This is my system config:
System: Kernel: 5.10.69-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: root=UUID=9279d3fa-41b3-4a57-8a34-fcde65d58047 rw [email protected]
systemd.unified_cgroup_hierarchy=1 loglevel=3 [email protected]\boot\intel-ucode.img
[email protected]\boot\initramfs-linux-lts.img
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Garuda Linux
Machine: Type: Laptop System: Micro-Star product: GF65 Thin 9SEXR v: REV:1.0 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16W1 v: REV:1.0 serial: <filter> UEFI: American Megatrends
v: E16W1IMS.10B date: 05/19/2020
Battery: ID-1: BAT1 charge: 27.4 Wh (54.8%) condition: 50.0/51.3 Wh (97.4%) volts: 11.6
min: 11.4 model: MSI Corp. MS-16W1 type: Li-ion serial: N/A status: Unknown
ID-2: hidpp_battery_0 charge: N/A condition: N/A volts: 3.8 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A serial: <filter>
status: Discharging
CPU: Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: A (10) microcode: EA cache:
L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38400
Speed: 2400 MHz min/max: 800/2400 MHz Core speeds (MHz): 1: 2400 2: 2400 3: 2380
4: 2400 5: 2400 6: 2400 7: 2400 8: 2400
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Graphics: Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 470.74 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Display: wayland server: X.Org 1.21.1.2 compositor: gnome-shell driver:
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 120 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.2
compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:a348
Device-2: ASUSTek ROG STRIX Go 2.4 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-6:3 chip-ID: 0b05:18d6 class-ID: 0300
Sound Server-1: ALSA v: k5.10.69-1-lts running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Network: Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel port: 5000
vendor: Micro-Star MSI driver: r8169 v: kernel port: 3000 bus-ID: 04:00.0
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb
v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Drives: Local Storage: total: 1.4 TiB used: 76.31 GiB (5.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: N/A size: 953.87 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: RKT303.3 temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: LITE-ON model: CL1-8D512 size: 476.94 GiB
serial: <filter> rev: 1.00 temp: 42.9 C scheme: GPT
Partition: ID-1: / raw-size: 290 GiB size: 290 GiB (100.00%) used: 76.24 GiB (26.3%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%) used: 78.6 MiB (26.6%)
fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
ID-3: /home raw-size: 290 GiB size: 290 GiB (100.00%) used: 76.24 GiB (26.3%)
ID-4: /var/log raw-size: 290 GiB size: 290 GiB (100.00%) used: 76.24 GiB (26.3%)
ID-5: /var/tmp raw-size: 290 GiB size: 290 GiB (100.00%) used: 76.24 GiB (26.3%)
ID-1: swap-1 type: zram size: 15.48 GiB used: 0 KiB (0.0%) priority: 100
Sensors: System Temperatures: cpu: 67.0 C mobo: N/A
Info: Processes: 320 Uptime: 4m wakeups: 3 Memory: 15.48 GiB used: 3.4 GiB (21.9%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 alt: 8 clang: 12.0.1
Packages: pacman: 1613 lib: 383 Shell: Zsh v: 5.8 running-in: tilix inxi: 3.3.06
as the title says I have noticed from the qt5 settings app that the theme is not the same as when I first installed this OS. Right now the themes that are showing up are: Adwaita, Adwaita-Dark, AdwaitaHighContrast, AdwaitaHighContrastInverse, HighContrast, HighContrastInverse, kvantum, kvantum-dark, windows and fusion. I recently removed some packages that were flagged as orphans, and I don't know if one of them is the one responsible of the default look of qt5 apps. Can someone tell me what theme was the default and/or from which package I can get if from? Thanks a ton in advance
