I have problems with my keyboard when I writing windows open by themselves, like I used a shortcut, and for example
If I used any windows like a Konsole happens the same thing, and when I used the scroll of my mouse in the browser
go back one page, or if I used it in other windows like the Konsole Zoom in or zoom.
I have no idea why.
System: Kernel: 5.13.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=cb5e739f-8061-4b88-bcf9-2c57bf58b7ee
systemd.unified_cgroup_hierarchy=1 resume=UUID=907130b5-0a45-4a3f-b30e-0113d15e9eeb loglevel=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Hewlett-Packard product: HP Pavilion Notebook v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 80B1 v: 82.29 serial: <filter> UEFI: American Megatrends v: F.45
date: 05/02/2017
Battery: ID-1: BAT0 charge: 18.0 Wh (100.0%) condition: 18.0/18.0 Wh (100.0%) volts: 16.9 min: 14.8
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Not charging cycles: 161
CPU: Info: Quad Core model: AMD A8-7410 APU with AMD Radeon R5 Graphics bits: 64 type: MCP
arch: Puma family: 16 (22) model-id: 30 (48) stepping: 1 microcode: 7030105 cache: L2: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 17566
Speed: 2261 MHz min/max: 1000/2200 MHz boost: enabled Core speeds (MHz): 1: 2261 2: 2267
3: 2259 4: 2074
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard driver: radeon v: kernel
alternate: amdgpu bus-ID: 00:01.0 chip-ID: 1002:9851 class-ID: 0300
Device-2: Realtek HP Truevision HD type: USB driver: uvcvideo bus-ID: 2-1.2:3
chip-ID: 0bda:57c4 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: ati,radeon
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 112 size: 309x173mm (12.2x6.8") diag: 354mm (13.9")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.13.12-zen1-1-zen LLVM 12.0.1) v: 4.5 Mesa 21.2.0
direct render: Yes
Audio: Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.13.12-zen1-1-zen running: yes
Network: Device-1: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl v: kernel
modules: bcma port: f100 bus-ID: 02:00.0 chip-ID: 14e4:4365 class-ID: 0280
IF: wlo1 state: dormant mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard driver: r8169
v: kernel port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-3: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS] type: USB driver: r8188eu bus-ID: 3-2:3
chip-ID: 2357:010c class-ID: 0000 serial: <filter>
IF: wlp0s16u2 state: up mac: <filter>
Bluetooth: Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8 bus-ID: 1-1.3:3
chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter>
Drives: Local Storage: total: 223.57 GiB used: 40.07 GiB (17.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU630 size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00K0 scheme: GPT
Partition: ID-1: / raw-size: 211.61 GiB size: 211.61 GiB (100.00%) used: 40.07 GiB (18.9%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 211.61 GiB size: 211.61 GiB (100.00%) used: 40.07 GiB (18.9%) fs: btrfs
ID-4: /var/log raw-size: 211.61 GiB size: 211.61 GiB (100.00%) used: 40.07 GiB (18.9%)
ID-5: /var/tmp raw-size: 211.61 GiB size: 211.61 GiB (100.00%) used: 40.07 GiB (18.9%)
ID-1: swap-1 type: partition size: 11.71 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 10.64 GiB used: 66.2 MiB (0.6%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 74.5 C mobo: N/A gpu: radeon temp: 75.0 C
Info: Processes: 225 Uptime: 1h 23m wakeups: 1 Memory: 10.64 GiB used: 5.01 GiB (47.1%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1223 lib: 319
Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.06
