Hello, I am having issues on my desktop trying to launch games through proton using steam as well as OBS isnt launching which IDK if that is related or not.
Steps tried:
Konsole: "sudo pacman -S nvidia-utils"
Konsole: "sudo pacman -S lib32-nvidia-utils"
Konsole: "sudo pacman -S vulkan-icd-loader"
Looked up game (farming simulator) on Proton DB:
- Tried proton-GE
- Tried modifying config file (as suggested)
- Tried adding launch commands
Strange thing is that I didn't have any issues with my Laptop with the game, but I am having issues on my desktop. The laptop was able to boot into the live environment with the propriatary drivers boot option but I had to use open source drivers to boot into live environment on desktop.
Specs:
Laptop (no issues)
- Dell Latitude E5450
- Intel Core i7-5600U, 2 Core/4 Thread @3.20GHz
- RAM 16GB
- Geforce 840M
Desktop (having issues)
- ASRock X570 Taichi
- AMD Ryzen 9 3950X, 16 Core/ 32 Thread @ 3.50GHz
- Ram 32GB
- Zotac GeForce 3080Ti
garuda-inxi results:
Kernel: 6.1.5-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=48ef13db-0351-45d2-a882-ea5cf057d193 rw [email protected]
quiet resume=UUID=b8969c79-6451-4d93-9640-00a8a9849a0d loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: X570 Taichi serial: <superuser required>
UEFI: American Megatrends v: P4.60 date: 08/03/2021
Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2 gen: 3
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2281 high: 3500 min/max: 2200/4761 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3500 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 17: 3500 18: 2200 19: 2200
20: 2200 21: 2200 22: 2200 23: 2199 24: 2200 25: 2200 26: 2200 27: 2200
28: 2200 29: 2200 30: 2200 31: 2200 32: 2200 bogomips: 224003
Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] vendor: ZOTAC driver: nvidia
v: 525.78.01 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 0e:00.0 chip-ID: 10de:2208
Device-2: Valve 3D Camera type: USB driver: uvcvideo bus-ID: 2-1.1.1.1:5
chip-ID: 28de:2400 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 7040x1440 s-size: <missing: xdpyinfo>
Monitor-1: DP-2 pos: top-left res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: DP-4 pos: primary,top-center res: 2560x1440 hz: 60 dpi: 109
Monitor-3: HDMI-0 pos: bottom-r res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.39x12.76") diag: 611mm (24.05") modes: N/A
missing.
Device-1: NVIDIA GA102 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus-ID: 1-5:5 pcie: chip-ID: 413c:a503
class-ID: 0300 gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 0e:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 10:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Dell AC511 Sound Bar type: USB
Device-4: Valve VR Radio type: USB driver: cdc_acm,hid-generic,usbhid
bus-ID: 3-4.1.1.3.2:14 chip-ID: 28de:2102 class-ID: 0a00 serial: <filter>
Device-5: Valve VR Radio & HMD Mic type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4.1.1.3.3:15
chip-ID: 28de:2102 class-ID: 0102 serial: <filter>
Sound API: ALSA v: k6.1.5-zen2-1-zen running: yes
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:2
chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Local Storage: total: 8.67 TiB used: 244.2 GiB (2.7%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: KIOXIA
model: KXG60ZNV512G NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 10604106 temp: 50.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 type: SSD serial: <filter> rev: 42AZS6AC temp: 36.9 C scheme: GPT
model: WDS200T2B0A-00SM50 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 40WD
model: WD6003FZBX-00GXAB0 size: 5.46 TiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 919.17 GiB size: 919.17 GiB (100.00%)
used: 22.04 GiB (2.4%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 919.17 GiB size: 919.17 GiB (100.00%)
ID-4: /var/log raw-size: 919.17 GiB size: 919.17 GiB (100.00%)
ID-5: /var/tmp raw-size: 919.17 GiB size: 919.17 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.39 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:3
ID-2: swap-2 type: zram size: 31.27 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 42 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 47%
Processes: 539 Uptime: 17h 56m wakeups: 0 Memory: 31.27 GiB
used: 8.91 GiB (28.5%) Init: systemd v: 252 default: graphical
pkgs: 1333 libs: 460 tools: pamac Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-12
Last full system update: 2023-01-17 ↻
