hey, how do i make so i can run apps without them being closed if i exit the Konsole?
for example, sometimes Latte-Dock doesn't stay on screen and disappears during the boot, if i start it again with the konsole latte-dock --Replace
it works but i have to keep that konsole instance always on, same when i use a Flatpak app (have to use flatpak now since the python update killed the compiled one, waiting for update)
Kernel: 5.15.11-230-tkg-pds x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: intel_pstate=passive BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-pds
root=UUID=a2edb1d1-2b71-4078-8e7e-5c1eddf533f9 rw rootflags=subvol=@
quiet
cryptdevice=UUID=53f62651-9e7c-4ac4-9ddc-9ae7a1225771:luks-53f62651-9e7c-4ac4-9ddc-9ae7a1225771
root=/dev/mapper/luks-53f62651-9e7c-4ac4-9ddc-9ae7a1225771 splash
Type: Desktop System: Micro-Star product: MS-7B79 v: 3.0
Mobo: Micro-Star model: X470 GAMING PLUS MAX (MS-7B79) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.C0
date: 05/18/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4274 high: 4275 min/max: N/A cores: 1: 4275 2: 4274
3: 4275 4: 4275 5: 4273 6: 4275 7: 4275 8: 4273 9: 4275 10: 4275 11: 4275
12: 4275 13: 4275 14: 4275 15: 4275 16: 4275 bogomips: 136939
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA TU104 [GeForce RTX 2080 Rev. A] vendor: ASUSTeK
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 27:00.0
chip-ID: 10de:1e87 class-ID: 0300
loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 122 s-size: 533x302mm (21.0x11.9")
s-diag: 613mm (24.1")
Monitor-1: DP-4 res: 2560x1440 dpi: 123 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: NVIDIA GeForce RTX 2080/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 27:00.1 chip-ID: 10de:10f8 class-ID: 0403
driver: snd_hda_intel v: kernel bus-ID: 29:00.4 chip-ID: 1022:1487
Sound Server-1: ALSA v: k5.15.11-230-tkg-pds running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 22:00.0
Local Storage: total: 1.56 TiB used: 875.37 GiB (54.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1CH162
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC49
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37480G
type: SSD serial: <filter> rev: 1103 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SUV400S37240G
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 37R5 scheme: GPT
ID-1: / raw-size: 223.31 GiB size: 223.31 GiB (100.00%)
used: 92.59 GiB (41.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-53f62651-9e7c-4ac4-9ddc-9ae7a1225771
used: 706 KiB (0.3%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 223.31 GiB size: 223.31 GiB (100.00%)
ID-4: /var/log raw-size: 223.31 GiB size: 223.31 GiB (100.00%)
ID-5: /var/tmp raw-size: 223.31 GiB size: 223.31 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.61 GiB used: 1.69 GiB (10.8%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 47 C
Fan Speeds (RPM): cpu: 0 gpu: nvidia fan: 0%
Processes: 437 Uptime: 22m wakeups: 1 Memory: 15.61 GiB
used: 5.26 GiB (33.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1828 pacman: 1812 lib: 505 flatpak: 16
Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.11
