I'm having problems with the gpu configuration because it doesn't appear as a primary in Konsole, and I noticed that some games are crashing because the gpu isn't working properly (nvidia gtx 1050 ti). Thanks for the help I'm new to everything in linux including file types.
Here is the output.
Kernel: 5.18.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=33cb89e6-1286-4cae-82e9-4acb61ba8a3b rw [email protected]
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: BIOSTAR model: Hi-Fi H77S v: 5.0
serial: <superuser required> BIOS: American Megatrends v: 4.6.5
date: 12/21/2012
Info: model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 built: 2012-15 process: Intel 22nm family: 6
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1721 high: 1941 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1771 2: 1720 3: 1631
4: 1673 5: 1941 6: 1680 7: 1651 8: 1703 bogomips: 54272
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: NVIDIA GP107 [GeForce GTX 1050] vendor: ASUSTeK driver: nvidia
v: 470.129.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c81 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia
Screen-1: 0 s-res: 1360x768 s-dpi: 84 s-size: 410x232mm (16.14x9.13")
s-diag: 471mm (18.55")
Monitor-1: HDMI-0 res: 1360x768 hz: 60 dpi: 32
size: 1073x818mm (42.24x32.2") diag: 1349mm (53.12") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
v: 4.6.0 NVIDIA 470.129.06 direct render: Yes
vendor: Biostar Microtech Intl Corp driver: snd_hda_intel v: kernel
bus-ID: 1-1.3:3 chip-ID: 8086:0808 bus-ID: 00:1b.0 class-ID: 0300
Device-2: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
Device-3: Intel USB PnP Sound Device type: USB
Sound Server-1: ALSA v: k5.18.13-zen1-1-zen running: yes
vendor: Biostar Microtech Intl Corp driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
IF-ID-2: enp0s26u1u4 state: unknown speed: -1 duplex: half mac: <filter>
Local Storage: total: 698.65 GiB used: 121.66 GiB (17.4%)
model: WD5000LPVX-80V0TT0 size: 465.76 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3250820AS
size: 232.88 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: C
ID-1: / raw-size: 175.76 GiB size: 175.76 GiB (100.00%)
used: 121.66 GiB (69.2%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
ID-2: /home raw-size: 175.76 GiB size: 175.76 GiB (100.00%)
ID-3: /var/log raw-size: 175.76 GiB size: 175.76 GiB (100.00%)
ID-4: /var/tmp raw-size: 175.76 GiB size: 175.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.73 GiB used: 27 MiB (0.3%) priority: 100
System Temperatures: cpu: 38.0 C mobo: N/A gpu: nvidia temp: 33 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 256 Uptime: 1h 41m wakeups: 0 Memory: 7.73 GiB
used: 4.12 GiB (53.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1694 lib: 488
Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-07-03
Last full system update: 2022-07-24
Failed units: bluetooth-autoconnect.service systemd-networkd-wait-online.service
Thanks.
filo
24 July 2022 18:03
#2
Hi there welcome to the forum.
Your garuda-inxi shows only one GPU
Do you have another one?
It could be disabled in the BIOS.
What does konsole show?
miguelnl:
This could be something else. Let's clarify the above first. Probably it could be better to address this after with a dedicated topic, being more specific with the affected games, providing logs, etc.
filo
24 July 2022 18:08
#3
Wait, the driver is wrong.
I think your GPU is still supported with the latest version.
How did you install it?
It was installed using Garuda Assistant.
I also have this installed GPU: Intel HD Graphics 4000.
OS: Garuda Linux x86_64
Host: Hi-Fi H77S 5.0
Uptime: 6 hours, 10 mins
Packages: 1695 (pacman)[stable]
Shell: fish 3.4.1
Resolution: 1360x768
DE: KDE Plasma 5.25.3
WM: KWin (X11)
WM Theme: Sweet-Dark
Theme: kvantum-dark Sweetified [Plasma], Sweet-Dark [GTK2/3]
Icons: BeautyLine [Plasma], BeautyLine [GTK2/3/4]
Terminal: konsole
Terminal Font: FiraCode Nerd Font Mono 12
CPU: Intel Core i7-3770 (8) @ 3.9GHz
Memory: 3631MiB / 7912MiB
Here is the imput.
Here is the output.
date: 12/21/2012
Speed (MHz): avg: 1911 high: 2694 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1904 2: 1725 3: 1681
4: 2694 5: 1961 6: 1861 7: 1742 8: 1721 bogomips: 54272
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c81 class-ID: 0300
bus-ID: 1-1.3:3 chip-ID: 8086:0808 bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0300 class-ID: 0403
vendor: Biostar Microtech Intl Corp driver: N/A modules: r8169 pcie: gen: 1
Local Storage: total: 698.65 GiB used: 124.67 GiB (17.8%)
used: 124.67 GiB (70.9%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
ID-1: swap-1 type: zram size: 7.73 GiB used: 309.5 MiB (3.9%)
System Temperatures: cpu: 40.0 C mobo: N/A gpu: nvidia temp: 32 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Processes: 263 Uptime: 7h 24m wakeups: 0 Memory: 7.73 GiB
used: 3.93 GiB (50.9%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1697 lib: 489
inxi: 3.3.19
Garuda (2.6.5-1):
Last full system update: 2022-07-24 â»
Here is the imput.
mhwd -li
Hers is the output.
λ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-470xx-dkms 2022.06.14 false PCI
network-r8168 2020.05.22 true PCI
video-linux 2021.08.29 true PCI
video-modesetting 2020.07.13 true PCI
Warning: No installed USB configs!
filo
25 July 2022 05:52
#8
I see... Your inxi should have shown a GPU like
Intel 3rd Gen Core processor Graphics
Did you have a chance to check in the BIOS if you have a setting, whatever the name and location e g. to use dGPU only?
filo
25 July 2022 06:03
#9
miguelnl:
I'm not so technically expert on MHWD, I only saw with a simple forum search that there are many user with your exact model and drivers 515.xxx, so I haven't cross-checked at nvidia site, and I think it is not needed.
My suggestion would be to try
sudo mhwd -r pci video-nvidia-470xx-dkms
sudo mhwd -a pci nonfree 0300
and reboot, but maybe hang on a little bit to see if someone that knows better comes across the thread.
I think I have seen a recent change on this, Intel changed exposed description.
If this is the case, maybe inxi needs to modify its discovery method.
I suggest using lspci
to confirm, instead of relying on inxi only.
Here is the imput.
lspci
Here is the output.
λ lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.2 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 3 (rev c4)
00:1c.3 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 4 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation H77 Express Chipset LPC Controller (rev 04)
00:1f.2 IDE interface: Intel Corporation 7 Series/C210 Series Chipset Family 4-port SATA Controller [IDE mode](rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C216 Chipset Family SMBus Controller (rev 04)
00:1f.5 IDE interface: Intel Corporation 7 Series/C210 Series Chipset Family 2-port SATA Controller [IDE mode](rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation GP107 [GeForce GTX 1050] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 07)
04:00.0 PCI bridge: Integrated Technology Express, Inc. IT8893E PCIe to PCI Bridge (rev 41)
Here is the imput.
Here is the output.
> Removing video-nvidia-470xx-dkms...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-nvidia-470xx-dkms/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
verificando dependĂȘncias...
erro: falha ao preparar a transação (nĂŁo foi possĂvel satisfazer as dependĂȘncias)
:: a remoção de garuda-nvidia-470xx-config quebra a dependĂȘncia "garuda-nvidia-470xx-config" necessĂĄria por garuda-nvidia-470xx-prime-config
Error: pacman failed!
Error: script failed!
> Using config 'video-nvidia-dkms' for device: 0000:01:00.0 (0300:10de:1c81) Display controller nVidia Corporation GP107 [GeForce GTX 1050]
Error: config 'video-nvidia-dkms' conflicts with config(s): video-nvidia-470xx-dkms
Try this:
LC_ALL=C sudo pacman -S nvidia-dkms nvidia-utils lib32-nvidia-utils
then reboot. The LC_ALL=C
part will display the output in English so we can read it.
SGS
25 July 2022 19:56
#14
BTW, you are making a lot of work for yourself unnecessarily.
If we want to have terminal output here and talk about input and output, we want to see if the command was not accidentally misspelled. A separate enumeration is sometimes counterproductive and also just makes more work.
I hope this tip is helpful and I could clear up a misunderstanding.
As I said I'm new to all of this, so I'm sorry for something like that and thanks for the tip.
SGS
25 July 2022 20:07
#16
All fine, no sorry needed.
