My microphone records only some static. No discernible sounds or voice can be heard. I tried troubleshooting it myself but have given up (as far as for tonight) Here's' the console output:
Kernel: 5.18.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=4ce2de8b-3f8d-4880-ab59-341f27b61e16 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.0 tk: Qt v: 5.15.4 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: Z170-P D3 v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2604
date: 02/22/2018
Info: model: Intel Core i5-6600K bits: 64 type: MCP arch: Skylake-S
gen: core 6 built: 2015 process: Intel 14nm family: 6 model-id: 0x5E (94)
stepping: 3 microcode: 0xF0
desc: 1x6 MiB
Speed (MHz): avg: 4251 high: 4291 min/max: 800/4300 scaling:
driver: intel_pstate governor: performance cores: 1: 4202 2: 4291 3: 4279
4: 4235 bogomips: 27999
STIBP: disabled, RSB filling
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN 4
ports: active: HDMI-A-2 empty: DP-1, DP-2, DVI-D-1, HDMI-A-1
bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
Monitor-1: HDMI-A-2 mapped: HDMI-A-1 model: Dell S2340L serial: <filter>
built: 2015 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
OpenGL: renderer: AMD Radeon RX 470 Graphics (polaris10 LLVM 13.0.1 DRM
3.46 5.18.1-zen1-1-zen)
v: 4.6 Mesa 22.1.1 direct render: Yes
**Audio:**
**Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK**
**driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170**
**class-ID: 0403**
**Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]**
**vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3**
**speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403**
**Sound Server-1: ALSA v: k5.18.1-zen1-1-zen running: yes**
**Sound Server-2: JACK v: 1.9.21 running: no**
**Sound Server-3: PulseAudio v: 16.0 running: no**
**Sound Server-4: PipeWire v: 0.3.52 running: yes**
vendor: ASUSTeK AM1I-A driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.14 TiB used: 209.89 GiB (17.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Biostar model: M700-256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S0614B0
temp: 48.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC45
ID-1: / raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
used: 209.89 GiB (88.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 563 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
ID-4: /var/log raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.57 GiB used: 344.5 MiB (2.2%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 57.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1145
Processes: 260 Uptime: 6h 22m wakeups: 9 Memory: 15.57 GiB
used: 4.56 GiB (29.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1440
lib: 451 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.18
Garuda (2.6.3-2):
System install date: 2021-09-24
Last full system update: 2022-06-19 ↻
Snapshots: Timeshift
