I have proprietary nvidia driver but yesterday when i installed it i got driver version/library mismatch or something similar. im very new to garuda linux and never used arch based before. sometimes the UI animations and stuff arent fluid at all and have "Low fps" if that makes sense. its probably not a big deal but i wanna know if other people have that issue and if its fixable. The error is gone now without me doing anything but i still have the problem with the OS lagging sometimes which is weird since i have a very good pc and it should have no issue with graphical stuff at all
System: Kernel: 5.15.3-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=a62ecb5f-ee51-4c71-b36a-d9afae9c881b
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: NZXT model: N7 B550 serial: <filter> UEFI: American Megatrends v: P1.20
date: 03/02/2021
CPU: Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 71 (113) stepping: 0 microcode: 8701021 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 114991
Speed: 3594 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 3594 2: 3557
3: 3842 4: 3597 5: 3597 6: 3607 7: 3586 8: 3578 9: 3820 10: 3576 11: 4001 12: 3742 13: 3865
14: 3946 15: 3976 16: 3598
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA vendor: ASUSTeK driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm
bus-ID: 06:00.0 chip-ID: 10de:2488 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.6x11.5") s-diag: 600mm (23.6")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44 direct render: Yes
Audio: Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 06:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Razer USA RZ04-0318 Gaming Headset [Kraken Ultimate] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4.2:9 chip-ID: 1532:0527 class-ID: 0300
Sound Server-1: ALSA v: k5.15.3-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel port: f000
bus-ID: 04:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel bus-ID: 05:00.0
Bluetooth: Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-8:8 chip-ID: 8087:0032
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: N/A
Drives: Local Storage: total: 2.29 TiB used: 21.91 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 2B2QGXA7 temp: 26.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4B6Q
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1B6Q
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Generic model: Flash Disk size: 14.65 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter> rev: 8.07 scheme: MBR
Partition: ID-1: / raw-size: 931 GiB size: 931 GiB (100.00%) used: 21.91 GiB (2.4%) fs: btrfs
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%) used: 4.9 MiB (1.0%) fs: vfat
ID-3: /home raw-size: 931 GiB size: 931 GiB (100.00%) used: 21.91 GiB (2.4%) fs: btrfs
ID-4: /var/log raw-size: 931 GiB size: 931 GiB (100.00%) used: 21.91 GiB (2.4%) fs: btrfs
ID-5: /var/tmp raw-size: 931 GiB size: 931 GiB (100.00%) used: 21.91 GiB (2.4%) fs: btrfs
ID-1: swap-1 type: zram size: 31.28 GiB used: 2.2 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 29 C
Fan Speeds (RPM): fan-2: 1477 fan-3: 1522 fan-4: 1511 gpu: nvidia fan: 0%
Info: Processes: 377 Uptime: 15m wakeups: 0 Memory: 31.28 GiB used: 3.44 GiB (11.0%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1678 lib: 492 Shell: fish
v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
If you include terminal outputs in your post please use the proper output format in your post.
Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
