qBittorrent and side panel
Side panel looks…idk, interesting in Wayland and X11. Yep, I can hide it in menu when I don’t need that panel but I’d like to see qBittorent fully functional. So, what should I do? Help me, please.
In addition, looks like that’s only one program which has that kind of issue, including other Qt programs.
╭─astro@garuda in ~
╰─λ garuda-inxi
Kernel: 6.9.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=f53b173c-2c57-4e5c-b506-ac412b1c7f3a rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Desktop System: Gigabyte product: H610M S2H V2 DDR4 v: -CF
Mobo: Gigabyte model: H610M S2H V2 DDR4 v: x.x
Megatrends LLC. v: F26 date: 08/31/2023
Info: model: 12th Gen Intel Core i5-12400F bits: 64 type: MT MCP
microcode: 0x35
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 1093 high: 4323 min/max: 800/4400 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 4323 11: 800 12: 800
bogomips: 59904
Device-1: NVIDIA GP104 [GeForce GTX 1060 3GB] driver: nvidia v: 555.58.02
2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: HDMI-A-1 empty: DP-1, DP-2, DP-3, DVI-D-1 bus-ID: 01:00.0
chip-ID: 10de:1b84 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
s-diag: 610mm (24")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: HP 24w
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
max: 1920x1080 min: 640x480
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060
3GB/PCIe/SSE2 memory: 2.93 GiB
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 3GB driver: nvidia v: 555.58.02 device-ID: 10de:1b84
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 18.1.8 256
bits) driver: mesa llvmpipe v: 24.1.4-arch1.2 (LLVM 18.1.8)
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
API: ALSA v: k6.9.10-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 3.78 TiB used: 1.23 TiB (32.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: DGSM3001TS33T size: 953.87 GiB
tech: SSD serial: <filter> fw-rev: V1013A0 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EARS-00Y5B1
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 0A80 scheme: MBR
model: WD10EZEX-00BN5A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
model: WD10EZEX-00RKKA0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 model: SSD 128GB size: 119.24 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 6313 scheme: MBR
used: 146.23 GiB (15.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.18 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 119.24 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdd1 maj-min: 8:49
System Temperatures: cpu: 43.0 C mobo: 34.0 C gpu: nvidia temp: 41 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 25%
Memory: total: 32 GiB available: 31.19 GiB used: 9.98 GiB (32.0%)
Processes: 412 Power: uptime: 3h 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.43 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2175 libs: 609 tools: octopi,pamac,paru,yay
Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date:     2024-07-04
Last full system update: 2024-07-20 ↻
I played with a scale a bit.
Not a solution but it lets me use qBittorrent at least.
Exec=env QT_AUTO_SCREEN_SCALE_FACTOR=0 QT_SCALE_FACTOR=1.01 qbittorrent
Oh you’re right, there’s a bug in the left panel drawing.
Resizing the window forces a redraw though, so it’s usable… but definitely annoying.
I’m in a fresh Garuda install and in it in both Wayland and x11 and in my previous install of Garuda there are no issues with qBittorrent look.
