I've been using Garuda for a while now. I have a problem with no data being downloaded. I'm connected so everything looks good, but no data.I have another small eee computer that I run Mx Linux and there it works well. Does anyone have a solution maybe
Hi there @pata66. Sorry to say it, but that's nowhere near enough information to make an informed assessment of your problem.
If you have no network connection, then try to use Android USB phone tethering for a temporary internet connection. Once you can get online please post the output of the following command:
inxi -Fxxxza
Please do not post the output as a picture.
system:
Kernel: 5.8.13-zen1-2-zen x86_64 bits: 64 compiler: N/A
root=UUID=474078bb-cc6e-4f8a-ba01-e4083faee863 rw rootflags=subvol=@
quiet splash resume=UUID=290248bc-30ac-4d73-a8ec-7a38048d553f
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Garuda Linux
Type: Laptop System: Hewlett-Packard
product: HP Pavilion 15 Notebook PC v: 0975100000405F10000620180
Mobo: Hewlett-Packard model: 2281 v: 77.35 serial: <filter>
UEFI [Legacy]: Insyde v: F.42 date: 03/18/2015
ID-1: BAT0 charge: 34.6 Wh condition: 34.6/34.6 Wh (100%)
volts: 16.8/14.8 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: Full
Info: Dual Core model: Intel Core i5-4210U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26
L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 19156
Speed: 1950 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 1696
2: 1696 3: 1697 4: 1700
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes,
SMT vulnerable
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
Device-2: NVIDIA GM108M [GeForce 840M] vendor: Hewlett-Packard
driver: nouveau v: kernel bus ID: 0a:00.0 chip ID: 10de:1341
Device-3: Suyin type: USB driver: uvcvideo bus ID: 1-1.3:3
chip ID: 064e:c341 serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
driver: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (20.0x11.2")
s-diag: 582mm (22.9")
Monitor-1: HDMI1 res: 1920x1080 hz: 60 dpi: 81
size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 20.2.0 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
Sound Server: ALSA v: k5.8.13-zen1-2-zen
Device-1: Broadcom and subsidiaries BCM43142 802.11b/g/n
vendor: Hewlett-Packard driver: wl v: kernel port: 6040 bus ID: 08:00.0
chip ID: 14e4:4365
IF: wlo1 state: dormant mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000
bus ID: 09:00.0 chip ID: 10ec:8136
Local Storage: total: 465.76 GiB used: 17.97 GiB (3.9%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS545050A7E680
size: 465.76 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: AH10
scheme: MBR
ID-1: / raw size: 456.96 GiB size: 456.96 GiB (100.00%)
used: 17.97 GiB (3.9%) fs: btrfs dev: /dev/sda1
ID-2: /home raw size: 456.96 GiB size: 456.96 GiB (100.00%)
ID-3: /var/log raw size: 456.96 GiB size: 456.96 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2
ID-2: swap-2 type: zram size: 493.2 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 493.2 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 493.2 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 493.2 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram3
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 235 Uptime: 9h 34m Memory: 7.71 GiB used: 2.25 GiB (29.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1898 lib: 559 flatpak: 0 Shell: Zsh v: 5.8 running in: konsole
inxi: 3.1.06
@pata66 Please use ~~~ in first and last raw of terminal output if </> not work correct.
Kernel: 5.8.14-zen1-1-zen x86_64 bits: 64 compiler: N/A
ID-1: BAT0 charge: 35.0 Wh condition: 35.0/35.0 Wh (100%)
L2 cache: 3072 KiB
bogomips: 19156
Speed: 2395 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 2395
2: 2395 3: 2649 4: 2395
SMT vulnerable
Sound Server: ALSA v: k5.8.14-zen1-1-zen
chip ID: 14e4:4365
Local Storage: total: 469.49 GiB used: 33.88 GiB (7.2%)
scheme: MBR
ID-2: /dev/sdb type: USB vendor: SanDisk model: Cruzer Blade
size: 3.73 GiB block size: physical: 512 B logical: 512 B
serial: <filter> rev: 1.26 scheme: MBR
used: 33.88 GiB (7.4%) fs: btrfs dev: /dev/sda1
ID-2: swap-2 type: zram size: 493.2 MiB used: 87.7 MiB (17.8%)
ID-3: swap-3 type: zram size: 493.2 MiB used: 82.1 MiB (16.6%)
ID-4: swap-4 type: zram size: 493.2 MiB used: 85.3 MiB (17.3%)
ID-5: swap-5 type: zram size: 493.2 MiB used: 86.0 MiB (17.4%)
System Temperatures: cpu: 59.0 C mobo: N/A
Processes: 246 Uptime: 2h 17m Memory: 7.71 GiB used: 2.97 GiB (38.5%)
pacman: 1900 lib: 559 flatpak: 0 Shell: Zsh v: 5.8 running in: konsole
inxi: 3.1.06 ~~~
I'm guessing you have no Ethernet connection either (as the output is registering as down for your wired adapter). You can use Android USB phone tethering if you need a working connection to make it easier to post diagnostic outputs. When running commands to diagnose issues with your wifi make sure you have no alternate internet connection activated (ie Ethernet or tethering).
With no connections active except your WiFi run:
ping -c5 8.8.8.8
ping -c5 google.com
Please post the outputs of those command as text (no pictures please)
Also:
cat /etc/resolv.conf
I got it started with Android USB phone tethering
Then I started the Network-Assistant tool and after that, it seems to work.
Thanks so much for your help
