Hello,
I had some issues regarding the newest nvidia-dkms driver 465.24.02 and the zen-kernel 5.11.15:
After a fresh install of Garuda GNOME and an update to the whole system, the Desktop did not start correctly. Only starting with mode 3 on the grub menu allows me to login.
Sadly, I did not find any useful hints in the journalctl regarding nvidia or the kernel regarding the problem.
Finally, I decided, to downgrade the nvidia-packages with:
sudo pacman -U /var/cache/pacman/pkg/nvidia-dkms-460.67-1-x86_64.pkg.tar.zst /var/cache/pacman/pkg/nvidia-utils-460.67-1-x86_64.pkg.tar.zst /var/cache/pacman/pkg/nvidia-settings-460.67-1-x86_64.pkg.tar.zst
and I could login to the desktop again.
Maybe, someone can give me some hints, what went wrong and how can I solve this issue without downgrading the driver.
Thank you and best regards
