root=UUID=b885927a-d504-47a0-85f0-6c4abb2ecb37 rw rootflags=subvol=@
Type: Desktop Mobo: ASRock model: B550 Phantom Gaming 4
serial: <superuser required> UEFI: American Megatrends v: P1.20
date: 08/13/2020
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3812 high: 4079 min/max: 2200/4559 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3900
2: 3900 3: 3900 4: 3900 5: 3900 6: 3900 7: 3727 8: 3900 9: 4079
10: 3595 11: 3592 12: 3766 13: 3612 14: 3685 15: 3900 16: 3746
bogomips: 124567
svm
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASRock
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0b:00.0
chip-ID: 1002:73ff class-ID: 0300
Device-2: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3
chip-ID: 0c45:6537 class-ID: 0102 serial: <filter>
compositor: Hyprland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 1
Monitor-1: HDMI-A-1 model: LG (GoldStar) ULTRAWIDE serial: <filter>
built: 2016 res: 2560x1080 hz: 60 dpi: 81 gamma: 1.2 scale: 1
size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes:
max: 2560x1080 min: 720x400
API: Vulkan v: 1.3.269 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 XT (RADV NAVI23) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73ff surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Oculus VR Rift S
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.2:4 chip-ID: 2833:0051
Device-4: Kingston HyperX 7.1 Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:5 chip-ID: 0951:16a4
Device-5: C-Media Blue Snowball
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 0d8c:0005
Device-6: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.85 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:24fd
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:7
chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 4.09 TiB used: 3.24 TiB (79.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte
model: GP-ASM2NE6100TTTD size: 931.51 GiB block-size: physical: 512 B
fw-rev: EGFM13.0 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM006-2DM164
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: CC26
scheme: MBR
model: WDS100T2B0A-00SM50 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 00WD
scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 850 EVO 250GB
ID-1: / raw-size: 32.23 GiB size: 32.23 GiB (100.00%)
used: 22.29 GiB (69.2%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 800 MiB size: 798.4 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 525.11 GiB size: 515.8 GiB (98.23%)
used: 473.74 GiB (91.8%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 32.23 GiB size: 32.23 GiB (100.00%)
ID-5: /var/tmp raw-size: 32.23 GiB size: 32.23 GiB (100.00%)
zswap: no
ID-1: swap-1 type: zram size: 15.54 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: partition size: 19.61 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p8 maj-min: 259:8
System Temperatures: cpu: 55.8 C mobo: N/A gpu: amdgpu temp: 38.0 C
mem: 36.0 C
Processes: 472 Uptime: 3m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 4.17 GiB (26.8%) Init: systemd v: 254
pm: pacman pkgs: 1675 libs: 521 tools: octopi,paru Shell: fish v: 3.6.1
running-in: foot inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-06
Last full system update: 2023-11-20
So, I’ve been fiddling with this for days and I’m getting nowhere. My goal is just stratchpads. My config for pyrpland is as follows -
pyprland.toml
[pyprland]
plugins = ["scratchpads"]
pyprland.json
"pyprland": {
"plugins": [
"scratchpads",
"monitors",
"workspaces_follow_focus"
"scratchpads": {
"footterm": {
"command": "footclient --class scratchpad",
"margin": 50,
"animation": "fromTop",
"unfocus": "hide"
"volume": {
"command": "pavucontrol",
"animation": "fromRight"
"monitors": {
"placement": {
"LG-ULTRAWIDE": {
"topOf": "HDMI-A-1"
"unknown": "wlrlui"
hyprland.conf
exec-once = pypr
$scratchpad = class:^(scratchpad)$
windowrulev2 = float, $scratchpad
windowrulev2 = workspace special silent, $scratchpad
bind = $mainMod, Y, exec, pypr toggle term
bind = $mainMod, S, exec, pypr toggle volume
windowrule = float,^(pavucontrol)$
windowrule = size 40% 90%,^(pavucontrol)$
windowrule = move 200% 5%,^(pavucontrol)$
windowrule = workspace special:scratch_volume silent,^(pavucontrol)$
And finally, the issue currently is that the pypr command promptly crashes, with this error -
[🔴] × pypr
Error initializing plugin scratchpads:
File "/home/scrubby/.local/pipx/venvs/pyprland/lib/python3.11/site-packages/pyprland/command.py", line 61, in load_config
await self.plugins[name].load_config(self.config)
File "/home/scrubby/.local/pipx/venvs/pyprland/lib/python3.11/site-packages/pyprland/plugins/scratchpads.py", line 335, in load_config
if await self.ensure_alive(name):
File "/home/scrubby/.local/pipx/venvs/pyprland/lib/python3.11/site-packages/pyprland/plugins/scratchpads.py", line 350, in ensure_alive
await self.start_scratch_command(uid)
File "/home/scrubby/.local/pipx/venvs/pyprland/lib/python3.11/site-packages/pyprland/plugins/scratchpads.py", line 371, in start_scratch_command
scratch.conf["command"],
KeyError: 'command'
Exception ignored in: <function StreamWriter.__del__ at 0x7fbe1aa18ae0>
File "/usr/lib/python3.11/asyncio/streams.py", line 396, in __del__
self.close()
File "/usr/lib/python3.11/asyncio/streams.py", line 344, in close
return self._transport.close()
File "/usr/lib/python3.11/asyncio/selector_events.py", line 860, in close
self._loop.call_soon(self._call_connection_lost, None)
File "/usr/lib/python3.11/asyncio/base_events.py", line 761, in call_soon
self._check_closed()
File "/usr/lib/python3.11/asyncio/base_events.py", line 519, in _check_closed
raise RuntimeError('Event loop is closed')
RuntimeError: Event loop is closed
I feel like I’m missing something with the config here, but I dunno what. Sorry if my formatting with this post is a mess.
