I am trying to install from Snap (Photogimp)
but it does not work.
Have tried installing on Snap but it does not help?
Anyone have a solution to this?
MVH Pata66
<jonathon> !give pata66 doesntwork
<phrik> pata66: What do you mean it doesn't work? If there's an error, *tell us*. If it's more than two lines, see !paste.
Ensure prerequisites for "photogimp" are available
Installerar photogimp
Fetch and check assertions for snap "snapd" (9607)
Mount snap "snapd" (9607)
Snap install error:
cannot perform the following tasks:
- Mount snap "snapd" (9607) ([start snap-snapd-9607.mount] failed with exit status 1: Job failed. See "journalctl -xe" for details.
Is /snap
a symlink to /var/lib/snapd/snap
by any chance, as in this thread:
Yeah try removing /snap
