Python-playsound package signature is invalid
Having trouble updating my system thanks to some invalid signature.
Here's the issue:
error: python-playsound: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/python-playsound-1.3.0-2.2-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: failed to commit transaction (invalid or corrupted package)
Here's my garuda-inxi:
[🔴] × garuda-inxi
        LANGUAGE = "en_GB:en_US:fi",
        LC_ALL = (unset),
        LC_ADDRESS = "fi_FI.UTF-8",
        LC_NAME = "fi_FI.UTF-8",
        LC_MONETARY = "fi_FI.UTF-8",
        LC_PAPER = "fi_FI.UTF-8",
        LC_IDENTIFICATION = "fi_FI.UTF-8",
        LC_TELEPHONE = "fi_FI.UTF-8",
        LC_MEASUREMENT = "fi_FI.UTF-8",
        LC_CTYPE = "fi_FI.UTF-8",
        LC_TIME = "fi_FI.UTF-8",
        LC_COLLATE = "fi_FI.UTF-8",
        LC_NUMERIC = "fi_FI.UTF-8",
        LANG = "en_FI.UTF-8"
perl: warning: Falling back to the standard locale ("C").
  Kernel: 6.3.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=33b92acc-eae1-4daf-86a1-a400c31bc857 rw rootflags=subvol=@
    splash intel_iommu=on rd.udev.log_priority=3 vt.global_cursor_default=0
    systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
  Type: Desktop Mobo: ASRock model: Z370 Gaming-ITX/ac
    serial: <superuser required> UEFI: American Megatrends v: P4.30
    date: 11/01/2019
  Device-1: hidpp_battery_0 model: Logitech MX Keys WirelessMX W
  Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 3 MiB desc: 12x256 KiB
    L3: 144 MiB desc: 12x12 MiB
  Speed (MHz): avg: 800 high: 801 min/max: 800/5100 scaling:
    5: 801 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 88796
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASRock
    ports: active: DP-3 empty: DP-1, DP-2, DP-4, HDMI-A-1, HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0300
  Device-2: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Sapphire
    off: DP-6 empty: DP-5,DP-7,HDMI-A-3 bus-ID: 03:00.0 chip-ID: 1002:73bf
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: kwin_wayland driver: X: loaded: intel unloaded: amdgpu dri: i965
    gpu: amdgpu,i915 display-ID: 0
  Monitor-1: DP-3 model: BenQ EX3501R serial: <filter> built: 2019
    res: 3440x1440 dpi: 107 gamma: 1.2 size: 819x346mm (32.24x13.62")
    diag: 889mm (35") modes: max: 3440x1440 min: 720x400
  Monitor-2: DP-6 model: BenQ EX3501R serial: <filter> built: 2019
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) direct-render: Yes
  Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel bus-ID: 1-5.3:6 chip-ID: 1038:1297 alternate: snd_soc_avs
    bus-ID: 00:1f.3 class-ID: 0300 chip-ID: 8086:a2f0 class-ID: 0403
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
  Device-3: SteelSeries ApS Arctis Pro Wireless type: USB
  API: ALSA v: k6.3.1-zen1-1-zen status: kernel-api with: aoss
  Server-1: JACK v: 1.9.22 status: off tools: N/A
  Server-2: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
  Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
    bus-ID: 06:00.0 chip-ID: 14e4:43a0 class-ID: 0280
  IF: wlp6s0 state: dormant mac: <filter>
  Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
    bus-ID: 1-14.3:11 chip-ID: 05ac:828f class-ID: fe01
  Local Storage: total: 2.67 TiB used: 2.41 TiB (90.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
    lanes: 4 type: SSD serial: <filter> rev: R0906I temp: 38.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
    type: SSD serial: <filter> rev: 2B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU800 size: 1.86 TiB
    serial: <filter> rev: 7A
  ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 840 PRO Series
    type: SSD serial: <filter> rev: 6B0Q scheme: GPT
  ID-1: / raw-size: 39.26 GiB size: 39.26 GiB (100.00%)
    used: 28.59 GiB (72.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 437.18 GiB size: 437.18 GiB (100.00%)
    used: 419.99 GiB (96.1%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-4: /var/log raw-size: 39.26 GiB size: 39.26 GiB (100.00%)
  ID-5: /var/tmp raw-size: 39.26 GiB size: 39.26 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.02 GiB used: 84 KiB (0.0%) priority: 100
  System Temperatures: cpu: 33.0 C mobo: 34.0 C gpu: amdgpu temp: 32.0 C
    mem: 32.0 C
  Fan Speeds (RPM): fan-1: 535 fan-2: 4017 fan-3: 824 fan-4: 0 fan-5: 0
    gpu: amdgpu fan: 0
  Power: 12v: N/A 5v: N/A 3.3v: 3.34 vbat: 3.18 gpu: amdgpu watts: 6.00
  Processes: 417 Uptime: 7h 25m wakeups: 8 Memory: 31.02 GiB
  used: 8.35 GiB (26.9%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 2305 libs: 613 tools: pamac,paru pm: rpm pkgs: 0 Shell: Zsh v: 5.9
  System install date:     2021-05-05
  Last full system update: 2023-05-04
  Relevant software:       timeshift NetworkManager mkinitcpio
  Failed units:            fancontrol.service preload.service samba.service vncserver-virtuald.service vncserver-x11-serviced.service
I've already tried updating mirror lists and keyrings.
Updated also chaotic-keyring?
Or garuda-update does it at first.
