Python-vdf conflict
HI
I have been unable to update my garuda machines due to a conflict.
python-vdf-solstice-3.5-1 and python-vdf-3.4-3 are in conflict. Remove python-vdf? [y/N] y
When i try to confirm the removal i get an error
Unexpected user input required. Try again without --noconfirm
I found a thread where someone encountered this conflict. But it seems they were able to confirm the removal just fine.
https://forum.garudalinux.org/t/garuda-update-conflict-between-python-vdf-solstice-and-python-vdf/38486/4
Kernel: 6.10.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=6a8a01fd-1dfe-48f8-8b4d-c2c38ad8ec88 rw rootflags=subvol=@
quiet resume=UUID=61fcd7d4-37c6-41ce-8991-c45faf6c34ec loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Desktop System: Gigabyte product: X570S AORUS PRO AX v: -CF
Mobo: Gigabyte model: X570S AORUS PRO AX serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F6c
date: 09/20/2023
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3928 high: 4749 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4000 2: 3700
3: 4500 4: 4071 5: 3700 6: 3599 7: 3841 8: 3700 9: 4654 10: 3681 11: 3810
12: 3838 13: 3687 14: 3789 15: 3700 16: 3700 17: 3700 18: 3700 19: 3807
20: 3676 21: 4727 22: 3785 23: 4159 24: 4749 bogomips: 177588
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3,Writeback-1 bus-ID: 0d:00.0
chip-ID: 1002:744c class-ID: 0300
gpu: amdgpu d-rect: 5360x2520 display-ID: 0
Monitor-1: DP-1 pos: bottom-l res: 3440x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: top-right res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.4-arch1.2
navi31 LLVM 18.1.8 DRM 3.57 6.10.1-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 15 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.1.4-arch1.2
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.4-arch1.2 (LLVM 18.1.8) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:ab30
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS GameDAC driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-2.2:5
chip-ID: 1038:1282 class-ID: 0300 serial: <filter>
API: ALSA v: k6.10.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0608
Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
IF: enp7s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: xone-dongle
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-6.3:5
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
wpa_supplicant
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-5:2 chip-ID: 0e8d:0608
Local Storage: total: 4.32 TiB used: 1.29 TiB (29.9%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Kingston model: SNV2S500G
lanes: 4 tech: SSD serial: <filter> fw-rev: EJFK3N.7 temp: 54.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 25.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1
tech: SSD serial: <filter> fw-rev: 054 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 2TB
ID-1: / raw-size: 431.11 GiB size: 431.11 GiB (100.00%)
used: 355.1 GiB (82.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 27.4 MiB (9.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 431.11 GiB size: 431.11 GiB (100.00%)
ID-4: /var/log raw-size: 431.11 GiB size: 431.11 GiB (100.00%)
ID-5: /var/tmp raw-size: 431.11 GiB size: 431.11 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.23 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.36 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:5
System Temperatures: cpu: 48.2 C mobo: 34.0 C gpu: amdgpu temp: 42.0 C
mem: 54.0 C
Memory: total: 32 GiB available: 31.23 GiB used: 8.95 GiB (28.6%)
Processes: 509 Power: uptime: 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
Packages: pm: dpkg pkgs: 0 tools: apt,apt-get pm: pacman pkgs: 2210
libs: 576 tools: octopi,paru Compilers: clang: 18.1.8 gcc: 14.1.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: yakuake inxi: 3.3.35
System install date:     2024-04-19
Last full system update: 2024-07-31
Is partially upgraded:   Yes
Failed units:            nmb.service systemd-vconsole-setup.service
have you tried it without the --nocofirm as the error states?
Not sure why it would cause issues, but you should be able to manually replace just fine. There might be a different unexpected conflict (after the python-vdf conflict), so try doing without --nocofirm anyways.
yeah i have tried the --noconfirm and it still gives the prompt.
╰─λ garuda-update --noconfirm
[sudo] password for mitchell:
garuda is up to date
core is up to date
extra        7.2 MiB  91.8 KiB/s 01:21 [-------------------------------------------------------------------------------------------------------------------] 100%
multilib is up to date
chaotic-aur        758.8 KiB   414 KiB/s 00:02 [-------------------------------------------------------------------------------------------------------------------] 100%
spawn pacman -Su
resolving dependencies...
:: python-vdf-solstice-3.5-1 and python-vdf-3.4-3 are in conflict. Remove python-vdf? [y/N]
Sorry i misread you reply. I originally did not use --noconfirm. Eitherway it says the same thing
[đź”´] Ă— garuda-update
core is up to date
extra is up to date
chaotic-aur is up to date
spawn pacman -Su
:: python-vdf-solstice-3.5-1 and python-vdf-3.4-3 are in conflict. Remove python-vdf? [y/N] y
Unexpected user input required. Try again without --noconfirm⏎
Please check /etc/garuda/garuda-update/config to make sure you didn’t set --noconfirm (PACMAN_NOCONFIRM=1) in there
yep that was it. Thanks for the help
