inxi -Faz
[[email protected] old]$ inxi -Faz
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=657229c1-3537-4059-91ed-d7fbf1917eba rw [email protected]
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: Acer product: Swift SF114-34 v: V1.08
Mobo: JSL model: Labatt_JL v: V1.08 serial: <superuser required>
UEFI: Insyde v: 1.08 date: 05/11/2021
ID-1: BAT0 charge: 41.4 Wh (79.8%) condition: 51.9/48.0 Wh (108.1%)
volts: 12.0 min: 11.2 model: LGC KT0030G020 AP18C8K type: Li-ion
serial: <filter> status: Discharging cycles: 4
Info: model: Intel Celeron N4500 bits: 64 type: MCP arch: Tremont family: 6
model-id: 0x9C (156) stepping: 0 microcode: 0x1D
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 1.5 MiB desc: 1x1.5 MiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1608 high: 1720 min/max: 800/2800 scaling:
driver: intel_pstate governor: performance cores: 1: 1720 2: 1496
bogomips: 4454
Device-1: Intel JasperLake [UHD Graphics] vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:4e55 class-ID: 0300
Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-4:3
chip-ID: 0408:a094 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.2 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157
size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
Device-1: Intel vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:4dc8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX201 160MHz driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:4df0 class-ID: 0280
bus-ID: 1-8:5 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 88.12 GiB used: 57.3 GiB (65.0%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: Kingston model: TA2964
size: 58.31 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0x8 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Lexar
model: USB Flash Drive size: 29.81 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 28.6 GiB size: 28.6 GiB (100.00%) used: 27.9 GiB (97.5%)
fs: btrfs dev: /dev/mmcblk0p5 maj-min: 179:5
used: 57 MiB (59.4%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
ID-3: /home raw-size: 28.6 GiB size: 28.6 GiB (100.00%)
used: 27.9 GiB (97.5%) fs: btrfs dev: /dev/mmcblk0p5 maj-min: 179:5
ID-4: /var/log raw-size: 28.6 GiB size: 28.6 GiB (100.00%)
ID-5: /var/tmp raw-size: 28.6 GiB size: 28.6 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.64 GiB used: 321.5 MiB (8.6%)
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 248 Uptime: 21m wakeups: 1 Memory: 3.64 GiB
used: 1.89 GiB (51.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1506 lib: 377 Shell: Bash
v: 5.1.12 running-in: gnome-terminal inxi: 3.3.11
I'm hoping for some advice on how to proceed. Currently I can't update my Garuda installation because there's not enough space.
It's installed in a single 29GB btrfs partition, with most of my user data stored on an external 32GB non-btrfs USB stick. This is just on a cheap laptop I use for working on when away from home.
The problem started last week when I tried a system update (via pacman -Syu).
After an hour downloading about a GB of newer packages it started to install them and I think tried to take a system snapshot. Unfortunately it failed, with timeshift reporting there was not enough space. There was a little under 1GB of free space. So the update did not proceed.
I looked at timeshift to try to see what snapshots had been taken, and indeed it reported there was not enough space (700MB available, less than the minimum needed of 1000MB).
There were four snapshots listed, and I deleted one in the hope of freeing enough space. It had a minuscule effect on disk usage.
Right now it's saying:
2021-11-28 16:04:49, 7.3GB size, 30.7MB unshared
2021-11-28 18:30:53, 7.3GB size, 13.5MB unshared
2022-01-01, 03:01:25, 9.8GB size, 5.1GB unshared
733MB available.
I think the above means that in 7.3GB of files, there's a delta of 30.7MB of changed files, and in a 2nd snapshot 13.5MB of differences. In the 2022 snapshot though there were a lot of changes (5.1GB).
When I ran pacman -Syu today it gave up much faster, not even downloading any updates because of insufficient space:
pacman -Syu
core 137.5 KiB 37.8 KiB/s 00:04 [------------------------------------] 100%
extra 1564.0 KiB 526 KiB/s 00:03 [------------------------------------] 100%
community 6.0 MiB 621 KiB/s 00:10 [------------------------------------] 100%
multilib 152.1 KiB 332 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur 1706.1 KiB 1204 KiB/s 00:01 [------------------------------------] 100%
resolving dependencies...
Packages (100) alsa-card-profiles-1:0.3.43-1 android-udev-20220102-1 appstream-0.15.1-2 brltty-6.4-8
ca-certificates-mozilla-3.74-1 cht.sh-git-r892.46d1a5f-1 curl-7.81.0-1 e2fsprogs-1.46.5-1
evolution-data-server-3.42.3-1 flameshot-0.10.2-2 garuda-assistant-2.5.1-1
garuda-fish-config-1.4.4-1 garuda-hooks-2.5.4-1 garuda-update-1.6.1-1
garuda-wallpapers-r66.bc0053b-1 gjs-2:1.70.0-2 glslang-11.7.1-3 gnome-autoar-0.4.2-1
gnome-software-41.3-1 gnome-software-packagekit-plugin-41.3-1 google-chrome-97.0.4692.71-1
gst-plugin-pipewire-1:0.3.43-1 gtk-update-icon-cache-1:4.6.0-1 gtk4-1:4.6.0-1
haveged-1.9.16-1 hidapi-0.11.2-1 iso-codes-4.9.0-1 kaccounts-integration-21.12.1-1
kdenlive-21.12.1-1 lib32-curl-7.81.0-1 lib32-e2fsprogs-1.46.5-1
lib32-libva-mesa-driver-21.3.3-1 lib32-mesa-21.3.3-1 lib32-mesa-vdpau-21.3.3-1
lib32-opencl-mesa-21.3.3-1 lib32-vulkan-intel-21.3.3-1 lib32-vulkan-mesa-layers-21.3.3-1
lib32-vulkan-radeon-21.3.3-1 libgphoto2-2.5.28-1 libnumbertext-1.0.8-1 libpipeline-1.5.5-1
libreoffice-fresh-7.2.5-1 libsoup-2.74.2-2 libsoup3-3.0.4-2 libsysprof-capture-3.42.1-2
libtg_owt-0.git10.6708e0d-2 libva-mesa-driver-21.3.3-2 libxnvctrl-495.46-2
linux-lts-5.10.90-1 linux-lts-headers-5.10.90-1 linux-zen-5.15.13.zen1-1
linux-zen-headers-5.15.13.zen1-1 mesa-21.3.3-2 mesa-vdpau-21.3.3-2 mpv-1:0.34.1-1
mutter-41.2-2 nlohmann-json-3.10.5-1 nss-3.74-1 opencl-mesa-21.3.3-2 pipewire-1:0.3.43-1
pipewire-alsa-1:0.3.43-1 pipewire-jack-1:0.3.43-1 pipewire-pulse-1:0.3.43-1
pipewire-v4l2-1:0.3.43-1 pipewire-zeroconf-1:0.3.43-1 pkcs11-helper-1.28.0-1
protobuf-3.19.2-1 python-isodate-0.6.1-1 python-pillow-9.0.0-1 python-psutil-5.9.0-1
python-pygments-2.11.2-1 python-reportlab-3.6.5-1 python-setuptools-1:59.1.0-1
qt5-base-5.15.2+kde+r276-1 qt5-declarative-5.15.2+kde+r42-1
qt5-quickcontrols2-5.15.2+kde+r9-1 qt5-script-5.15.8-2 qt5-svg-5.15.2+kde+r15-1
qt5-webengine-5.15.8-1 qt6-base-6.2.2-4 signon-kwallet-extension-21.12.1-1 sqlite-3.37.1-1
systemd-250.1-1 systemd-libs-250.1-1 systemd-sysvcompat-250.1-1 tealdeer-1.5.0-1
util-linux-2.37.2-5 util-linux-libs-2.37.2-5 vulkan-intel-21.3.3-2
vulkan-mesa-layers-21.3.3-2 vulkan-radeon-21.3.3-2 vulkan-swrast-21.3.3-2 whois-5.5.11-1
wireplumber-0.4.6-1 wxgtk-common-3.0.5.1-3 wxgtk3-3.0.5.1-3 xorg-server-21.1.3-1
xorg-server-common-21.1.3-1 xorg-server-xephyr-21.1.3-1 zita-alsa-pcmi-0.4.0-1
Total Download Size: 593.62 MiB
Total Installed Size: 2378.52 MiB
Net Upgrade Size: -15.60 MiB
error: Partition /var/cache too full: 157113 blocks needed, 156459 blocks free
error: failed to commit transaction (not enough free disk space)
What would you advise?
My guess is that I should unmount my external 32GB user files and format a fresh 32GB USB drive as btrfs and change over to using that for timeshift's snapshots via btrfs.
I worry that otherwise, if I deleted the 5.1GB snapshot of 2022/1/1, after the fresh update from the really old snapshot, there wouldn't be space.
It also felt bad to me that the update didn't offer me the chance to proceed without taking a snapshot, on the understanding I'd be taking a risk in that if there was a problem, the system wouldn't be able to roll back to a known good state. (Maybe that's a reasonable safety precaution.)
Because the snapshots vary so much in actual size (from 13MB to 5GB), I lso wonder whether the "Not enough disk space" warning in timeshift is reporting the apparent size needed or the actual size the snapshot would need on a btrfs file system.
Anyway, those are just background thoughts. My main hope is to get some advice at what I can do to update my system.
Thanks in advance.
