C
mem: 32.0 C
Processes: 239 Uptime: 3m wakeups: 10 Memory: 7.7 GiB used: 2.43 GiB
(31.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1923 libs: 546
Garuda (2.6.8-1):
System install date: 2022-10-14
Last full system update: 2022-10-14
Snapshots: Timeshift
