Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=160c21e9-cb54-47dc-86eb-e0f663f37903
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Gigabyte product: B460MDS3H v: N/A serial: N/A
Mobo: Gigabyte model: B460M DS3H serial: N/A UEFI: American Megatrends v: F5 date: 11/23/2021
Info: model: Intel Core i5-10600K socket: U3E1 bits: 64 type: MT MCP arch: Comet Lake family: 6
model-id: 0xA5 (165) stepping: 5 microcode: 0xEE
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4681 high: 4700 min/max: 800/4800 base/boost: 3960/8300 scaling:
driver: intel_pstate governor: performance volts: 1.1 V ext-clock: 100 MHz cores: 1: 4699
2: 4655 3: 4675 4: 4655 5: 4696 6: 4614 7: 4700 8: 4692 9: 4700 10: 4695 11: 4697 12: 4700
bogomips: 98397
Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: Micro-Star MSI driver: nvidia v: 510.47.03
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1b82 class-ID: 0300
Display: server: X.Org 1.21.1.3 compositor: kwin_x11 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.6x11.5") s-diag: 600mm (23.6")
Monitor-1: HDMI-0 res: 1920x1080 dpi: 94 size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
OpenGL: renderer: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 510.47.03
direct render: Yes
Device-1: Intel Comet Lake PCH-V cAVS vendor: Gigabyte driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a3f0 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: C-Media KLIM PUMA type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5:4
chip-ID: 0d8c:0012 class-ID: 0300
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
v: kernel port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5020 bus-ID: 00:17.0
chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 1.93 TiB used: 12.6 GiB (0.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P2SSD8 size: 465.76 GiB
rev: P2CR033 temp: 42.9 C scheme: GPT
SMART: yes health: PASSED on: 66d 12h cycles: 488 read-units: 18,039,907 [9.23 TB]
written-units: 33,330,640 [17.0 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD110 family: P300 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: A8J0 temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2
y 72d 19h cycles: 3029
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB family: based SSDs
size: 465.76 GiB block-size: physical: 512 B logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 4B6Q temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 117d 18h cycles: 2310 written: 39.8 TiB
ID-4: /dev/sdc maj-min: 8:32 vendor: Emtec model: X150 120GB size: 111.79 GiB block-size:
physical: 512 B logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD serial: <filter> rev: Sc10
temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 69d 13h cycles: 497 read: 621 KiB
written: 3.1 MiB
ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 12.6 GiB (2.7%) fs: btrfs
block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 12.6 GiB (2.7%) fs: btrfs
ID-4: /var/log raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 12.6 GiB (2.7%) fs: btrfs
ID-5: /var/tmp raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 12.6 GiB (2.7%) fs: btrfs
ID-1: swap-1 type: zram size: 31.28 GiB used: 1024 KiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 40.0 C mobo: 16.8 C gpu: nvidia temp: 49 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 37%
Processes: 344 Uptime: 16m wakeups: 0 Memory: 31.28 GiB used: 3.86 GiB (12.3%) Init: systemd
v: 250 tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1262 lib: 301
Client: shell wrapper v: 5.1.16-release inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-02-10
Last full system update: 2022-02-10
Hello, and first of all, thank you for this incredible distro that is Garuda.
I was wondering, why while having applied the performance options, memavaild, UResourced, nohang and prelockd are not enabled? Are they causing any problems?
