Problems with an update
So here is the problem. Running sudo garuda-update installs these packages or tries to install them I should say.
chaotic-aur/brave-bin                      1:1.60.118-1     1:1.60.125-1       0.01 MiB
extra/discord                              0.0.35-1         0.0.36-1           0.01 MiB
extra/fzf                                  0.43.0-1         0.44.1-1           0.01 MiB
chaotic-aur/libgbinder                     1.1.34-2         1.1.35-1           0.00 MiB
extra/linux-zen                            6.6.2.zen1-1     6.6.3.zen1-1      -0.08 MiB
extra/linux-zen-headers                    6.6.2.zen1-1     6.6.3.zen1-1       2.01 MiB
extra/plasma-wayland-protocols             1.11.1-1         1.11.1-2           0.00 MiB
extra/python-attrs                         22.2.0-3         23.1.0-1           0.02 MiB
extra/python-setuptools                    1:68.1.2-1       1:68.2.0-1         0.02 MiB
extra/qt6-base                             6.6.0-3          6.6.1-1            0.04 MiB
extra/qt6-declarative                      6.6.0-1          6.6.1-1            0.00 MiB
extra/qt6-imageformats                     6.6.0-1          6.6.1-1            0.00 MiB
extra/qt6-svg                              6.6.0-2          6.6.1-1            0.00 MiB
extra/qt6-translations                     6.6.0-1          6.6.1-1            0.10 MiB
extra/qt6-wayland                          6.6.0-2          6.6.1-1            0.01 MiB
chaotic-aur/retroarch-autoconfig-udev-git  r2194.2ca1cea-1  r2196.9476f58-1    0.00 MiB
extra/shaderc                              2023.5-1         2023.7-2           0.00 MiB
extra/telegram-desktop                     4.11.8-1         4.11.8-2           0.00 MiB
extra/thunderbird                          115.5.0-1        115.5.1-1          0.00 MiB
multilib/winetricks                        20230212-1       20230212-2         0.00 MiB
After the update the booting and shutting down is very very slow. On booting the monitor goes on and off about 7 times. There are also some spots on boot screen. Once the system is logged in its running fine. Then the shutdown is also very very slow. I have had to use snapper to get back to normal. I’ve tried the update two times and both times are the same effect. Any help would be greatly appreciated, I love Garuda but I’m stuck with not being able to update anything at the moment.
My garuda-inxi is
Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=f55db9ba-a175-4729-a3cf-3a581950eeb2 rw rootflags=subvol=@
nvidia-drm.modeset=1 ibt=off
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> BIOS: American Megatrends v: 3405
date: 02/01/2021
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3999 high: 4000 min/max: 2200/6090 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4000 2: 4000
3: 4000 4: 4000 5: 4000 6: 4000 7: 4000 8: 4000 9: 4000 10: 4000 11: 4000
12: 4000 13: 4000 14: 4000 15: 4000 16: 4000 17: 4000 18: 4000 19: 4000
20: 4000 21: 4000 22: 4000 23: 4000 24: 4000 25: 4000 26: 4000 27: 4000
28: 3998 29: 4000 30: 4000 31: 4000 32: 4000 bogomips: 255998
Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] vendor: Gigabyte driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-3,HDMI-A-2 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 0a:00.0 chip-ID: 10de:2208 class-ID: 0300
Device-2: Linux Foundation EEM Gadget driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2
chip-ID: 1d6b:0102 class-ID: 0102
Screen-1: 0 s-res: 5760x2160 s-dpi: 154 s-size: 950x361mm (37.40x14.21")
s-diag: 1016mm (40.01")
Monitor-1: DP-3 mapped: DP-4 note: disabled pos: primary,top-right
model: Samsung LU28R55 serial: <filter> built: 2020 res: 3840x2160 hz: 60
dpi: 154 gamma: 1.2 size: 632x360mm (24.88x14.17") diag: 727mm (28.6")
ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: HDMI-A-2 mapped: HDMI-1 note: disabled pos: bottom-l
model: Acer K272HL serial: <filter> built: 2016 res: 1920x1080 hz: 60
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.3.269 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3080 Ti driver: nvidia v: 545.29.06 device-ID: 10de:2208
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: NVIDIA GA102 High Definition Audio vendor: Gigabyte
bus-ID: 0a:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-3: Linux Foundation EEM Gadget driver: snd-usb-audio,uvcvideo
Device-4: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:4
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2526 class-ID: 0280
lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 30.26 TiB used: 245.26 GiB (0.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 953.87 GiB
tech: SSD serial: <filter> fw-rev: ECFM13.3 temp: 36.9 C scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Western Digital
model: WD BLACK SN850 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 611100WD temp: 47.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Utania model: OOS10000G size: 9.1 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: N/A fw-rev: OOS1 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Utania model: OOS10000G size: 9.1 TiB
rpm: 7200 serial: <filter> fw-rev: OOS1 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Utania model: OOS10000G size: 9.1 TiB
ID-6: /dev/sdd maj-min: 8:48 model: SATA SSD size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 61.3 scheme: GPT
ID-1: / raw-size: 953.86 GiB size: 953.86 GiB (100.00%)
used: 245.26 GiB (25.7%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 953.86 GiB size: 953.86 GiB (100.00%)
ID-3: /var/log raw-size: 953.86 GiB size: 953.86 GiB (100.00%)
ID-4: /var/tmp raw-size: 953.86 GiB size: 953.86 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.7 GiB used: 512 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 40.0 C mobo: 44.0 C gpu: nvidia temp: 57 C
Fan Speeds (rpm): fan-1: 688 fan-2: 1982 fan-3: 751 fan-4: 809 fan-5: 2928
fan-6: 4179 fan-7: 1991 gpu: nvidia fan: 55%
Processes: 539 Uptime: 5m wakeups: 0 Memory: total: 64 GiB note: est.
available: 62.7 GiB used: 4.86 GiB (7.8%) Init: systemd v: 254
pm: pacman pkgs: 1879 libs: 532 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.19-2):
System install date:     2023-11-21
Last full system update: 2023-11-28
Can you post the output from systemd-analyze --no-pager blame?
7.031s nmb.service
5.572s NetworkManager-wait-online.service
4.438s dev-disk-by\x2ddiskseq-4\x2dpart1.device
4.438s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d6\x2dpart1.device
4.438s dev-disk-by\x2dpartuuid-b39d9ae6\x2d3396\x2d4091\x2d9e4b\x2d8aa51985c177.device
4.438s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d6.0\x2dpart1.device
4.438s dev-disk-by\x2dlabel-New\x5cx20Volume.device
4.438s dev-disk-by\x2duuid-3A5CA5835CA53B11.device
4.438s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:0a.0-0000:09:00.0-ata7-host6-target6:0:0-6:0:…
4.438s dev-disk-by\x2did-ata\x2dSATA_SSD_21030924000975\x2dpart1.device
4.438s dev-sdd1.device
4.436s dev-disk-by\x2dpartlabel-Basic\x5cx20data\x5cx20partition.device
4.424s dev-ttyS9.device
4.424s sys-devices-platform-serial8250-tty-ttyS9.device
4.424s dev-ttyS7.device
4.424s sys-devices-platform-serial8250-tty-ttyS7.device
4.424s dev-sdd.device
4.424s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:0a.0-0000:09:00.0-ata7-host6-target6:0:0-6:0:…
4.424s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d6.0.device
4.424s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d6.device
4.424s dev-disk-by\x2did-ata\x2dSATA_SSD_21030924000975.device
4.424s dev-disk-by\x2ddiskseq-4.device
4.424s dev-ttyS8.device
4.424s sys-devices-platform-serial8250-tty-ttyS8.device
4.422s sys-devices-platform-serial8250-tty-ttyS5.device
4.422s dev-ttyS5.device
4.421s dev-ttyS4.device
4.421s sys-devices-platform-serial8250-tty-ttyS4.device
4.421s sys-devices-platform-serial8250-tty-ttyS6.device
4.421s dev-ttyS6.device
4.421s sys-devices-platform-serial8250-tty-ttyS31.device
4.421s dev-ttyS31.device
4.418s sys-devices-platform-serial8250-tty-ttyS30.device
4.418s dev-ttyS30.device
4.383s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d5.device
4.383s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d5.0.device
4.383s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:0a.0-0000:09:00.0-ata6-host5-target5:0:0-5:0:…
4.383s dev-disk-by\x2did-ata\x2dOOS10000G_00000000.device
4.383s dev-sdc.device
4.383s dev-disk-by\x2ddiskseq-3.device
4.383s dev-disk-by\x2did-wwn\x2d0x5000c500a4e2a7d5.device
4.381s dev-sda.device
4.381s dev-disk-by\x2ddiskseq-1.device
4.381s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d1.0.device
4.381s dev-disk-by\x2did-wwn\x2d0x5000c500b00c16b0.device
4.381s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d1.device
4.381s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:0a.0-0000:09:00.0-ata2-host1-target1:0:0-1:0:…
4.372s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:0a.0-0000:09:00.0-ata3-host2-target2:0:0-2:0:…
4.372s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d2.device
4.372s dev-disk-by\x2did-wwn\x2d0x5000c500a3cb6fc6.device
4.372s dev-sdb.device
4.372s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d2.0.device
4.372s dev-disk-by\x2ddiskseq-2.device
4.352s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d5.0\x2dpart1.device
4.352s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:0a.0-0000:09:00.0-ata6-host5-target5:0:0-5:0:…
4.352s dev-disk-by\x2did-wwn\x2d0x5000c500a4e2a7d5\x2dpart1.device
4.352s dev-sdc1.device
4.352s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d5\x2dpart1.device
4.352s dev-disk-by\x2did-ata\x2dOOS10000G_00000000\x2dpart1.device
4.352s dev-disk-by\x2dpartuuid-08d376b1\x2db131\x2d47dc\x2d8e8d\x2d62fe43338430.device
4.352s dev-disk-by\x2ddiskseq-3\x2dpart1.device
4.340s dev-disk-by\x2dpartlabel-Microsoft\x5cx20reserved\x5cx20partition.device
4.333s dev-disk-by\x2did-wwn\x2d0x5000c500a3cb6fc6\x2dpart1.device
4.333s dev-sdb1.device
4.333s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:0a.0-0000:09:00.0-ata3-host2-target2:0:0-2:0:…
4.333s dev-disk-by\x2dpartuuid-7e75cc33\x2d61e8\x2d4650\x2d863e\x2dd508bab03962.device
4.333s dev-disk-by\x2ddiskseq-2\x2dpart1.device
4.333s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d2\x2dpart1.device
4.333s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d2.0\x2dpart1.device
4.302s dev-disk-by\x2dpartuuid-28bf906d\x2d8a49\x2d43ad\x2d8dae\x2d172b2deced78.device
4.302s dev-sda1.device
4.302s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d1.0\x2dpart1.device
4.302s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:0a.0-0000:09:00.0-ata2-host1-target1:0:0-1:0:…
4.302s dev-disk-by\x2did-wwn\x2d0x5000c500b00c16b0\x2dpart1.device
4.302s dev-disk-by\x2ddiskseq-1\x2dpart1.device
4.302s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d1\x2dpart1.device
4.297s dev-disk-by\x2did-wwn\x2d0x5000c500a4e2a7d5\x2dpart2.device
4.297s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d5.0\x2dpart2.device
4.297s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d5\x2dpart2.device
4.297s dev-disk-by\x2dpartuuid-25dc4abd\x2df3b0\x2d488c\x2d9fae\x2d6ed0e96f66b6.device
4.297s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:0a.0-0000:09:00.0-ata6-host5-target5:0:0-5:0:…
4.297s dev-sdc2.device
4.297s dev-disk-by\x2ddiskseq-3\x2dpart2.device
4.297s dev-disk-by\x2duuid-422E2B5F2E2B4AED.device
4.293s dev-disk-by\x2did-ata\x2dOOS10000G_00000000\x2dpart2.device
4.267s dev-disk-by\x2did-wwn\x2d0x5000c500a3cb6fc6\x2dpart2.device
4.267s dev-disk-by\x2dpartuuid-864e9811\x2d7aff\x2d4151\x2dba0c\x2d21c427340147.device
4.267s dev-disk-by\x2ddiskseq-2\x2dpart2.device
4.267s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:0a.0-0000:09:00.0-ata3-host2-target2:0:0-2:0:…
4.267s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d2.0\x2dpart2.device
4.267s dev-sdb2.device
4.267s dev-disk-by\x2duuid-CC30B05D30B05066.device
4.267s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d2\x2dpart2.device
4.247s dev-disk-by\x2duuid-C8468D21468D10FC.device
4.247s dev-disk-by\x2ddiskseq-1\x2dpart2.device
4.247s dev-disk-by\x2dpartuuid-9980c380\x2da1db\x2d4afe\x2d8f5e\x2d4413bea541ae.device
4.247s dev-sda2.device
4.247s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:0a.0-0000:09:00.0-ata2-host1-target1:0:0-1:0:…
4.247s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d1\x2dpart2.device
4.247s dev-disk-by\x2dpath-pci\x2d0000:09:00.0\x2data\x2d1.0\x2dpart2.device
4.247s dev-disk-by\x2did-wwn\x2d0x5000c500b00c16b0\x2dpart2.device
4.181s sys-module-configfs.device
4.170s sys-devices-platform-serial8250-tty-ttyS1.device
4.170s dev-ttyS1.device
4.170s dev-ttyS10.device
4.170s sys-devices-platform-serial8250-tty-ttyS10.device
4.170s sys-devices-platform-serial8250-tty-ttyS11.device
4.170s dev-ttyS11.device
4.169s dev-ttyS14.device
4.169s sys-devices-platform-serial8250-tty-ttyS14.device
4.169s sys-devices-platform-serial8250-tty-ttyS12.device
4.169s dev-ttyS12.device
4.169s dev-ttyS13.device
4.169s sys-devices-platform-serial8250-tty-ttyS13.device
4.168s dev-ttyS15.device
4.168s sys-devices-platform-serial8250-tty-ttyS15.device
4.168s dev-ttyS16.device
4.168s sys-devices-platform-serial8250-tty-ttyS16.device
4.168s dev-ttyS17.device
4.168s sys-devices-platform-serial8250-tty-ttyS17.device
4.167s dev-ttyS18.device
4.167s sys-devices-platform-serial8250-tty-ttyS18.device
4.167s sys-devices-platform-serial8250-tty-ttyS19.device
4.167s dev-ttyS19.device
4.167s dev-ttyS2.device
4.167s sys-devices-platform-serial8250-tty-ttyS2.device
4.166s dev-ttyS20.device
4.166s sys-devices-platform-serial8250-tty-ttyS20.device
4.166s sys-devices-platform-serial8250-tty-ttyS21.device
4.166s dev-ttyS21.device
4.166s dev-ttyS24.device
4.166s sys-devices-platform-serial8250-tty-ttyS24.device
4.165s dev-ttyS25.device
4.165s sys-devices-platform-serial8250-tty-ttyS25.device
4.165s sys-devices-platform-serial8250-tty-ttyS27.device
4.165s dev-ttyS27.device
4.165s dev-ttyS23.device
4.165s sys-devices-platform-serial8250-tty-ttyS23.device
4.165s dev-ttyS28.device
4.165s sys-devices-platform-serial8250-tty-ttyS28.device
4.164s sys-devices-platform-serial8250-tty-ttyS29.device
4.164s dev-ttyS29.device
4.164s dev-ttyS3.device
4.164s sys-devices-platform-serial8250-tty-ttyS3.device
4.164s dev-ttyS26.device
4.164s sys-devices-platform-serial8250-tty-ttyS26.device
4.163s sys-devices-platform-serial8250-tty-ttyS22.device
4.163s dev-ttyS22.device
4.160s dev-ttyS0.device
4.160s sys-devices-pnp0-00:04-tty-ttyS0.device
4.096s dev-disk-by\x2did-nvme\x2deui.e8238fa6bf530001001b448b492d489c\x2dpart2.device
4.096s dev-disk-by\x2did-nvme\x2dWD_BLACK_SN850_2TB_204704800642\x2dpart2.device
4.096s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart2.device
4.096s dev-disk-by\x2dpartuuid-b9d5b2e8\x2d3d52\x2d438d\x2dac11\x2dd9d1080a9d57.device
4.096s dev-disk-by\x2did-nvme\x2dWD_BLACK_SN850_2TB_204704800642_1\x2dpart2.device
4.096s dev-nvme1n1p2.device
4.096s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:01.0-0000:04:00.0-nvme-nvme1-nvme1n1-nvme1n1p…
4.096s dev-disk-by\x2ddiskseq-6\x2dpart2.device
4.095s dev-disk-by\x2ddiskseq-6\x2dpart3.device
4.095s dev-disk-by\x2did-nvme\x2deui.e8238fa6bf530001001b448b492d489c\x2dpart3.device
4.095s dev-disk-by\x2duuid-0C2EED472EED2A82.device
4.095s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:01.0-0000:04:00.0-nvme-nvme1-nvme1n1-nvme1n1p…
4.095s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart3.device
4.095s dev-disk-by\x2dpartuuid-12198ace\x2d72e0\x2d4829\x2db894\x2d16b230699d90.device
4.095s dev-disk-by\x2did-nvme\x2dWD_BLACK_SN850_2TB_204704800642_1\x2dpart3.device
4.095s dev-nvme1n1p3.device
4.095s dev-disk-by\x2did-nvme\x2dWD_BLACK_SN850_2TB_204704800642\x2dpart3.device
4.091s dev-nvme1n1p1.device
4.091s dev-disk-by\x2dpartlabel-EFI\x5cx20system\x5cx20partition.device
4.091s dev-disk-by\x2dpartuuid-3ed740e4\x2d95b6\x2d4d8d\x2dadee\x2d53ac475ef1dc.device
4.091s dev-disk-by\x2did-nvme\x2dWD_BLACK_SN850_2TB_204704800642\x2dpart1.device
4.091s dev-disk-by\x2did-nvme\x2deui.e8238fa6bf530001001b448b492d489c\x2dpart1.device
4.091s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:01.0-0000:04:00.0-nvme-nvme1-nvme1n1-nvme1n1p…
4.091s dev-disk-by\x2ddiskseq-6\x2dpart1.device
4.091s dev-disk-by\x2did-nvme\x2dWD_BLACK_SN850_2TB_204704800642_1\x2dpart1.device
4.091s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1\x2dpart1.device
4.091s dev-disk-by\x2duuid-68DA\x2dCE55.device
4.087s dev-disk-by\x2did-nvme\x2dWD_BLACK_SN850_2TB_204704800642_1.device
4.087s dev-disk-by\x2ddiskseq-6.device
4.087s dev-disk-by\x2dpath-pci\x2d0000:04:00.0\x2dnvme\x2d1.device
4.087s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:01.0-0000:04:00.0-nvme-nvme1-nvme1n1.device
4.087s dev-nvme1n1.device
4.087s dev-disk-by\x2did-nvme\x2deui.e8238fa6bf530001001b448b492d489c.device
4.087s dev-disk-by\x2did-nvme\x2dWD_BLACK_SN850_2TB_204704800642.device
4.085s sys-devices-pci0000:00-0000:00:01.1-0000:01:00.0-nvme-nvme0-nvme0n1-nvme0n1p1.device
4.085s dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2dnvme\x2d1\x2dpart1.device
4.085s dev-nvme0n1p1.device
4.085s dev-disk-by\x2did-nvme\x2dPCIe_SSD_20120110242210\x2dpart1.device
4.084s dev-disk-by\x2did-nvme\x2dPCIe_SSD_20120110242210_1.device
4.084s sys-devices-pci0000:00-0000:00:01.1-0000:01:00.0-nvme-nvme0-nvme0n1.device
4.084s dev-disk-by\x2did-nvme\x2dnvme.1987\x2d3230313230313130323432323130\x2d5043496520535344\x2d00000001.de…
4.084s dev-disk-by\x2did-nvme\x2dPCIe_SSD_20120110242210.device
4.084s dev-nvme0n1.device
4.084s dev-disk-by\x2ddiskseq-5.device
4.084s dev-disk-by\x2dpath-pci\x2d0000:01:00.0\x2dnvme\x2d1.device
4.075s dev-disk-by\x2duuid-f55db9ba\x2da175\x2d4729\x2da3cf\x2d3a581950eeb2.device
4.066s dev-disk-by\x2did-nvme\x2dPCIe_SSD_20120110242210_1\x2dpart1.device
4.066s dev-disk-by\x2ddiskseq-5\x2dpart1.device
4.066s dev-disk-by\x2did-nvme\x2dnvme.1987\x2d3230313230313130323432323130\x2d5043496520535344\x2d00000001\x2…
4.056s dev-disk-by\x2dpartuuid-f60bf426\x2d01.device
3.993s sys-subsystem-bluetooth-devices-hci0.device
3.993s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:08.0-0000:07:00.3-usb3-3\x2d5-3\x2d5:1.0-blue…
3.781s dev-bus-usb-001-003.device
3.781s sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:08.0-0000:07:00.1-usb1-1\x2d2.device
3.715s sys-devices-virtual-misc-rfkill.device
3.715s dev-rfkill.device
764ms NetworkManager.service
722ms initrd-switch-root.service
400ms systemd-journald.service
348ms avahi-daemon.service
341ms systemd-tmpfiles-setup.service
328ms bluetooth.service
302ms polkit.service
263ms systemd-udev-trigger.service
251ms systemd-remount-fs.service
244ms initrd-cleanup.service
238ms systemd-modules-load.service
238ms lm_sensors.service
236ms systemd-journal-flush.service
234ms [email protected]
224ms [email protected]
206ms systemd-machined.service
201ms lvm2-monitor.service
185ms [email protected]
184ms dev-hugepages.mount
183ms linux-modules-cleanup.service
183ms garuda-pacman-snapshot-reject.service
181ms kmod-static-nodes.service
181ms dev-mqueue.mount
180ms sys-kernel-debug.mount
170ms sys-kernel-tracing.mount
168ms garuda-pacman-lock.service
168ms dev-zram0.swap
166ms dracut-shutdown.service
149ms [email protected]
149ms systemd-vconsole-setup.service
127ms var-log.mount
126ms var-tmp.mount
120ms systemd-binfmt.service
112ms dbus.service
107ms udisks2.service
98ms dracut-pre-udev.service
84ms [email protected]
82ms ModemManager.service
80ms home.mount
79ms root.mount
78ms systemd-oomd.service
78ms srv.mount
77ms var-cache.mount
72ms systemd-tmpfiles-setup-dev-early.service
71ms upower.service
62ms systemd-timesyncd.service
60ms systemd-logind.service
59ms systemd-udevd.service
52ms systemd-sysctl.service
51ms systemd-user-sessions.service
49ms tmp.mount
46ms modprobe@dm_mod.service
45ms [email protected]
45ms initrd-udevadm-cleanup-db.service
42ms systemd-random-seed.service
40ms sys-fs-fuse-connections.mount
40ms smb.service
38ms systemd-tmpfiles-clean.service
30ms libvirtd.service
29ms dracut-cmdline.service
29ms nordvpnd.socket
28ms systemd-tmpfiles-setup-dev.service
27ms systemd-update-utmp.service
26ms [email protected]
20ms systemd-fsck-root.service
18ms proc-sys-fs-binfmt_misc.mount
16ms initrd-parse-etc.service
14ms power-profiles-daemon.service
11ms dracut-pre-pivot.service
9ms wpa_supplicant.service
8ms systemd-rfkill.service
8ms cups.service
7ms rtkit-daemon.service
Your BIOS is pretty out of date. You are missing a lot of stability improvements among other things like security fixes.
Considering this happened after a kernel update and what issues you are experiencing, I would update to the latest BIOS version.
Ok I’ll try that
Output of dmesg please?
How do I post all of that its a lot of stuff?
Upper right on forum page, too
In my terminal is show a few things in red. Also my terminal won’t let me scroll all the way to the top of it.
.929944] BTRFS: device fsid f55db9ba-a175-4729-a3cf-3a581950eeb2 devid 1 transid 18177 /dev/nvme0n1p1 scanned by (udev-worker) (514)
[ 1.936333] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 545.29.06 Thu Nov 16 01:59:08 UTC 2023
[ 1.965477] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 356.002587] [drm:drm_new_set_master] ERROR [nvidia-drm] [GPU ID 0x00000a00] Failed to grab modeset ownership
[ 6397.263191] Bluetooth: hci0: unexpected event for opcode 0x0c24
Those last line are just the ones marked in RED
sudo dmesg | nc termbin.com 9999 then post the resulting URL here.
https://termbin.com/wpc5
So a ran the update again and its doing the same things super slow boot
sudo dmesg had a lot more errors, also I did the bios update.
There was a lot of these errors:
[drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000a00] Flip event timeout on head 1
And from your garuda-inxi
:thinking:
That’s odd… All I can really think of is that there is some sort of new issue with the new kernel version with the parameter nvidia-drm.modeset=1 being on in an X11 session (at least with your specific setup).
Flipping doesn’t seem to be working right at all, so I would remove the specific kernel parameter and still stick with X11 Plasma sessions.
In the Garuda Boot Options program, you can remove nvidia-drm.modeset=1 from your kernel parameters, hit apply, and restart to see if that will fix you issue.
If that doesn’t seem to help, you can put that kernel parameter back in place and try a Wayland Plasma session which you can select on the login screen.
Should I update to the broken update before doing all of this or after? the system is still usable in it’s broken State just the booting and shutdown is painfully long
I would do that kernel parameter change before the update. Then after the reboot for it, garuda-update.
Or you can load a working snapshot (without this problem) and compare the kernel parameters with the current ones. If they are the same, you can rule that out as a reason.
Okay I removed that kernel parameter then I rebooted then I updated the system and I can confirm that seems to fix it. I’ve been using the x11 should I switch to the Wayland now? I don’t mind to keep using x11
Stick with X11 for now.
When KDE 6 becomes available in about a few months, you can try putting that kernel parameter back and trying Wayland (if you are interested in trying it out) since it will have better support by then.
Big thanks to everyone who helped sort this out for me I really appreciate it. :blush::blush:
